Old 07-18-2013, 02:37 PM   #496
cross-country
cross-country's Avatar
Oddometer: 1,645
Originally Posted by jonb View Post
I assume on the 500XCW there is no way to bring the idle down a little without going into the KTM dealership and having them check your TPS and seeing if its where it should be...right?
My 500 idles faster than any other bike i have owned but its not outrageous. If i could, i would lower it.
Are others finding their XCWs idle a little high?
Thanks.
Idle adjust is on the side of the TB. It should idle higher than any carb'd dirtbike you have ever owned, the FI likes it that way. Just ignore it and eventually it will become the new normal to you.
cross-country is online now   Reply With Quote
Old 07-18-2013, 11:35 PM   #497
Scubatoe
Trained monkey
Scubatoe's Avatar
Oddometer: 200
Thanks.
The knob on the throttle body pulls out for cold start, and rotates for idle adjust.
Scubatoe is offline   Reply With Quote
Old 07-19-2013, 07:23 AM   #498
rotorhead511
Live and let live.
rotorhead511's Avatar
Oddometer: 479
You all are right. It's the bulb contact. I took the headlight assembly apart and bent the bulb contacts toward the bulb for better contact. With a loose connection there is increased resistance that bulbs don't like. I'll keep an eye on it but think it will help.
Next I'm going to figure out the high/low control and post pics. It's really not needed but if I have a switch that can control something I want it to work. I have issues.
Originally Posted by CamelBill View Post
Stock headlight does not work very well, if at all, on mine either,. Even with the switch on. The bulby is fine, lights right up when hoooked up direct to a battery. Me thinky these things are just sucky
'12 450 XC-W
'11 300 XC
'04 GasGas TXT Pro 280
'89 Honda Transalp XL600V
rotorhead511 is offline   Reply With Quote
Old 07-19-2013, 09:42 AM   #499
jonb
Montana Adventurer
jonb's Avatar
Oddometer: 285
Idle speed.
Copy that. Thank you.
JB
jonb is offline   Reply With Quote
Old 07-20-2013, 04:40 PM   #500
guns_equal_freedom
Oddometer: 5,530
Plated my XC-W 500 yesterday.
The Sicass kit was almost a perfect plug and play with the exception of the rear brake light wiring.
I have the Rekluse left hand rear brake so I mounted the switch at the master cylinder.
I had to lengthen the wire just a bit to have it fit.
Sicass offered to make me a custom wire for the same price, I didn't want to wait.
I even ordered the Sicass key set up.
guns_equal_freedom is offline   Reply With Quote
Old 07-22-2013, 07:37 AM   #501
Too Tall
Too Tall's Avatar
Oddometer: 186
Low Fuel Light "no-worky"
Anyone having a problem with a non-working low fuel light on their 500 XCW or EXC? Mine worked the first few tanks of fuel but has not since.
Have checked the bulb and it is fine. Did install the fuel cap sock-type filter about the same time the low fuel light quit functioning. Would the filter have stopped a float from lowering as the fuel level dropped? I always assumed the fuel level float was internal to the pump.
Will probably pull the fuel pump soon if no one has a better idea. All fuses are good and the bike runs great. Has the European mapping installed.
Thoughts?
www.2wheel-adventure.blogspot.com
2014 KTM 350EXC-F
2012 Triumph 800XC
2010 KTM 990 SMT
2007 Suzuki DR650
Too Tall is offline   Reply With Quote
Old 07-22-2013, 07:39 AM   #502
rotorhead511
Live and let live.
Oddometer: 479
Not much help but...
Mine isn't working either. I posted my issue in KTMtalk as well and go no response.
Thoughts?
'12 450 XC-W
'11 300 XC
Old 07-22-2013, 07:42 AM   #503
Too Tall
Too Tall's Avatar
Oddometer: 186
rotor,
Hopefully someone else has had this problem and figured out it's source.
2014 KTM 350EXC-F
2012 Triumph 800XC
2010 KTM 990 SMT
2007 Suzuki DR650
Old 07-27-2013, 09:23 AM   #504
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,562
But ya need little chick hands to get to it !
Guns keep society safe.
Colemanfu is online now   Reply With Quote
Old 07-29-2013, 01:15 PM   #505
guns_equal_freedom
Oddometer: 5,530
A long thin straight slot screwdriver works just fine.
Old 07-31-2013, 08:17 PM   #506
Too Tall
Too Tall's Avatar
Oddometer: 186
Thoughts?
Well I took the fuel pump assembly out of the 500's gas tank. The low fuel sensor is not working and needs replaced. Dash light will come on if the sensor is short circuited. Unfortunately, KTM only sells the sensor with the fuel pump which is big $$$. No markings on the sensor so unsure how to find a source for replacing it. Thoughts again?
2014 KTM 350EXC-F
2012 Triumph 800XC
2010 KTM 990 SMT
2007 Suzuki DR650
Old 08-01-2013, 12:33 PM   #507
rotorhead511
Live and let live.
Oddometer: 479
TooTall, mine actually came on today but I didn't notice it until my bike quit. I would accept it and keep an eye in it or carry some fuel.
May not help but I wouldn't pay for a new fuel pump.
'12 450 XC-W
'11 300 XC
rotorhead511 screwed with this post 08-04-2013 at 12:00 PM
Old 08-04-2013, 07:41 AM   #508
davidm
davidm
Oddometer: 32
500
Great topic for all 500 owner's
David
davidm is offline   Reply With Quote
Old 08-08-2013, 10:39 AM   #509
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,291
I'm in the process of getting my 500 ready for the cam1k (a one thousand mile offroad ride in colorado).
Has anyone gone to a larger foot peg on their 500? If so, I'd be interested to hear what you went to and how you like it.
Old 08-08-2013, 01:19 PM   #510
Lulu7404
Oddometer: 277
17" Warp9 sumo set up FS
since i got the lil CBR for track days I haven't put the 17's back on the 500. just put them up on flea market. used once
http://www.advrider.com/forums/showt...6#post22057096
14 Triumph Tiger 800
13 KTM 350XCF-W -- new hotness
13 KTM 250XCF-W -- hers
Lulu7404 is offline   Reply With Quote
Times are GMT -7.   It's 09:44 AM.
