01-11-2013, 06:44 AM
#76 |
Same here. I thought I needed something better two up.
I'll be checking one out.
" The lesser of two evils is still evil" |
01-11-2013, 07:40 AM
#77 |
Oddometer: 2,820
01-11-2013, 07:48 AM
#78 |
Oddometer: 628
One of the pictures shows the same luggage as the Sprint GT. I dig the fully adjustable suspension. This would have definitely been in the running before I bought my GT.
2011 Sprint GT, 2008 Kawasaki KLR650, 1981 Honda CB750F, 1957 BSA Bantam D3 restoration project, Past bikes -1986 Honda Shadow VT1100C, 1998 Honda Shadow Aero VT1100C3, 2006 Yamaha FZ6, 2006 Kawasaki ZX-14,1980 Yamaha XT500 |
01-11-2013, 08:05 AM
#79 |
Oddometer: 628
and an information scroll button on the handlebar switch....
01-11-2013, 09:45 AM
#80 |
Doesn't Care
Oddometer: 1,517
why? is there a lack of big-bore adventure bikes all of a sudden?
--Semantics are everything. |
01-11-2013, 10:00 AM
#82 |
Oddometer: 426
It's a road bike.
01-11-2013, 10:41 AM
#84 |
Oddometer: 17,983
"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind." — Dr. Seuss “Watch out for everything bigger than you, they have the "right of weight" Bib |
01-11-2013, 11:35 AM
#85 |
Oddometer: 26
01-11-2013, 11:53 AM
#86 |
Oddometer: 886
Damn, that makes me miss my 1050 triple in my Sprint. That engine is absolutely awsome! Triumph steps it up once again. If they gave it good suspension then Ducati is in trouble.
_______________ 2012 Tiger 800 XC |
01-11-2013, 12:16 PM
#87 |
Oddometer: 149
01-11-2013, 01:21 PM
#88 | |
Doesn't Care
Oddometer: 1,517
01-11-2013, 02:39 PM
#89 |
new to ADV
Oddometer: 6
Tiger 1050 Sport
FEATURES
The new Tiger Sport takes the adventure style street bike category to another level. The new exhaust and upgraded intake system have enabled our engineers to deliver an additional 10PS of power and 6Nm of torque from its 1050cc triple engine whilst boosting the output across the full range of revs. The engine’s growl sounds throatier and meaner too, but more importantly, it has improved acceleration with an output of 125PS (123 bhp, 92kW) and 104Nm (77lb.ft, 10.6kgm). Also new for the Tiger Sport is an updated gearbox that brings slicker, faster gear changes. Major revisions to the styling create a more sporting look coupled with a new single sided swingarm which improves packaging and allows more space for the new exhaust and larger optional panniers. The fully adjustable suspension has been completely redeveloped with new springs and re-valved damping. The new stronger rear subframe provides greater payload capacity (220kg) and greater rigidity, whilst improved ergonomics make for a more comfortable ride. AN IMPROVED ENGINE The Tiger Sport's engine creates a more dynamic, punchy and responsive ride with more power, torque and improved fuel efficiency. The 1050cc three-cylinder engine that powers the Tiger Sport has been upgraded with improved gas flow, a new air box, better breathing and even more distinctive sound. This all results in improved acceleration and, combined with gearbox revisions, provides lighter, more responsive gear changes. Output increases by 10PS to 125PS (123 bhp, 92kW) and 104Nm (77lb.ft, 10.6kgm). With the added advantage of better fuel economy. SUPERIOR HANDLING Key to the Tiger Sport is a chassis that not only delivers comfort but also sporting fun. Fully adjustable suspension and new springs with re-valved damping enable high levels of adjustability and feel. The new stronger rear subframe provides greater payload and greater rigidity meaning the fun continues even when riding two up. This gives the bike its sharper feel with enough left in reserve to handle the additional load capacity offered by the fitment of the optional Triumph Dynamic Luggage System. TDLS features an inter-connecting cable between each pannier to isolate turbulence-induced movement from the chassis resulting in a more stable ride. The latest ABS system is standard and includes a new modulator for better extreme braking and improved feel to back up the Tiger’s radial brakes. It all goes to create a bike you’ll relish taking through the twistys. MORE COMFORT Not only has ride comfort improved, the seat is now narrower and more comfortable for both rider and passenger: it’s 5mm lower at the front and the handlebars are lower and closer to the rider, giving a more direct feel. The back seat is also lower, sitting the passenger fully behind the rider for better wind protection. Added versatility is also provided by the under seat storage compartment and the ability to store an optional U-Lock. Who said you can’t have comfort and a sporty ride in the same bike? ALL-NEW STYLING Attention to detail has shaped the Tiger Sport. A specially designed single-sided swing-arm, newly styled side panels, tail unit and screen all make the bike look sportier. New lightweight reflector type headlights improve lighting performance and create a new visual look. Sculptured footrests, coloured seat stitching, tougher material on the underside of the seat, aluminium pannier mounts and careful styling of the new fork yokes and engine side casings add to that impression. In fact, the fit, finish and build quality of every single facet of the bike has been improved for 2013. New colours: Crystal White or Diablo Red. ACCESSORIES A wide range of accessories are available for Tiger Sport including the optional Triumph Dynamic Luggage System. Payload is doubled to 10kg per pannier. The left sided pannier is 31 litres and is capable of storing a full face helmet, the right sided pannier is 24 litres in order to shape around the silencer. The Dynamic Luggage System is designed to minimise the forces passed through to a bike's chassis induced by turbulence around the luggage. It does this by partially cross-linking the panniers, which are free to pivot on their top mountings by several degrees, so that the force on one pannier is passed through to the other without affecting the main chassis of the bike resulting in a bike which is more stable and yet more agile. |
01-11-2013, 02:59 PM
#90 |
Oddometer: 238
Looks to be an excellent touring ride. I am guessing this is exactly the market they are after, someone who wants to tour that also wants comfy ergos and performance for 99% road use. Most riders that tour rarely venture off the beaten path anyway. Its just a dreamers dream to have the bike that can supposedly do it all even though it will see about 15 miles of off pavement use in its lifetime. Kind of like owning a Hummer, it can go anywhere but never leaves the pavement. I think it looks like a killer Trumpy! Here is to hoping it comes stateside eventually so I can check it out. Please bring it to the US Triumph........
2008 Yamaha FJR1300 "If you Can't Fix it with a Hammer, it must be an Electrical Problem......" |
