Old 03-21-2012, 10:06 AM   #16
Johnf3 OP
Oddometer: 989
Originally Posted by brents347 View Post
I got mine used from a guy who had a SM set-up for a 450/520 RFS bike.
As I recall, the caliper sliding pins were too far apart by about 2 or 3mm so I welded closed the old lower pin hole (the pin is thread in) and then redrilled the caliper bracket on the proper pin spread.
Does that make sense?
Yes, that is what I heard too. Thanks for that. I don't have the know how or the equipment for that, so I will see if we can keep CJ interested in making us a batch.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is offline   Reply With Quote
Old 03-28-2012, 02:33 AM   #17
LukasM
Oddometer: 4,900
I am pretty sure that KTM now has a 320mm bracket that will fit, advertised for the 2009+ dirt bikes which have an updated Brembo 2 piston caliper. It's even smaller than the old one but should have the same pin spacing as the ADV/SE from what I was able to find out.
77013914000 if anybody wants to give it a try.
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Old 04-11-2012, 02:31 PM   #18
brents347
KOTW 2010 Finisher
brents347's Avatar
Oddometer: 2,971
So Lukas, this is the brake caliper bracket you are talking about. What makes you think that it would be correct for a 950 ADV caliper? I can't find any information on it or what bike it is for at all.
Brent
Brents347 Truckee, CA.
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
brents347 is offline   Reply With Quote
Old 04-11-2012, 02:47 PM   #19
LukasM
Oddometer: 4,900
Brent
KTM sells it for supermoto conversions of all 530 and smaller bikes that come with the new style 2 piston Brembo caliper.
Unlike the old dirt bike caliper, this one is supposed to share the same pin spacing as the 950/990 big piston calipers, or so I have been told.
I actually just put one of these new calipers on a bike so I can measure it tomorrow to confirm. If the pin spacing is correct, the only remaining issue is axial spacing. If necessary it would be easy to make some adjustments using aluminum spacers here.
Old 04-11-2012, 03:12 PM   #20
Johnf3 OP
Oddometer: 989
Lukas,
If you could measure it and compare, that would be great.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Old 04-11-2012, 07:00 PM   #21
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,332
hmmm
hey CJ, yeah I am keen depending on price.
Joe
Simpson Trip 2008
http://www.advrider.com/forums/showt...33#post7397233
Life should NOT be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, body thoroughly used up, totally worn out and screaming "WOO HOO - what a ride!"
MymoJoe is offline   Reply With Quote
Old 04-29-2012, 06:26 AM   #22
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 2,574
I want to go single disk with stock caliper and master cylinder initially and later try the SE master if required.
My 990 has the split brake lines so i will need a new brake line. Will the one from a 950SE fit the Adv Master and caliper ? What about length, i don't think it should be an issue, but still thought i'd ask.
cheers
'07 KTM Adv990S
No myriad hues of laser lights no bottles that are oozing with nectars from heaven, no beautiful body soft and warm to the touch but, i have a very small desire.. Give me a dark.. long.. winding road, three gears to go and my Hellas on fire..
950Rally picture thread
Vicks is offline   Reply With Quote
Old 04-30-2012, 02:25 AM   #23
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 2,574
My 990 has the split brake lines so i will need a new brake line. Will the one (brake line) from an 950SE fit the Adv Master and caliper ? What about length, i don't think it should be an issue, but still thought i'd ask.
cheers
anybody ?
'07 KTM Adv990S
Old 04-30-2012, 03:11 AM   #24
LukasM
Oddometer: 4,900
The line just loops above the bars so it will not matter if it's a bit longer, but if you have S length suspension it should be fine anyway.
Old 04-30-2012, 03:16 AM   #25
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 2,574
Thanks Lukas, my other question was about the compatibility of the 950SE brake line with the Adv master cylinder. I'm not sure what type of end is on the 950SE brake line but on mine IIRC, it has a male threaded end instead of a banjo end. This will thread directly into the MC instead of using a banjo bolt with copper washers to be fixed at the MC. At the caliper, its the regular banjo type.
'07 KTM Adv990S
Old 04-30-2012, 04:10 AM   #26
mousitsas
Oddometer: 2,129
I am using 950ADV master with SE line. No problem. I guess 990 master is the same.
Old 04-30-2012, 06:00 AM   #27
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 2,574
thx.
'07 KTM Adv990S
Old 06-14-2012, 12:05 PM   #28
Dan950ser
NW Shredder
Oddometer: 197
Hey wanted to bring this thread back. Looking to do a 320mm on my 950 se. I have a left over new 320mm rotor from my 450 smr as well as the radial caliper. I know the caliper won't fit with the 21" wheel but wanted to use the rotor with a relocating bracket and wondered if anybody figured out a solution. Or... Cj did you end up making a batch? Thanks.
2007 KTM 950 Super Enduro R: titanium Q's, CJ Rack, H2W Jetting, Scott's triples and dampner and more to come.
2005 CR 500AFC: Need more be said BEAST!!!
Dan950ser is online now   Reply With Quote
Old 06-14-2012, 10:47 PM   #29
tahoeacr
tahoeacr's Avatar
Oddometer: 2,169
Originally Posted by Dan950ser View Post
I know the caliper won't fit with the 21" wheel but wanted to use the rotor with a relocating bracket and wondered if anybody figured out a solution. .
Why won't it fit? I've seen brackets for them.
http://www.motostrano.com/Brembo-Sup...331-2004x-.htm
tahoeacr is offline   Reply With Quote
Old 06-15-2012, 12:52 AM   #30
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 888
4pots hit the spokes.
You should be able to order the new style 2012 exc ktm bracket and use the original caliper of your SE.
950 Rally custom - 690 Enduro Ride ON!
StevenD is offline   Reply With Quote
Times are GMT -7.   It's 02:07 PM.
