Old 06-15-2012, 06:18 AM   #31
Johnf3 OP
Oddometer: 1,068
Originally Posted by tahoeacr View Post
Why won't it fit? I've seen brackets for them.
http://www.motostrano.com/Brembo-Sup...331-2004x-.htm
The caliper pin spacing is different on the Brembo caliper that the 950/990 uses. These adapters are for the smaller calipers on all the other KTMs. Won't work.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is offline   Reply With Quote
Old 06-15-2012, 06:23 AM   #32
LukasM
Oddometer: 5,427
These off-the-shelf brackets are for a radial caliper and not the stock one, and the radial caliper will not fit with them on a 21" wheel because it's too wide as StevenD said. It might be possible to make it fit with a custom bracket and a disc spacer, but you'd have to build it yourself.
As I said above the 2009+ 530 and smaller KTMs use a new caliper that has the same pin spacing as the 950/990 Adv + Se, and 690 E / R. This is why I recommended somebody to try the 77013914000 bracket with a 320mm disc.
Old 06-15-2012, 11:10 AM   #33
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,385
With the motostrano addition i think there will clearence enough for the magura 4pot.
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 06-15-2012, 06:02 PM   #34
Aussie Steve
Aussie Steve's Avatar
Oddometer: 1,401
Caliper mount is irrelevant, its the space between the inside of the disc and the spokes which is too small for the caliper.
Anyone tried the KTM bracket Lukas listed?
I have found many references to it working without seeing proof it does and one claim that it doesnt?
Aussie Steve is offline   Reply With Quote
Old 06-18-2012, 02:21 AM   #35
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,149
Still looking for a 950 or 690 calliper. as soon as i find one i'll order this bracket. Have an exc calliper on the 999 now.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 06-18-2012, 09:36 PM   #36
tahoeacr
tahoeacr's Avatar
Oddometer: 2,212
I'm not following here. You have the 320 disc and 4 piston caliper. Why not figure it out? How wide is your caliper? My four piston is 66mm wide. Fits fine with the stock wheel. Probably go as wide as 72mm and have clearance.
tahoeacr is offline   Reply With Quote
Old 06-18-2012, 09:39 PM   #37
tahoeacr
tahoeacr's Avatar
Oddometer: 2,212
Caliper mount is the hardest part. Space between the disc and spoke is irrelevent. Mount the caliper then space the disc appropriately.
Old 06-19-2012, 12:05 AM   #38
Aussie Steve
Oddometer: 1,401
Are you sure?
Looked into this a while ago and the consensus was that the disc cant be spaced out far enough to clear.
When you say stock wheel is it the 17" or 21"?
Old 06-19-2012, 08:24 AM   #39
tahoeacr
tahoeacr's Avatar
Oddometer: 2,212
Are you sure?
I think I went 6.04mm with the the disc. Stock 21" rim
I know this thread is for stock caliper conversion but for that much trouble and how great the four pistons work I think Dan950ser should get his radial to work since he has one.
Your thinking this here
Looks bolt on with 17 mag but would probably need the adapter bracket milled(to move the caliper out) a little to clear 21" spokes. But since the bracket is available that is the direction I would head. Just throwin ideas out there for him.
Old 06-19-2012, 10:36 AM   #40
mousitsas
mousitsas's Avatar
Oddometer: 2,993
320 disc
You can use a stock 640SM caliper, they are made for 320 discs with the same fitting pattern as the 950/990.
The carriers are different though, so you need the hole assembly. Minor milling required (about 1mm off the inside of the carrier) depending on the rivet sizes of the disc you will use.
Old 06-19-2012, 06:41 PM   #41
Aussie Steve
Oddometer: 1,401
Thanks for the confirmation its possible.
Is that an adventure/SE or SD/SM? I have no idea on the LC8 but the LC4 variants used a different triple clamp with wider fork spacing on the duke/motard.
Old 06-19-2012, 09:45 PM   #42
tahoeacr
tahoeacr's Avatar
Oddometer: 2,212
07 990 adventure S so no anti-lock crap in the way.
Old 06-22-2012, 12:10 AM   #43
Aussie Steve
Oddometer: 1,401
Thanks again.
Old 06-22-2012, 02:16 AM   #44
Dan950ser
NW Shredder
Oddometer: 523
So was going to try and make the radial work but just realized my stock 2006 450 Smr stuff is a 310mm disc. Crap... What to do now. Well why I debate it I ordered a cyclops hid race light and xpc can't wait till they get here. Thanks for the input as this mod is in the near future for me.
2015 KTM 690 Enduro R, 2007 KTM 990 SuperDuperEnduroR Sale Pending, 2014 KTM 250 XC-W
Dan950ser is offline   Reply With Quote
Old 06-22-2012, 08:29 AM   #45
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,385
Can someone confim that these are 108mm or 100mm?
Regards
Mikael
KTM 530 EXC-R 08
Times are GMT -7.   It's 05:40 PM.
