Old 03-19-2012, 02:31 PM   #1
ThruTraffic OP
ThruTraffic's Avatar
Oddometer: 35
AltRider Crash Bars - Fit 2012 1200 GS ??
I want a set of AltRider Crash Bars for my new 2012 BMW R 1200 GS Triple Black. I went to their site and found the following review on their Web page.
http://www.altrider.com/altrider-cra...200-gs/pid/713
"I have a 2012 GS that needs crash bars. The AltRider bars looked to be the best choice and came highly recommended by my local BMW dealer. The problem is they don't fit! I contacted AltRider before buying these crash bars asking if they will fit the 2012model. The answer I got was "we have not been informed of any changes..." Another words; let the buyer find out for himself. After the dealer assured me they will fit I made the purchase only to find out the right side does not fit into the hole it is designed for. I had my son, a mechanical engineer, look at it and he determined the tolerances are too close and did not allow for paint and other variations. After an hour of hand filing and fitting I finally got them on. They look great and seem to be strong and purpose built however this lack of attention to detail is concerning!"
So I sent AltRider email asking for written confirmation that their bars will fit the 2012. Two weeks later; zero response.
So I called them. For the life of me I could not get the person I spoke to to say the words "Yes, they will fit the 2012". I couldn't get her to answer me when I asked if they'd actually installed a set on a 2012 yet. 15 minute conversation and nothing but beating around the bush alluding to this and that but they refuse to state yes they will or no they won't fit the 2012 but seem perfectly willing to sell me a set despite knowing if they fit my machine or not.
Have any of you other 2012 owners purchased these and found them to fit or not? I'm going to order a set and will report here my success/fail to mount them but would like to hear if anyone else has had a similar experience with AltRider?
ThruTraffic is offline   Reply With Quote
Old 03-19-2012, 11:44 PM   #2
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
says 05 to current. the bike has not changed.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 04-28-2012, 06:15 PM   #3
ThruTraffic OP
Oddometer: 35
OK, They do fit.
I bought a set and was successful in mounting them. However, I ran into the same problem as the person I quoted in my original post. The upper mounting attachment point on the right side is off by ~1/8” to ~1/4”. All of the installation went well until I hit that part and then I spent the next hour loosening other stuff, shaking, twisting, banging with a rubber hammer, etc. to get it together.
Tip; before you install the right side run a tap through the small bolt hole to drive out the black paint BMW filled it with. Also watch the length of the bolt supplied by AltRider for this as it is just a hair too long and comes into contact with the block on my machine.
Hey AltRider – I AM NOT LOOKING FORWARD TO REINSTALLING THESE THINGS AFTER EVERY TIME I TAKE IT TO THE SHOP FOR SERVICE!!!
I have a couple of photos of the problem but it looks like I don’t have permission to post attachments. I’ll post them if I can figure out why not and get perms.
There was also a spot where the black paint had been scraped off. Not a good thing to see come out of the box but given their purpose I let it slide.
Pros:
- I think they’ll go a good job if called on
- They look great
Cons:
- PITA to install
- Will have to suffer that PITA many times over the life of the machine
- Overpriced given the PITA
Old 04-28-2012, 08:06 PM   #4
Okie Preacher
Okie Preacher's Avatar
Oddometer: 949
The AltRider stuff fits tight, no doubt about it. But with the lower bars I found that it was only the first time on that was a wrestling match. Now I can have them off/on for a valve adjustment in 10 minutes.
I just installed their new upper bars on my GS on Monday. Same scenario. Same expectations for the second time on them as well.
Okie Preacher is offline   Reply With Quote
Old 05-03-2012, 04:52 PM   #5
ThruTraffic OP
Oddometer: 35
Valve Covers Will Come Off - Bars On
I'm planning a Deadhorse ride for September. Last night I woke up frm a nightmare where I was on the Dalton Highway is nasty conditions and had to pull the valve covers for some reason. I was working through how I was going to get the suspension compressed on my own. Yuck.
So I just came in from the garage and the valve covers will in fact come off without removing the bars. Kind of a puzzle but they will come off. So I can do valve adjustments on my own and won't have to pull the things when I take it to a dealer.
Whew
Okie Preacher: I wrote AltRider asking about the upper bars but as usual they didn't respond. It looks like the upper bar will cause me to have to remove my PIAA light bar. Is that true?
PS: When I mounted my lowers I threw a chain around my lift deck and a ratchet strap between that and triple tree. Cranked on that ratchet strap and that sucked the suspension towards the lift deck. Sweet.
Old 05-03-2012, 07:16 PM   #6
Okie Preacher
Oddometer: 949
I am surprised to hear that they haven't responded as I have always found their customer service to be quick and helpful. Call 'em and get them on the line...ask for Nick.
The PIAA bar mounts to one of the frame cross members behind the oil cooler, correct? The AltRider uppers mount a bit forward from there, so I think they might fit--but it will be tight at best.
I used a pair of light bar clamps from RocketMoto to mount my Krista's to the upper bars. Made for a nice installation and their customer service is STELLAR!
http://www.rocketmoto.com/index.php/...ght-mount.html
Old 05-04-2012, 11:46 AM   #7
ThruTraffic OP
Oddometer: 35
Looks like PIAA Light Bar has to go
I called them and they really don't know. They pointed me to the instructions and it's hard to tell from the photos but I have serious doubts they're compatible.
Instructions:
http://www.altrider.com//files/produ...r_R0.pdf_2.pdf
That's too bad. I can see this hurting their sales. There are a lot of these PIAA light bars out there that will have to go if people buy these bars.
Old 05-14-2012, 10:57 AM   #8
banshee
hi
banshee's Avatar
Oddometer: 6,160
I am purchasing a 2012 1200GS and just got off the phone with Altrider. I called because of that review and my concern that the bars won't fit. The person I talked to did not give me any confidence and was downright dismissive of the issue. Based on that conversation I won't buy their crash bars. It's too bad, I really wanted to. I have Altrider bits on my F800GS but that phone conversation was a real turn-off...
banshee is offline   Reply With Quote
Old 05-14-2012, 11:26 PM   #9
ThirdBestFriend
Explorer
ThirdBestFriend's Avatar
Oddometer: 119
They definitely fit a 2012 1200GS, I have them on mine — they were an utter bitch to get on though, partly because that bolt that goes through the engine was a complete mofo to get off.
ThirdBestFriend is offline   Reply With Quote
Old 05-15-2012, 06:32 AM   #10
motomandan
motomandan's Avatar
Oddometer: 452
Altrider
I went with Hepco-Becker tanks and cylinder guards on my 2012 triple black. You can remove the tank sidecovers (carefully). I have not tried removing the valve covers yet. It does look like they will come off, again carefully. Easy install, heavy built , offer a lot of protection to the cylinder head.
motomandan is offline   Reply With Quote
Old 05-15-2012, 06:55 AM   #11
birdie_xx
birdie_xx's Avatar
Oddometer: 840
Instructions:
Unfortunately every accessory is made for the stock bike, without any add-ons nor modifications. It would be impossible to take into consideration every other accessory out there....I know this from a different line of accessories.
BTW, when installing any frames on the bike (engine guards, saddlebag mounts..) where two sides are involved, it helps when lot of slack is left at the mounting points. When all is connected together and aligned (sort of) then the tightening may begin, one by one... Maybe that's the reason the bars won't quite fit on one side ?
I have number of accessories on my '09 GSA and everything fits spot on .
Cheers
birdie_xx screwed with this post 05-15-2012 at 07:05 AM
birdie_xx is offline   Reply With Quote
Old 05-15-2012, 07:17 AM   #12
Wandering Nomad
Obsessive Traveller
Wandering Nomad's Avatar
Oddometer: 363
I had a set on my 2011 GS. They are nice bars. Sturdy as hell.
Wandering Nomad is offline   Reply With Quote
Old 05-15-2012, 07:25 AM   #13
Bluetru
Bluetru's Avatar
Oddometer: 46
Laugh
I had my dealer install both the altrider crash bars and the altrider skid plate on my 2012 R1200GS TB. They look great and fit well. NO issues.
Bluetru is offline   Reply With Quote
Old 05-16-2012, 09:10 PM   #14
banshee
hi
banshee's Avatar
Oddometer: 6,160
just like to point out that one of the owners of Altrider contacted me concerned about my previous post in this thread. he said that they DO fit the 2012 and we also cleared the air about other stuff. was nice that they contacted me.
I am still undecided about crash bars. better figure it out soon, I pick up my new bike next week
Old 05-16-2012, 09:36 PM   #15
birdie_xx
birdie_xx's Avatar
Oddometer: 840
Their page says "fits 2008 and newer"
And they offer them now in RED to match the Rallye edition
http://www.altrider.com/en/product/detail/pid/927
Cheers,
Times are GMT -7.   It's 10:52 PM.
