Old 03-20-2012, 12:30 PM   #1
transalpian OP
Over, Across, and Through
Oddometer: 306
Fixed front calipers
Greetings all! My hack rig has regained the status of "moving under its own power"!!!!!
All in all, I'm pleased. But with all things, not yet "done". Here is an old picture. (Progress has been made since then)
As you can see, she has leading link forks with fixed calipers. Other than coverting to floating calipers, what can I do to minimize rise under braking? More front shock spring preload? Less? Other options?
Thanks in advance!
I'm on a one-year bike buying hiatus. If I contact you about buying a bike, ignore me!!
On second thought, maybe I'm interested....
transalpian is offline   Reply With Quote
Old 03-20-2012, 02:27 PM   #2
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,350
Thanks in advance!
I'm curious as to why you consider the rise to be an issue? My old Earles fork BMW braked that way, didn't seem to upset anything. Is it something you just have to get used to? I would think keeping the chair level and reducing front dive would make handling under braking more stable.
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 03-20-2012, 03:30 PM   #3
claude
Sidecar Jockey
Oddometer: 3,908
Floating calipers will make a difference. The rise, in simple terms, is actually a battle taking place between braking and suspension action. It will limit traction a lot in most cases under braking and is not nearly as desirable as otherwise.
Claude
http://freedomsidecars.com/
Old 03-20-2012, 03:36 PM   #4
BeeMaa
Hack Pilot
BeeMaa's Avatar
Oddometer: 1,098
OK Claude, I'm a bit lost.
If I'm understanding correctly, the floating calipers can limit traction under braking.
Wait that doesn't make sense to me either.
Do you mean the combination of the LL front end AND the floating calipers could be a bad combo?
Help me understand please.
And thank you in advance.
Eric B
'06 R12GSA/Hack & '10 R12GSA
An armed society is a polite society. Manners are good when one may have to back up his acts with his life. Robert A. Heinlein
BeeMaa is offline   Reply With Quote
Old 03-20-2012, 04:31 PM   #5
outfit
outfit's Avatar
Oddometer: 661
Look's to me as though those caliper's are floating.
My eye's are getting a bit advanced though.
Best way to minimize lift when braking is to place caliper above swingarm. Sort of like below.
outfit screwed with this post 03-20-2012 at 04:40 PM
outfit is offline   Reply With Quote
Old 03-21-2012, 03:11 AM   #6
transalpian OP
Oddometer: 306
This
Originally Posted by Bobmws View Post
... Is it something you just have to get used to? ...
and this
... It will limit traction a lot in most cases under braking and is not nearly as desirable as otherwise.
I guess I understand the advantages of floating and with unlimited funds for this project would have incorporated them into the front end. However, I don't and didn't.
If I had to do it again, I probably would go a different route (i.e. buy a completed HPS rig ). I've learned a lot though, and she is a good ride now.
Probably something I'll just need to get used to on this rig, I guess.
Old 03-21-2012, 03:29 AM   #7
transalpian OP
Oddometer: 306
Not really. When the brakes are applied, the torque generated is transferred into the horizontal element of the leading links. Since I'm talking about braking going forward, the torque is counter-clockwise (looking from the left side, like your picture). This CCW torque has to go somewhere so it is "converted" into a force couple, one "up" force behind the axle, a matching (but opposite direction) "down" force in front of the axle. These are the forces that cause the shocks to compress and the front of the bike to rise under braking.
With a floating caliper:
The torque (and resultant forces) are transferred into the vertical element of the leading links. Sure, this force is trying to bend the vertical element, but its not likely going to bend, and there is no "up" force to compress the shocks and lift the bike.
Having the caliper above or below the axle has other benefits, but the torques and forces don't know (or care) where the calipers are. the magic is the ability for the caliper mounts to rotate (float) around the axle and the strut that connects the floating caliper to the vertical leading link element.
The mounting approach you posted is sort of a hybrid. It looks like the caliper can float on the axle, but the connecting strut goes to a bit on the horizontal element. It probably has "some" lift, but I'd guess WAY less than my system.
All being said, a floating caliper has a more complex mounting system than I have. And I'm not that talented of a fabricator (yet). I'm also cheap.
Old 03-21-2012, 12:43 PM   #8
claude
Sidecar Jockey
Oddometer: 3,908
I was trying to say just the opposite of that. Floating calipers ARE best!!
Claude
Old 03-21-2012, 01:21 PM   #9
outfit
outfit's Avatar
Oddometer: 661
I am highly sceptical of this brake set-up as the torque arm is fixed to the down fork. Which I would think compromise's both braking and suspension.
I know EML et all have this arrangement so 'it must be right'. Not on my watch though.
The brake torque arm on a motorcycle equiped with a rear caliper is attached to the swingarm, where both move in tandem. I'm not seeing that on the above set-up.
Just my thought's. No offence to anyone.
Old 03-21-2012, 02:28 PM   #10
Ducatiparts.110mb
Oddometer: 43
please read more and speak less
Ducatiparts.110mb is offline   Reply With Quote
Old 03-21-2012, 03:08 PM   #11
val. h.
On the wrong planet
val. h.'s Avatar
Oddometer: 123
This is in the main a floating caliper, or it would be if the tie rod was attached to the vertical part of the forks with an articulated joint. As it is it will work in the same way as the OPs Unit forks above. IE all the braking forces are directed into the direction of the wheel. Therefore forcing the front axel down and the bike up. This causes the front tyre to loose traction much sooner than with a floating caliper, as it will lock up and start to bounce each time maximum extension of the forks is reached. Once reached the tyre will then flick back upwards into the air, momentarely leaving the ground, where it can do no good at all.
It doesn't matter where the caliper is situated. Above, behind or below, the same forces will have the same end cause.
If you look closely at the ends of the tie rod that fixes the caliper to the vertical fork leg, you will see that they are rose/rod end type joints. These allow the caliper to move up and down vertically as the axel moves up and down.
Because of this the tyre is able to continue to stay in contact with the surface of the road, soaking up any bumps or dips under braking in the same way as it would when rolloing freely. This gives the tyre much more grip under braking and it therefore much safer to use.
Which would you preffer. Braking all the time or just part of the time the leaver is pulled? Maybe a little more reasearch needed?
Val.
The land you visit may be a beautiful place with extraordinary views and heavenly skyes, but it's the people of the land that make it truly worthwhile returning time and time again.
Ay! and the roads need to be bloody good too
val. h. is offline   Reply With Quote
Old 03-21-2012, 04:25 PM   #12
outfit
outfit's Avatar
Oddometer: 661
val. h. - That Lockheed caliper set-up is mine and it is fully floating in that picture. It was fully floating for 15 yrs.
I have now made it a fixed set-up and have been running like this for 2 yrs.
I can testify that there is no difference in performance. The front end hardly rise's, the tyre stay's in contact with tarmac and breaking presure is constant, otherwise it would fail it's M.O.T.
When the caliper's were positioned below the LL swingarm I had alot of front end lift.
So yes, reasearch was indeed ventured on all front's and I feel I have the experience to speak out on my set-up.
I cannot relate to one word you've wrote. But hey, mine is only seat in the pant's experience
And as a foot note - perhap's floating caliper's are so to eleviate uneven surface pressure on the disc, much the same as floating disc's help in the prevention of warped disc's.
Old 03-21-2012, 05:02 PM   #13
BeeMaa
Hack Pilot
BeeMaa's Avatar
Oddometer: 1,098
Val.
Thanks Val.
Thanks Claude.
Eric B
Old 03-22-2012, 06:57 AM   #14
val. h.
On the wrong planet
val. h.'s Avatar
Oddometer: 123
In the picture it looks very much like the caliper is secured to the lower shock mount which in turne is mounted to the swinging arm. Is this correct, or does the picture deceive my eyes? A fully floating caliper is attached to the axel and the vertical fork leg with pivoting joints of some sort. If you then remove the shocks, to allow freedome of movement, you will find that the caliper moves vertically up and down whith the wheel. If however it is attached to the swing arm which it looks to be in your picture, then phisically the caliper can only be opperating as a fixed brake caliper would do and follow the same ark of movement as the swing arm.
Tha fact that the caliper is mounted on the axel only means it is mounted on the axel. The fact that it has then been fixed to the swing arm means that is can only move with the swing arm and not indipendently as a floating caliper should.
You are probbably correct in this point and I should have pointed out that this is more likely to affect modern braking systems. The Lockheed calipers where revolusionary in there day, however a well set up twin leading shoe worked just as well. The older bikes 'and I include my R80' just don't have powerfull enough brakes to make this an issue under normal braking. Though it does start to show at higher speeds as you mention below.
otherwise it would fail it's M.O.T. It's unlikely as the brakes aren't tested at a speed where this would show up.
Val.
Old 03-22-2012, 12:34 PM   #15
outfit
outfit's Avatar
Oddometer: 661
Struth...............your having a laugh or your not plugged in. It's okay I've a good sense of humour
What does the front wheel run on? and what is that attached to?
You've got the mechanic's of this all wrong.
Re-read your first paragraph.
I'll substitute the word float for slide (no I'll not go there).
Times are GMT -7.   It's 08:13 AM.
