03-28-2012, 06:02 PM
#61 | |
Duel
Oddometer: 2,187
__________________ "If you can't be a Professional, at least look like one." |
03-28-2012, 06:11 PM
#62 |
Oddometer: 2,472
I love it. I even love the colors of that Gold Wing (finally, a color pattern that makes me want to own one).
But at $259 for that set-up, um... I'd do it in a heartbeat if I could afford that Wing
"After reading through this thread I've come to the conclusion that more people cruise the internet looking for reasons why X bike won't work in Y scenario rather than actually riding their motorcycles." -- RyanR |
11-12-2012, 01:43 PM
#63 |
Oddometer: 411
![]() I saw this on on my tire the other day. Note the tire manufacturer (Avon) states that said max pressure is for testing purposes only. Fwiw, I run this 17" front at 15-18 off road and 24 psi on the road. My owners manual says 1.5 bar or ~21-22psi. |
11-12-2012, 02:14 PM
#64 |
Oddometer: 481
The tire sidewall in the pic does give the max pressure for that tire. It is the minimum pressure required to carry the max load that tire can carry, according to the Federal Motor Vehicle Safety Standard 119.
http://www.gpo.gov/fdsys/pkg/CFR-199...-119-id524.xml Here's Avon's inflation pressure recommendations: http://www.avonmoto.com/tech/tire-pressure-guidelines Here's Metzeler's blurb: " ...Over inflation or extreme tire pressure will impair your riding comfort and decrease the size of the contact patch of the tire with the road....You will find the correct pressure in the operating manual of the motorcycle." http://www.metzeler.com/site/us/tech...intenance.html James Davis writes some very good, very important stuff, then he writes some stuff that is just goofy. As others have said, try to reason with him at your own peril.
It's not what you look at that matters, it's what you see. Henry David Thoreau |
11-12-2012, 02:52 PM
#65 | |
Just Beastly
Oddometer: 6,478
Public Service Announcement - the above response is accurate, but fueled by Vodka. Barry
Tail of the Dragon at Deal's Gap... Avoid it now, do a trackday. Do not do business with Myrtle West Cycle... Not a reputable vendor by a long shot. |
11-12-2012, 07:29 PM
#66 |
Oddometer: 2,472
Well, anyway, I run my DR650 at speeds most DR650's don't ever see because I live next to a major highway where average speeds are pretty damned (illegally) high, and since I believe in at least going the speed of most traffic...
I run my dual sport tires much higher than Suzuki recommended (for whatever crappy tire came with the DR650's back in 2002), and I've found that doing so stabilizes the bike better at speed. I learned the hard way that when I was comuting over 20k a year on motorcycles that they stayed cooler (despite the hotter south FL summer weather and hot pavements) and lasted longer at higher pressures. I can always easily find some way to "air down" if I'm going to take it on sand and whatnot, but I run all my moto tires above the original bike manufacturers' recommended stats because of the highway use the bikes see. I've read a number of posts in this thread, and I'm glad to see others that agree with me. This all goes back to those same types of people who wouldn't run fully synthetic on bikes that didn't come with it, or riders who wouldn't run a 'dark side' tire on the rear... some people are just too afraid of deviating from original specs to best suit their needs and purposes. |
11-12-2012, 07:44 PM
#67 |
Oddometer: 1,376
11-12-2012, 08:04 PM
#68 |
Oddometer: 858
There are at least 15 different opinions on tire pressures in this thread, and probably 17 of them are wrong. 10% this and that. Max load. Off road pressures. Passengers.
Go with what the manufacturers say, not some goobers on a forum.
Ducati S4 916 is history. KTM 950 SM, my main squeeze now. 1970 CT-70 And now, an XR75, |
11-12-2012, 09:30 PM
#69 | |
Oddometer: 2,472
As if either know just where and how each of us are using their tires / bikes... Part of all of this is educating (or people looking to educate themselves), and the rest of it is applying that which you've learned. It needs to be out there, and needs to be discussed. |
11-12-2012, 10:07 PM
#70 | |
Oddometer: 17,983
![]() The 10% change between cold and hot IS what the manufacturers say.
"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind." — Dr. Seuss “Watch out for everything bigger than you, they have the "right of weight" Bib |
11-12-2012, 10:32 PM
#71 | |
Oddometer: 56
![]() ![]() ![]() finally some truth ! every oumce\degree or angle you ride that is different than the model weight\degree\ounce that they tested that tire on will produce a different tire life and ride than what they use as a standard rule. Just as sure as one rider may get 50 mpg the next may get 35 mpg so dont let blanket statements keep all you bad ass motherfuckers up at night! Dont get me wrong I dont think everyone on this site is a Bad ass! thats just another blanket statement to make you all feel well and sway the opinion of others to realize that most of the people here can ride the hell out of a keyboard. Bah ha ha ha wa ha ! Good night everyone
11-12-2012, 11:40 PM
#72 | |
Oddometer: 858
Not when it's conflicting bullshit. Could get somebody killed.
11-13-2012, 02:55 AM
#73 |
To old to fall off
Oddometer: 23
this is like an oil thread
i have ridden my klr 15 k My 240 lb. butt and lots of gear, Shinko 705s @ 38-42 psi. they stick good, turn in well and last 5 k rear 15 k front. tryed 32 psi front and tire started to cup.
Off road ? Bikes to heavy I dont do sand or mud. On road had a ball @ the dragon, Blue ridge parkway and such. |
11-13-2012, 03:10 AM
#74 |
Booze Merchant
Oddometer: 543
My Daily ride ( an old 250 Honda AX) has tyres that recommend 32psi.
I usually run 25psi. It's an on road bike nowdays. I check the pressure every two weeks. Today the front and rear were both down to 10psi! Offroad, on my EXC or DR I run 10-15psi rear and 5-10psi front.
CambodiaYeah! |
11-13-2012, 03:18 AM
#75 |
Oddometer: 246
I think the engineers who developed my bike and tires are more competent than me (at least in their fields) or someone in the internet and have their reasons to concordantly recommend 2,5bar (36psi) front / 2,9bar (42psi) rear pressure. So I stay with that instead of experimenting what lower pressure might be better on my 280kg street bike at speeds from 30mph at bumpy backroads up to 155mph at highways in one trip.
In addition, for the occurrence of slightly loosing air over time, it's better to start at the upper end of the save pressure window.
Into the dark side of our nature to look we all need. The energy, the passion there is. Afraid of that people are. Pieces of us it holds busy denying we are. |
