11-13-2012, 04:17 AM
#76 | |
Oddometer: 4,678
Pretty much all of the tire makers say the same thing, for STREET use follow the bike maker's recommendation for pressure i.e. it doesn't matter. For track use they are much more specific, and it varies wildly for example the recommended cold pressures on my Diablo Rosso Corsas is 26f/28r 29/31 hot Dunlop Q2s want significantly higher pressure at ~32 front and rear as a start, guess what the teller is......10% Now would I run max PSI settings? I certainly have, I used to run 35,000+ miles a year on roads that had surface temperatures in the 160* range, so yeah, I didn't want any excess heat for commuting. I'd just air them down when I went anywhere with a corner. I've also set the tire pressures high as hell because I was running two up on a loaded down 850lbs bike and a little napkin math said that I was going to be pretty close to the load rating. |
11-13-2012, 04:22 AM
#77 |
Fat Drunk & Lazy ADV
Oddometer: 1,566
Handling
Air your tires to get the desired handling depending on terrain and load. too squirrelly on road? air them up. too squirrelly off road? air them down.
it's your bike, it's your ride, and your bike, load and ride are different than everyone else's, so adjust your pressure accordingly. |
11-13-2012, 04:47 AM
#78 |
Oddometer: 4,315
I run 41R/35F on the Tuono all the time. There's no need to run track day pressures riding to work or even on strafing runs on my favorite mountain roads. If I need the extra grip slowing down is a good idea.
When injustice becomes law,resistance becomes duty. Thomas Jefferson |
11-13-2012, 05:01 AM
#79 |
Oddometer: 596
Motoghost in Phoenix, my favorite BMW mechanical shop recommends running ROAD tires at 2psi less than the max load pressure on the tire, especially in Summer. They have several tires in their showroom that have failed due to excessive heat caused by running too low pressure along with a chart indicating how much hotter your tires run AT SPEED, with increments of only 2 pounds less pressure. The Phoenix Police Dept. runs their moto tires at Maximum pressure. I know this is not a universally popular practice, but I will continue to follow it. A tire that is being run AT SPEED, let's say 70-90 mph for extended periods and which is 7-10 psi under inflated, will eventually reach nearly the same temperature as when it comes out of the mold.....especially when the ambient temp is 100 degrees plus and the road surface is quite a bit hotter. I think motorcycle tires are one of the least understood and most neglected parts of a bike by many riders.
11-13-2012, 06:24 AM
#80 | |
Oddometer: 627
I gotz an FJR which I run 43R/41F on PRIIs, and I have enough grip ta get ta the edge of the tires, & drag pegs. I run the same size tires/rims on mah little FZ6 dirtbike, butt I run much lower pressures 36R/34F (And I'm still experimenting) cuz the bike weighs much less. I do run higher pressures (I'm gonna die!!!!) than most to get better tire life, 'n it actually makes the big pig feel "lighter.". It all depends on the bike, the weight, the power, the kind of tires, the rider, the roads, 2 up w/ gear; common sense goes a long way with this shit. Don't listen ta anythang "track guys" do, (Unless yer ride'in on the track) cuz the street is a whole 'nother world. The roads 'round here are much shitier than the tracks 'round here.
2007 FJR1300 2007 FZ6 (Dirt bike) |
11-13-2012, 09:34 AM
#81 |
Oddometer: 367
Inspired by this thread, I checked the rubber on my Yam 900 Diversion - Bridgestone Battlax BT021s. The rear says that maximum load is (x) lb at 42psi, which ties in with what has been noted here previously; that what is stated in this way is not the maximum pressure the tyre will take, but the pressure at which it can support its maximum load - presumably at up to its maximum rated speed.
Since the pressure in the rear tyre after a period of high-speed riding will be around 10percent higher than 42psi, this cannot be its maximum pressure rating. FWIW, cycle tyres have a max. pressure rating moulded on the sidewall, but that's 'cos a narrow clincher inflated to 160psi might either blow clean off the rim or, if the rim is worn, break the rim by cracking the sidewalls away at the braking surface. It is invariably way higher than the highest recommended riding pressure. I run 36/42 on the Diversion in all circumstances. The manual says this is right for for two-up and high-speed riding and says 33/36 otherwise but, since I never know when I might venture onto a fast stretch of road, I prefer to stick with 36/42 day-to-day. In any case, there's enough grip in the dry to scrape the footpeg hero blobs and reach the edge of the rear tyre tread. Also, the higher pressure reduces the bike's tendency to self-steer in road depressions. For solo riding I have tried 33/36 and 37/43 pressures and even some in between; why not experiment a bit to find the exact pressure that suits? Off-road? Yup, I air-down, albeit not as much as some suggest here but that's 'cos I hate the idea of a pinch flat. Still makes a big difference to grip. |
11-13-2012, 10:03 AM
#82 | ||
Oddometer: 795
![]() no, the tire does NOT give the max pressure, it give max load rating and the pressure that is necessary to acheive max load but nowhere does it say that its also max air pressure nor does the federal regulation require or say anything about max air pressure, only max load and the corresponding pressure that supports max load Quote:
RandyO IBA # 9560 07 VeeStrom 99 SV650 82 XV920R A man with a gun is a citizen A man without a gun is a subject |
