03-21-2012, 08:55 PM
#1 |
Oddometer: 35
I've got an M49 sherpa T that came with rigid footpegs and I'd like to change them to a set of standard folding style pegs. I've found a set from Sammy Miller that come complete with the brackets to weld on that I'll likely use. I have read on different threads that some have lowered pegs and some have raised them. What may be the main considerations when deciding on a new location for the pegs. I'm only 5'8'' so stock height seems comfortable to me, I'm also a new trials rider so I won't be attempting anything too trick for a while!
Jay 2004 Beta Rev 3, 1972 Bultaco Sherpa T 250, 00' Kawasaki Super Sherpa 250 (Wife's) |
03-21-2012, 10:23 PM
#2 |
Oddometer: 993
Lower the pegs as much as you can, but avoid moving them back, as this will take weight of the front wheel and reduce front wheel traction.
03-22-2012, 07:11 AM
#3 |
Oddometer: 35
Is the idea of lowering the pegs only to keep the centre of gravity low as possible?
03-22-2012, 08:23 AM
#4 | |
Location: Summer: Kemiö, Finland; Winter: North Germany
Oddometer: 641
Anyway as you haven't posted a photo of your model 49, when I remember right, the footbrake lever is situated below the footpeg and also the gear lever shaft is situated to the standard footpeg position. so you can't go too low with your peg without doing changes to the levers too. In my experience the Sherpa is very heavy in the front, I believe you have recognized this too, expecially when you want to lift up the front end up for climbing over obstacels, steps, ... on the other hand the bike has a good directional stability but turning thight is often easier on other bikes, (Yamaha / Fantic, ...). The front wheel likes to push when turning thight and using some throttle. My first Bultaco a Sherpa m221 had this behavior, (a 175cc with the frame of the m190). I now have a m199b where Bultaco has changed the footpeg position to the predecessors, now beeing situated lower and a little more back. The m119b has the same "turning" behavior but it's lighter to lift the front end, which I see as an advance as you don't need so much physical strength to ride the bike in modulated sections with steps and obstacels. Any disadvantege in turning I haven't experienced, but I believe I do put more body weight to the front when doing thight turns, (which doesn't work uphills i know), compared to my SWM, (where thight turns for me are easier). A good way to figure out your footrest position as the area to mount is limited might be the way it's installed here: http://www.twnclub.ch/classic_trial_...stauration.htm With the additional plate you can change the position once again if you don't feel comfortable with it. |
03-22-2012, 08:21 PM
#5 | |
Buffoonery, Inc.
Oddometer: 2,273
Work hard. Play hard. Team Dead End. The drinking team with a Trials problem. ![]() 2-Time winner of the coveted "Best Shenanigans" award at Capt. Rick's annual BBQ. brewtus screwed with this post 03-23-2012 at 07:59 PM Reason: Turning my back. I'm done. |
03-22-2012, 08:26 PM
#6 | |
Oddometer: 35
03-22-2012, 08:38 PM
#7 |
Oddometer: 35
Ooops, have to figure out how to link images...
03-22-2012, 09:15 PM
#8 |
Oddometer: 35
03-22-2012, 11:38 PM
#9 |
Oddometer: 993
Looks like MX type footrest position on that, so you will need to fabricate a mounting to move the footrests properly.
03-23-2012, 06:42 AM
#10 |
Buffoonery, Inc.
Oddometer: 2,273
Work hard. Play hard. Team Dead End. The drinking team with a Trials problem. ![]() 2-Time winner of the coveted "Best Shenanigans" award at Capt. Rick's annual BBQ. |
03-23-2012, 07:27 AM
#11 |
LDA
Oddometer: 179
I have the same bike. That is the stock early footpeg mount for the Model 49. I have been trying to find the later folding pegs and mount without luck. The Model 49's that I have seen ridden today have the pegs lowered by 1 1/2 inches and moved back about an inch.
03-23-2012, 12:35 PM
#12 | |
Oddometer: 35
03-23-2012, 12:43 PM
#13 |
Oddometer: 993
If you can find some tube same OD as the frame tube which connects to the swinging arm pivot, then its easy to fabricate a nice triangle shaped footrest mount out of 2 pieces of tube. By the look of your bike I would say move the rests back about 3 inches behind the swinging arm pivot, with the bottom edge of the footrest mounting brackets level with the bottom of the lower frame tubes. You will also find its a big improvement to get rid of the "tiller" type top yoke, as moving the bars ahead of the steering axis will mean much better steering, and improved feel.
03-23-2012, 02:40 PM
#14 | |
LDA
Oddometer: 179
Rockcat screwed with this post 03-23-2012 at 02:46 PM |
03-25-2012, 11:28 PM
#15 |
Oddometer: 35
[QUOTE=gvadney;18288199]After I fix the pegs, I was planning on getting an Electrex World ignition for it. I have a NOS Amal on it, but I'm sure a Mikuni would be an improvement. My tank has been resealed, but still weeps. Ethanol and age is taking its toll on the fiberglass. I want to keep it as close to original as I can./QUOTE]
What did you use to reseal the tank, I was planning to use some caswells that has been recommended to me. I put the mikuni on because the original amal just would not work anymore.. Your sherpa looks great, I got mine from my dad and he competed on it in the mid 70s in ontario and NY, I had such a great time riding it last year once I got it running properly that I'm hooked!
