Old 01-28-2013, 12:15 PM   #106
Ivanych
Ivanych
Ivanych's Avatar
Oddometer: 239
Oh, I had the same problem with my tank, the lower CRF450 clamp hit a the tank.
Here is my solution:
first test CRF450 forks (before welding)
Ivanych screwed with this post 01-28-2013 at 12:33 PM
Ivanych is offline   Reply With Quote
Old 01-29-2013, 07:32 AM   #107
Bluffskier
Bluffskier's Avatar
Oddometer: 176
Wow! I had not even thought of that for stops! Thanks for sharing. Such pretty welds, mine tend to look like wasp nests. hahaha.
2002 onward forks it will be then, especially if it will allow for the use of more of my OEM XRL parts. I may look into some '05 CR forks since the axle was supposed to be farther back, but I will have to look into caliper compatibility more.
I sent RSW racing an email, but I'm supposed to call him, about making a top triple clamp that combines the CRF fork dimensions with the ignition hole of the XRL. I mean they make both brackets, one the the CRF and XRL, so I bet they could combine them and it would be a hit since alot of people seem to be doing this swap and many people, including myself, are saying "what about the steering lock, ignition, ect." This would be huge for the Super Moto folks too.
Bluffskier is offline   Reply With Quote
Old 01-29-2013, 07:51 AM   #108
mcma111
mcma111's Avatar
Oddometer: 12,088
XR650l CRF top triple clamp.
You mean like this one?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-29-2013, 08:54 AM   #109
elsalvadorklr OP
southern xr rider
Oddometer: 4,154
bluriness included?
elsalvadorklr is offline   Reply With Quote
Old 01-29-2013, 09:42 AM   #110
Ivanych
Ivanych
Ivanych's Avatar
Oddometer: 239
Steve,
Can I change the trail of these clips?
Are there options to change the trail?
I'm an amateur in welding.
Welding was carried out very slowly (short seams and big breaks) I was afraid of warping (changes shape) space for the bearing. Big wet rag was in place for the bearing. All wasp holes patched now.
Old 01-29-2013, 11:06 AM   #111
mcma111
mcma111's Avatar
Oddometer: 12,088
Christian,
Blurryness due to prior camera. Notice all of the latest pictures are good. Nikon baby.
Don't know about changing the trail. I would imagine RSW is copying the OE specs.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-29-2013, 02:33 PM   #112
Bluffskier
Bluffskier's Avatar
Oddometer: 176
Those XR650l CRF top triple clamps are nice.
Where do they come from?
Do you happen to know the offset? or the trail?
Oh yea, do they take the OEM XRL stem?
Old 01-29-2013, 02:39 PM   #113
mcma111
mcma111's Avatar
Oddometer: 12,088
http://www.rswracing.com/xr650l.htm
The web site doesn't show them but he has 'em.
Don't know the spec's.
Yes, the OE stem goes right on.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-10-2013, 07:57 PM   #114
Bluffskier
Bluffskier's Avatar
Oddometer: 176
Looks like I will be able to pull the trigger in a month or so as the tax return comes, but this will just be the first leg, or just the forks will be purchased, maybe more depending on what I can find for the price.
Valentines Day has found my wife a new Pandora Charm and me a complete Pro Link from an '88 XR600 ($37 shipped!!), to replace the Devol lowering link and give me all the original zerk fittings that went away over time. I must say the higher seat feels much better and handling at 70-75mph is unaltered. Besides the higher rear will help level the bike once I do go with the USD's.
Old 02-11-2013, 08:10 AM   #115
elsalvadorklr OP
southern xr rider
Oddometer: 4,154
hey bluff congrats...just play around with the forks when you get them to get correct sag and trail and all...just go up and down with the tubes in the clamps and see what works best for slow going and again for high speed...
mine are solid as hell no wobble or nothing from 1 to 99mph! jajajaj 97actually...
BUT again my xrl shock is rebuilt and revalved...si Im not compensating for anything out back
cheers
Old 02-11-2013, 08:12 AM   #116
elsalvadorklr OP
southern xr rider
Oddometer: 4,154
IVANYCH
I would like to see how you end up with your forks and oil cooler
I was under the impression that the xr400 cooler would hit the tubes when using usds on the xr600
thanks in advance!
christian
Old 02-11-2013, 01:00 PM   #117
Ivanych
Ivanych
Ivanych's Avatar
Oddometer: 239
Originally Posted by elsalvadorklr View Post
IVANYCH
thanks in advance!
christian
OK, Christian!
I will do a special photo shoot for you.
I have almost all the necessary parts to build my bike, and I'm waiting the warmth for a large assembly.
There are several ideas who flee in front of my opportunities.
these is ideas affect the work, but they are interesting.
Cheers!!!!!!!!!!!!
Old 02-12-2013, 11:16 AM   #118
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 823
Anyone know if they beefed up the steering stops? I recall someone had one snap off.
Cheers,
Cumbacheech
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 02-12-2013, 01:12 PM   #119
mcma111
mcma111's Avatar
Oddometer: 12,088
IIRC the person drilled and tapped the stops to install a limit bolt because the forks were hitting the tank. I don't know if the stops have been changed. .
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-12-2013, 01:44 PM   #120
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,492
As of last month , they were the same as before .
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is offline   Reply With Quote
Times are GMT -7.   It's 09:57 PM.
