Old 03-22-2012, 04:10 PM   #1
P B G OP
Oddometer: 10,001
Structural Engineering 101 - How to hang my air compressor.
I want to suspend this:
Next to this:
How would one go about ensuring that it is "within" the load limits of the structure...
Old 03-22-2012, 04:14 PM   #2
deejay_xr
deejay_xr's Avatar
Oddometer: 496
By not risking it? ...
Calculating that would be a real challenge, trust me.
Just by eyeballing it, I wouldn't do it personally.
Do you have a ballpark on what that thing weighs?
deejay_xr is offline   Reply With Quote
Old 03-22-2012, 04:14 PM   #3
P B G OP
Oddometer: 10,001
~1100 lbs.
I'm assuming by being unitstrut products that someone knows how to rate those things.
Atleast in my view point it is largely 4 all thread rods suspending two unistrut rails, ancillary to that are the vibration reduction components, and anchors into the concrete which I view to be more positioning related than weight suspension.
In terms of roof joists of that style, it is unclear.... It is of course right next to the concrete block structure of an interior wall.
Old 03-22-2012, 04:16 PM   #4
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,270
i have one about that size - 2 stage 7.5hp 80 gallon. every bit of 700+lbs just loading it into a truck is a chore.
current bikes
stainlesscycle is offline   Reply With Quote
Old 03-22-2012, 04:18 PM   #5
P B G OP
Oddometer: 10,001
Also I am not against augmenting the structure by going next to it to the right.
Old 03-22-2012, 04:22 PM   #6
deejay_xr
deejay_xr's Avatar
Oddometer: 496
The strut could maybe still take the extra compressor, I would be more concerned about the struts mount to the roof structure
Old 03-22-2012, 04:26 PM   #7
P B G OP
Oddometer: 10,001
This is a bit more than that.
Its a 10 HP 3 Phase on a 120 Gallon Tank.And being from the 60's it is not wimpy in the castings department. The one from the ceiling is more in that rhelm and is a single phase 220.
Old 03-22-2012, 04:27 PM   #8
P B G OP
Oddometer: 10,001
Good feedback, I will get to clambering up and taking a peak at that hardware.
Old 03-22-2012, 04:29 PM   #9
morerpmfred
morerpmfred's Avatar
Oddometer: 139
Looks like the strut is attached to another bar stock resting above the steel joist between the q decking. The steel joist is sitting on top a steel i beam. So i would just mount it the same way as the other tank but one joist over.
morerpmfred is offline   Reply With Quote
Old 03-22-2012, 05:11 PM   #10
stainlesscycle
Oddometer: 2,270
gotta love the old equip - mine's a mid 60's speedaire - 3ph - rebuilt the head about 10 years ago - still chugging along.
current bikes
Old 03-22-2012, 05:49 PM   #11
ttpete
Rectum Non Bustibus
Oddometer: 5,973
I'd hang the big compressor closest to the wall and use a piece of channel through bolted to the wall for the stringers to rest on. The stringers really need to be heavier channel iron as well. The roof trusses and threaded rod kind of bother me, though. If the truss is made up of pairs of angle iron with the diagonals welded between them and the suspension rods also run between them with a nut and washer on top, there is a chance that it could spread or the washer deform under load and fail. In any case, it would be a good idea to have a civil engineer or journeyman millwright look it over first.
What about supporting it in a corner using the two walls and using an I-beam column to the floor on the one unsupported corner? It would be a lot more rigid.
How do you envision servicing the units? You'll have to install automatic drain valves and pipe the discharge somewhere. My experience is that overhead units like that get neglected because they're so difficult to access.
15 BMW RnineT
09 Kaw Versys
Old 03-22-2012, 06:04 PM   #12
P B G OP
Oddometer: 10,001
Originally Posted by ttpete View Post
I'How do you envision servicing the units? You'll have to install automatic drain valves and pipe the discharge somewhere. My experience is that overhead units like that get neglected because they're so difficult to access.
By climbing up my fork lift....
Actually the one that is up there has a remote drain for the tank. I would tie the new compressor directly into the old compressor with T fittings.
That way both will "share" volume, and both with share a drain, and both will plumb into the shop air distribution.
The current unit is actually not hung on all thread w/ a washer between the angle irons, it is hung on "clamps" the type that unistrut sells to grab hold on things.
I'm thinking of going below the other unit. I have the overhead room.
I can support the current unit on my fork lift, then swap the current all thread ~3/8" with heavier 1/2" acme rod. Suspend another layer directly below the current.
And yes knowing engineering history the allthread would be joined with a coupler and lock nuts not adjacent holes.
Swap the current "clamps" with a lock nut over a steel plate,
The owner to the north has no problem with me punching a hole through the cinderblock, so I can compress an angle iron to that wall. The wall to the right is cinder w/ cosmetic brick, so going through that wall is harder, it is quite thick.
I can carry the heavier/lower compressor on unistruts doubled back to back and bolted together. Which should be overbuilt. Or perhaps just heavy U channel steel.
Old 03-22-2012, 06:16 PM   #13
boardrider247
Weekend Anarchist
boardrider247's Avatar
Oddometer: 736
I don't have my book in front of me, but from memory 1/2" all thread rod is good for about 1100 lbs.
I think what you have there will hold both compressors.
That being said I wouldn't do it. I would replace the strut with channel iron. And check to make sure what type of anchors are in that block wall. If it's a poured wall and they are drop-ins your good to go. If it is just toggles bolted to the block I would change those out. And use square washers on the top of the rods connecting it to the joists if possible.
boardrider247 is offline   Reply With Quote
Old 03-22-2012, 06:19 PM   #14
P B G OP
Oddometer: 10,001
Its stacked cinder block.
Old 03-22-2012, 06:26 PM   #15
boardrider247
Weekend Anarchist
Oddometer: 736
I have a strut catalog in my desk at work. I'll try to remember to bring it home with me tomorrow.
Feel free to shoot me a PM with anything you want me to look up for you. I think there are load limits listed in there.
Times are GMT -7.   It's 02:40 AM.
