Old 03-24-2012, 10:07 AM   #1
GreatWhiteNorth OP
GreatWhiteNorth's Avatar
Oddometer: 2,209
Steering damper setup for KLR650 rig?
Anyone care to show pics of how they setup their steering dampers (if you use one)?
I'm enjoying the heck out of my KLR with DMC Enduro sidecar, but really notice the front end shakes easy. I already have a steering damper that came with the sidecar on my Goldwing which I intend to use... just want to see how others have situated theirs.
Interesting - just took a caliper to measure fork leg diameter... at the upper fat area (of the lower fork leg) where the seal is installed (and I have an Eagle Mike fork brace fitted) the diameter is 58 mm. Lower down the leg the diameter is 48-50 mm - not round... over much of the leg. Easy to see the legs are cast and not finish machined in the lower area, but I'm surprised to see a 2 mm ovalization. Kind of makes it more challenging to find a clamp that'll fit!
GreatWhiteNorth screwed with this post 03-24-2012 at 10:50 AM
GreatWhiteNorth is offline   Reply With Quote
Old 03-24-2012, 04:50 PM   #2
Wolfgang55
Wolfgang55's Avatar
Oddometer: 3,462
Have seen shims as in thin strips of aluminum. Others have used aluminum foil, when there is nearly no room.
I use to own a KLR.
Wolfgang55 is offline   Reply With Quote
Old 03-24-2012, 08:20 PM   #3
NortwestRider
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 3,957
Here's a couple pics of the ways I have mounted my dampner on my 2 bikes.Maybe they might give you some ideas.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
GS500ADV..THE PURPLE EXPLORE
[B
NortwestRider is offline   Reply With Quote
Old 03-24-2012, 08:35 PM   #4
sandsman
sandsman's Avatar
Oddometer: 532
May this will help some, maybe not
I had to use some 1" by 1/8" aluminum to shim up my fork clamp, I had to hammer it to shape. Worked great. My steering damper came off of a goldwing too, I had to fab up a mount for the car. I made it out of 2X2 angle, Here are a couple of pics, maybe it will help.
You can see the shims in this pic.
Sorry for the fuzzy pic, but you get the idea.
IBA # 59807
The Sandsman cometh and so he goeth too.......
Don’t pick a fight with an old man. If he is too old to fight, he’ll just shoot you.
I got a real good feeling something bad is about to happen,
sandsman is offline   Reply With Quote
Old 03-25-2012, 12:26 AM   #5
GreatWhiteNorth OP
Oddometer: 2,209
Thnx guys!
Appreciate the pics... keep 'em coming. Interesting the head shake issue. Steering is much lighter (understandably) on the KLR than the Goldwing, but it's much more prone to the shakes.
Times are GMT -7.   It's 02:34 PM.
