05-17-2012, 09:40 AM
#31 |
Oddometer: 216
I can appreciate not wanting to limit articulation on a truck that gets used for serious off-roading. My truck is a 2wd Mazda b2300. Long before I achieved maximum articulation, my truck would be stuck or spinning wheels (open diff.
)!With the camper on, The only time it would achieve maximum articulation is about one second before it rolled over on its side!
05-17-2012, 11:54 AM
#32 |
Leghumper Emeritus
Oddometer: 4,942
I like this a lot.
Brad Felmey-izing threads everywhere |
05-17-2012, 12:34 PM
#33 |
Oddometer: 216
Stretch67, That's what my rig will be like when it grows up
05-18-2012, 09:19 AM
#34 | |
Painting by numbers
Oddometer: 5,387
or ? I don't know...
-Chris '04 GS Adv- A fond memory '07 990 Adventure- still bonding... How hard can it be? - Jeremy Clarkson |
05-18-2012, 09:28 AM
#35 |
Painting by numbers
Oddometer: 5,387
http://carlisuspension.blogspot.com/...xpedition.html
Apparently, they work pretty well on a Power Wagon, but at $850 I'd have to be real sure I needed them. Retired and traveling the world in a POWER WAGON?! Two things come to mind:1. This guy must have one heluva retirement nest egg. 2. No wonder gas prices are so high.
06-20-2012, 07:16 AM
#36 |
koolaidless
Oddometer: 1,903
I LOVE my truck camper.
Been there, broke that SFS |
07-01-2012, 12:28 PM
#37 |
Heavy Metal
Oddometer: 732
I quite fancy a Conqueror.
Sent from my binary data processing apparatus using magic and wires OLD SKOOL HEAVY METAL |
07-06-2012, 07:08 AM
#38 |
koolaidless
Oddometer: 1,903
Here is a picture of my AF on the ford with the boat hooked up.....
07-07-2012, 04:55 PM
#39 |
Supercàzzola
Oddometer: 1,798
what kind of weight are we talking about here? I have Super Duty F350 DRW but I've heard that even the ton trucks are overloaded with the largest slide-ins.
07-07-2012, 07:13 PM
#40 | |
koolaidless
Oddometer: 1,903
the picture of the camper on the dodge......dodge is a 3/4 with air bags. Hauls the same load pretty well, but not as good as the ford. I have been hauling truck campers for many years. My best truck for it was a crew cab f350, 2wd dually..........that truck really handled well........if your truck is a dually......i assume that is what "DRW" meant...........you should be able to haul a pretty good sized camper.
07-07-2012, 07:35 PM
#41 |
Supercàzzola
Oddometer: 1,798
yes, it's a dually. Thanks for the info. What does the AF do to your mileage? I assume your 350 has the 7.3 as does mine. I wish it had a Cummins instead though
07-08-2012, 05:42 AM
#42 | |
koolaidless
Oddometer: 1,903
Hauling the AF and boat on the ford.............10 to 11...................... In the dodge, I get about 10 pulling the toyhauler and 13 to 14, with the AF and boat............. the ford has an auto and 7.3 with chip, down pipe and gauges............ the dodge has 5 spd, cummins and is bone stock............
07-09-2012, 07:48 AM
#43 | |
Oddometer: 519
07-09-2012, 09:41 AM
#44 |
Oddometer: 4,019
I get the cool factor of the truck camper. I've always had an itch for one. Seems though, like their niche is for getting off the beaten path with as much luxury as possible.
If you goal is to park it while you work in places, seems like a light / short travel trailer would give more available space, more cheaply. Something in a 4k lb 21ft bumper pull travel trailer is going to be easy to find, and inexpensive used. Much easier to unhitch and drop off too.
2002 KLR650 - 2007 HD Electra Glide 'It doesn't matter how big a ranch ya' own, or how many cows ya' brand,the size of your funeral is still gonna depend on the weather.' Harry Truman "Death smiles upon us all, a U.S. Marine smiles back" |
07-09-2012, 05:11 PM
#45 | |
Oddometer: 519
"What am I going to use it for and where am I going to take it?" Every option is a niche with ups and downs. If I was never going off pavement and was going to be in one spot for a while, some sort of trailer would be the go. Once you start getting off the beaten track, trailers are a bad idea. I know there are lots of people that will say otherwise, but I have seen and experienced to many failures for me to go that way. Campers on the back of utes (pick ups for you 'mericans) seem to have evolved a bit. They are easier to get on and off the vehicle meaning you don't have to take your house with you for a quick trip to the shops or sight seeing, etc. I can certainly see the appeal. |
| Thread Tools | |
