Old 03-30-2012, 12:36 PM   #16
dougfromindy
I smell premix
dougfromindy's Avatar
Oddometer: 2,282
great bikes
I have 2 projects, one in garage, one on patio
If someone wants to rescue these poor bikes I probably would sell both plus a bunch of parts for around $888. Pickup Indpls, IN.
I rode a museum quality one (now sold) and it went over 100mph with more to spare with my 275# phat ass riding it.
dougfromindy is offline   Reply With Quote
Old 04-01-2012, 06:05 AM   #17
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,001
This is what you wanted to trade for my NX125? Douglas!
That said, one of the p.o. chopped my rear fender (behind the license plate bracket). Any chance you have a spare you'd part with?
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 04-02-2012, 06:51 PM   #18
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,001
Need some help
Rode the VTR to work this morning. No problems. Turned off the bike and locked the steering head. Came out after work and have no power. No dash lights, no headlight, no horn, no starter, nothing. It's like the bike has no battery in it.
I had my wife come get me and got the trailer and brought it home. Battery shows about 9.4 volts. I hooked it up to the Battery Tender.
I rode it over the weekend; had no issues starting it up. WTF?
An ideas what else to check?
Old 04-02-2012, 06:54 PM   #19
jas67 OP
Oddometer: 879
Charge it, and see if it starts. With voltage that low, sounds like a shorted cell. Sometimes, it just happens.
Duc M796 & 250 Monza, Guzzi V7R & Breva 1100, BMW F650GS Dakar, R100R Mystic, R100S, R75/5, 01 Honda VFR800, 76 CB400F, 68 CL175, Vespa GTS250.
jas67 is offline   Reply With Quote
Old 04-02-2012, 10:55 PM   #20
squish
Out of the office.
Oddometer: 6,318
Double check the ignition switch iirc on mine you could go past the lock position and into park which turned on the tail lights.
On vacation for a spell
squish is offline   Reply With Quote
Old 04-03-2012, 06:19 AM   #21
showkey
Oddometer: 1,962
Better yet charge it, test the battery (load test) then start it and check the bike charging system output.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Old 04-03-2012, 06:30 AM   #22
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,001
Thanks everyone (especially you, Bob).
I still am not sure what the problem is/was although I'm starting to suspect the battery. I checked all of the fuses (both the 30A main as well as all of them up by the ignition switch). They're all good. When I got it home (via trailer), the battery showed 9.4 volts. I hooked it up to the Battery Tender Jr. I have. It was still charging this morning (but I did not check the volts). When I turn the key, this morning, I do get lights but I did not try to start it (I would assume it will start at this point).
I'm thinking the battery may be no good. I have asked the p.o. if he knows the age of the battery (it has screw caps for each cell and I can see the electrolyte level [it's full] thru the translucent case).
Can I do a load test at home or is there special equipment for that? For instance, I could take it to the local Auto Zone and have them load test it.
Old 04-03-2012, 06:31 AM   #23
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,001
Are you thinking I did this, by mistake, and left the tail light on all day? Hmmm.
EDIT: In retrospect, I would imagine that this is exactly what I did.
Bronco638 screwed with this post 04-03-2012 at 10:58 AM
Old 04-03-2012, 06:46 AM   #24
Jon_Garfio
Jon_Garfio's Avatar
Oddometer: 76
Nice the VTR250, last friday I bought a VTR250 for my wife. A lot of fun!!!
Jon_Garfio is online now   Reply With Quote
Old 04-03-2012, 10:58 AM   #25
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,001
Sadly, we don't get that version of the VTR here in the US.
Old 04-03-2012, 11:34 AM   #26
Jon_Garfio
Jon_Garfio's Avatar
Oddometer: 76
it is the last unit that Honda brings to Spain because nobody wants to buy it.... people says that this motorbike is than expensive than a 600cc second hand.
Old 04-03-2012, 01:26 PM   #27
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,001
Geez, I've read a lot of good things about it. However, if it's expensive, I can understand why no one would want to buy one. That's a shame, it's certainly nice looking. I hope your wife enjoys it.
Old 04-04-2012, 07:23 AM   #28
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,001
Update
OK, I got home yesterday and the battery was fully charged courtesy of the Tender Jr (it took about 20 hours). I must have left the ignition switch in the Park position (as opposed to the Lock position). I did experiment with the ignition switch positions so I won't repeat that again.
I'm still wondering why a battery with 9.4 volts wouldn't activate the dash lights or the horn. I can understand not being able to engage the starter motor but no lights at all is kind of weird.
Old 04-04-2012, 07:23 PM   #29
RedShark
Oddometer: 1,449
Common mistake - every HawkGt owner has done it at least once ( raises hand )...
Even better, P switch position and OFF position are in opposite locations ( last & next-to-last) on my 2 most-ridden bikes ( Hawk & Wee-strom )
RedShark is offline   Reply With Quote
Old 04-05-2012, 06:29 AM   #30
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,001
On the VTR, the order is: (counter-clockwise) On, Off, Park, Lock.
I can understand having Park and Lock next to each other, both lock the steering. I guess I've owned too many dual sports (without this feature).
Times are GMT -7.   It's 01:20 AM.
