Old 04-01-2012, 07:44 AM   #1
torinreality OP
metaconscious
Oddometer: 57
Left hand rear brake
Hi, all. Forum searches aren't giving me what I'm looking for:
I'd like to move the rear brake controls to the left hand position. I have a Rekluse clutch, and was thinking to merely raise the stock clutch lever out of the way. I've read about the Clake system, but I think I'd rather have two separate controls.
Who's performed this operation? Are you glad you did? Can you tell me what suppliers you used for parts? Maybe a few photos?
torinreality is offline   Reply With Quote
Old 04-01-2012, 10:15 AM   #2
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,789
I havent done it so I have no opinion on it, but here's some threads on the subject.
http://advrider.com/forums/showthrea...highlight=lhrb
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 04-01-2012, 10:24 AM   #3
Peanuts
Peanuts's Avatar
Oddometer: 1,634
I have not done it on an Adv, but have done on my own 200EXC, 450SXS, 520EXC, 250EXCF. So much better control over the rear brake. Going down steep hills, skid steering, walking alongside over bogs etc, its all good.
I use a combination LHRB and footbrake by adapting the rear master cylinder to get fluid fed through it from the LHRB.
For the actual LHRB on the bars I use a scooter rear brake or the Brembo clutch master cylinder as fitted to later KTM EXC/SX models.
I have fitted dozens of Rekluses and LHRB since 2002.
Peanuts is offline   Reply With Quote
Old 04-01-2012, 06:33 PM   #4
torinreality OP
metaconscious
Oddometer: 57
Thanks for the replies, Brents347, Peanuts. I think I have enough information now to give this a shot.
Old 02-14-2013, 08:12 PM   #5
biggus
biggus's Avatar
Oddometer: 378
Do you have any updates on your Left Hand Rear Brake? Was it a go or a no go?
biggus is offline   Reply With Quote
Old 02-15-2013, 07:39 PM   #6
Tuna Helper
Rawrr!
Tuna Helper's Avatar
Oddometer: 766
A lot of stunt riders do this. You could check out stuntlife.com.
Originally Posted by dogjaw
I'm a bike slut, I love them all
Tuna Helper is offline   Reply With Quote
Old 02-16-2013, 04:55 PM   #7
eebrumfi
eebrumfi
eebrumfi's Avatar
Oddometer: 52
http://www.youtube.com/watch?feature...=14sq7uF-rIM#!
-2012 KTM 990 Adventure-
-A DRUNKEN MAN'S WORDS ARE A SOBER MAN'S THOUGHTS-
eebrumfi is offline   Reply With Quote
Old 02-22-2013, 12:13 PM   #8
ABuck99
0.0
ABuck99's Avatar
Oddometer: 595
torinreality What was your final solution?
The new Rekluse dual actuated left hand brake kit for the small bikes works pretty well, and retains the use of the foot brake. Depends on what you intend to use it for, but I wouldnt count on that as a stand alone system to stop an LC8 which weighs twice as much as the thumper it was designed for. That left hand brake kit is off a mountain bike, it uses a bicycle brake line, its not braided stainless, so under pressure it expands and you get fade. Also Im not sure that Rekluse master cylinder could develop enough system pressure to work the rear caliper enough to lock the back wheel if needed.
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 screwed with this post 02-22-2013 at 12:28 PM
ABuck99 is offline   Reply With Quote
Old 02-22-2013, 02:04 PM   #9
Patacca
Pimp my SE italian style
Patacca's Avatar
Oddometer: 563
So let's see if something good comes from this tread...
I still couldn't do this mod.
I would like to have LHRB + a very small clutch lever (1 finger) + no foot rear brake.....
I think that removing the foot rear brake get the mod easier, because you just need the master lever....a longer line to calliper and that's it.
No problem with pressure going in the reservoir of the rear foot reservoir.......
Can anyone find a good master lever for the rear brake of an eavy LC8?
Is the Magura master (changing the OR for dot instead of mineral oil) strog/big enough to brake?! The size is 10,5.
Hope we can reach a good final solution.
If you aren't sure, open to MAX!!!
www.raffaellophoto.com
check out my pimped SE @
http://www.myktm.it/viewtopic.php?f=50&t=223
Patacca is offline   Reply With Quote
Old 02-23-2013, 11:23 AM   #10
ABuck99
0.0
ABuck99's Avatar
Oddometer: 595
You might try this product- excellent quality: http://www.accossatousa.com/index_files/Page442.htm & they might be able to help you piece this together.
Old 02-23-2013, 04:32 PM   #11
DuctTape
Oddometer: 351
I'm thinking about this since I ride a Rekluse Clutched 990. http://www.ktmcyclehutt.com/ktm-part...nt=streetbikes
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape is offline   Reply With Quote
Old 02-25-2013, 01:44 PM   #12
Patacca
Patacca's Avatar
Oddometer: 563
yeap but there is even written that there is no solution yet for bikes with hydraulic clutch..........
Old 02-25-2013, 03:22 PM   #13
Kyler
Confused Hack Nut
Kyler's Avatar
Oddometer: 2,615
I've recently become enamored with THE CLAKE (CLutch And braKE)
http://www.clake.com.au/
I'm going to try it on my 450 first.
Ken => I'm a DAMN Rider (No rules, just ride!)
Happiness is a 3-wheel drift!
Member of the Maryland OHV Alliance
2014 Yamaha FZ-09 Adventure
Kyler is offline   Reply With Quote
Old 03-23-2014, 03:01 AM   #14
Patacca
Patacca's Avatar
Oddometer: 563
Someone told me that I could buy a EXC master "pump" that works with Hydraulic oil and connect it to the brake.
That's quite easy ok, but if I would like to maintein the "pedal Pump" I need a piece that is normally sold with original kit Rekluse LHRB...
It would be easier to buy the original kit if it was available for LC8's...
The Clake system is expensive and not easy to use I guess, I've seen the one with two levers....looks like a nightmare...
Patacca screwed with this post 03-23-2014 at 03:08 AM
Old 04-25-2014, 04:39 AM   #15
rearviewmirror
rearviewmirror's Avatar
Oddometer: 282
I am looking for a LHRB setup. Is your comment above based on actual experience or is it typical interwebs conjecture? I've heard lots of good things about the CLAKE so far.
Before you ask a question about oil, READ THIS!
KTM 300EXC Six Days
rearviewmirror is offline   Reply With Quote
Times are GMT -7.   It's 06:15 AM.
