Closed Thread
Old 07-23-2011, 05:58 PM   #1
HighTechCoonass OP
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,495
Laugh New F800gs Power Controller coming soon for a US supplier!....
Go here... for the web site...
http://www.wukaking.com
Do you suffer from STS - Snatchy Throttle Syndrome - the jerky throttle on your BMW? Here is the Fix
Whats the problem? Our bikes run very lean! -
Why is that? because of emissions tuning...
Whats the fix? give the engine a little more gas...
How I do it? Tell the ECU the air temperature is lower than is actually is this makes the ECU give the bike a tiny bit more fuel.
Simple!
This smooths out the throttle response for the F800GS F650GS (and all BMW fuel injected bikes) and gives the bike more HP.
It has a 2 position switch....
one position to use for 85 deg F and below ( -36 deg F temperature shift) and
another position to use when the air temp is 85 deg F and above (-18 degree F air temperature shift).
The 2 position switch can be mounted where ever the user prefers.
This is basically the same general idea as the Accelerator module and the Booster Plug sold overseas but a with a more refined fuel enrichment control when the temperature rises.
The idea of the switch : The rider may take off in the mountain mornings at 40 deg f and it may be 90 deg F later at noon riding in the desert. A -36 deg F offset to the ECU (the way the Accelerator plug works) is not need when the air temperature gets hot. Only a -18 deg F offset to the ECU is needed when the air temperature is above 85 deg f. Better control for a more precise enrichment.
The switch was a request from riders in some of the development discussions.
Good question to go over again.....
Blue position- this setting it tells the ECU that the air temperature is 36 deg F cooler than it is. The ECU enriches the fuel (on increase throttle movement and decrease throttle movement only)
Red position- this setting it tells the ECU that the air temperature is 18 deg F cooler than it is. The ECU enriches the fuel (on throttle movement only)
Less enrichment is needed when air temperature is above 85 deg F.
Steady state throttle- the O2 sensor controls enrichment!
Cost: $85 plus $5 to ship
WAL-MART guarantee - if you are not happy with the performance of the Power Controller please return for 100% refund!!!!
Step one.....
Step 2.....
Step 3....
Step 4 ....
Use sticky to stick down a base and tyrap the sensor to the "stick base"
this is where i have my switch....
operations: the "red paint" on the switch is for -10 offset (above 85 deg F) away from the red paint or blue is for -20 deg c) when temperature is below 85 deg F.)
any question PLEASE send me a PM!!!!!! I check a few times a day!!!
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass screwed with this post 05-25-2014 at 09:49 AM
HighTechCoonass is offline
Old 07-23-2011, 07:04 PM   #2
OverlandHank
Loves to Farkel
OverlandHank's Avatar
Oddometer: 59
Standing by!
2010 BMW F800GS
2009 Suzuki DL650 Vstrom
2004 Honda VT750 Aero
OverlandHank is offline
Old 07-24-2011, 03:07 PM   #3
1fastjunebug
Oddometer: 173
USA Controler
Didn't think SW La. was part of the US, don't you have a special passport that says "when traveling in foreign countries and can not commuincate with the local ladies, try communicating in braille"?
Greetings from another Coonass. Have 2011 F800Gs that I just bought and the leaness and fueling setup is dodo. Shifitng at anything under 4,000rpm and cracking the throttle brought on - nothing - a dead zone that, if you kept the throttle cracked, the poor thing would eventually get with the program. Just came off a well sorted and farkeled R1200GS which is a transition I know, but this just isn't right. Reminds me of my 2000 RT and the surging issues, that BMW refused to acknowledge and that I threw handfulls of moneyh at and finally got it rideable. Who ever said lean was green????????? Mo green for the inventors like youself, who I will support whole heartedly. Make it happen, Captain CoonAss, I'll be standing in line.
In the mean time, got me one of the "foreign" devices and it helped. Let me clarify: in Houston at 97 degrees it helped some. Didn't get rid of the devile but filed it's horns some.
Just rode this am in the Hill Country with a start out temp of 77, it was mucho moy better. As the day went on, things heated up and got back to camp with sub 90 temps - more city riding, same basic help as in Houston with those temps. .
That being said, a dual range device would be a step up from what I have. Need any back to back comparisons or field trials let me know.
Boudreaux
1fastjunebug is offline
Old 07-24-2011, 05:10 PM   #4
bodhizafa
How hard can it be?
bodhizafa's Avatar
Oddometer: 646
I'm interested in this, I'm on the verge of getting a booster plug and this seems like a good alternative.
I'll have one if you do.....
bodhizafa is offline
Old 07-24-2011, 06:48 PM   #5
Integratedfool
Oddometer: 5
Im in, brand new to the scene here but definitely want to get the throttle smoothed. When are you thinking of releasing these, and will they be "Plug - N - Play"?
Integratedfool is offline
Old 07-25-2011, 07:07 PM   #6
HighTechCoonass OP
Oddometer: 2,495
All of the final parts will be in this week... I am leaving for a Colorado Ride this Friday.... I am thinking I will have a few for sale in 3 weeks...
It will be plug and play....
My design-
It will have a two way switch, -20 and -10 deg C offset.
It will use the existing air temperature sensor
It will have an additional air sensor that will extend to the front of the bike.
It will have the BMW factory connectors that will plug into the factory wiring harness.
Old 07-25-2011, 08:12 PM   #7
ironbutt84
Time Traveler
ironbutt84's Avatar
Oddometer: 153
I'm in! Put me down for 1 as I was just going to order a booster plug. Seriously, put me down for 1!
ironbutt84 is offline
Old 07-25-2011, 08:34 PM   #8
porschenator
porschenator's Avatar
Oddometer: 18
I'm "in".......
My design-
Terrific!......rode 'rock gardens" this weekend.......wher this tool would have been perfect......and huge temp swing here in Idaho......started the ride into a river canyon at 7:00 a.m.....temp 44 degrees.....need the ride on a 'ridge road'....temp 103.4 degrees....OUCH!
porschenator is offline
Old 07-26-2011, 11:00 AM   #9
HighTechCoonass OP
Oddometer: 2,495
Laugh
OK I have you all down for one!
Old 07-26-2011, 12:42 PM   #10
eddyturn
Wannabe
Oddometer: 2,084
maybe...
All things being equal... fat people use more soap
eddyturn is offline
Old 07-28-2011, 08:54 AM   #11
foroffroaduseonly
foroffroaduseonly's Avatar
Oddometer: 82
defiantly interested!! Let me know when you can send one my way.
foroffroaduseonly is offline
Old 07-28-2011, 10:44 PM   #12
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
This sounds interesting... Let's discuss. :woot
Ride more, bark less
Gangplank is offline
Old 07-29-2011, 06:40 AM   #13
foroffroaduseonly
Oddometer: 82
It is hard to ride wheelies with that jerky on-off power transition
Old 07-31-2011, 10:10 PM   #14
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
How's it coming? Looking forward to when something becomes avail...
Old 08-02-2011, 06:28 AM   #15
Grafspee
one bike is never enough
Oddometer: 209
Interested
Very interested, I will keep an eye on this.
Grafspee is offline
Closed Thread
Times are GMT -7.   It's 07:51 PM.
