Closed Thread
Old 03-23-2012, 11:04 AM   #271
MtnBound
MtnBound's Avatar
Oddometer: 11
Pay pal sent.
MtnBound is offline
Old 03-23-2012, 08:20 PM   #272
HighTechCoonass OP
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,493
Laugh
Ok gang ... all orders to date have been shipped....
Thanks!!!!!
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is offline
Old 03-25-2012, 09:44 AM   #273
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Here is where I mounted mine. Left side of steering stem tube. there is room under there to zip tie it in place. Can easily reach it while riding.
Ride more, bark less
Gangplank is offline
Old 03-28-2012, 05:47 PM   #274
epicxcrider
epicxcrider's Avatar
Oddometer: 645
Just installed mine and went for a ride - the bike rides like you would expect from the beginning. Perfect transitions on/off throttle, and the ability to lug the engine to 1500rpm or so is great - $ well spent! Thanks!
epicxcrider is offline
Old 03-31-2012, 11:55 AM   #275
HighTechCoonass OP
Oddometer: 2,493
Thanks for the kind words... all orders to date went out Friday! I have another 5 in stock... ship out next day... Thanks again!!
Old 04-01-2012, 09:06 AM   #276
HighTechCoonass OP
Oddometer: 2,493
Laugh Power Controller - F800gs / F650gs Snatchy Throttle Fix
The way to calm the beast within is to lower the air box temperature readings to the ECM (engine Control Module)
Results: Smoother Throttle response on the UP and Down Throttle! a 5 minute fix...
If you have any questions post here.... The last thread turn into sales and got moved to vendors.....
There are about 30 bikes out there now running the units.... If you have any question post here....
The term for this is "Resistor Tuning" if you would like to read up on it. There is also the Booster Plug and the Accellerator.... lots of good info......
These work on almost all of the BMW FI bikes... but since the R1200 for example doesn't rev up as fast it is not a big of an issue...
This is a Q and A thread... any questions about orders and shipments please post in Vendor Fourm....
HighTechCoonass screwed with this post 04-13-2012 at 09:49 PM
Old 04-01-2012, 09:28 AM   #277
HighTechCoonass OP
Oddometer: 2,493
Laugh
30" switch lead..... all switch leads are black now....
Epoxy electronics....
Heat shrinked, with hot glue BMW connectors...
HighTechCoonass screwed with this post 04-13-2012 at 09:50 PM
Old 04-01-2012, 02:00 PM   #278
2Stamp
2Stamp's Avatar
Oddometer: 389
So, between the Booser plug and yours, the major difference is the ability to switch yours at different temps, correct? Any other differences? I currently am running the BP (bought it before yours came out).
_______________________________
2011 F800GS
2014 350XCF-W
2006 450EXC
2014 Honda Grom (hers)
2Stamp is offline
Old 04-01-2012, 05:39 PM   #279
HighTechCoonass OP
Oddometer: 2,493
Talking
Yeap the same ... the difference mine you can switch to a -10 degree C (18 deg f )offset - Because you don't need a -20 deg ( - 38 deg F) offset to the ECU when the air temperature is above 85 deg F.
Old 04-12-2012, 03:54 PM   #280
HighTechCoonass OP
Oddometer: 2,493
Laugh the new faster "Black and Red" edition...
HighTechCoonass screwed with this post 04-13-2012 at 09:47 PM
Old 04-12-2012, 03:56 PM   #281
HighTechCoonass OP
Oddometer: 2,493
Laugh New faster "Black and Red" edition
Old 04-12-2012, 05:42 PM   #282
drroccostein
Oddometer: 49
Question
HTCA - have you given any thought to a 3 position switch?
Just thinking out loud, position 1 bypass (factory, no offset), 2 cold and 3 hot. Bypass would be used on warm up and super efficiency mode on the highway.
drroccostein is offline
Old 04-12-2012, 07:17 PM   #283
MikeMike
MikeMike's Avatar
Oddometer: 4,150
What happens when you are riding at elevations above say 7,500ft?
MikeMike is offline
Old 04-13-2012, 09:21 PM   #284
HighTechCoonass OP
Oddometer: 2,493
BMW bikes have an air pressure sensor (to the ECU) that compensates for elevation
HighTechCoonass screwed with this post 04-16-2012 at 07:31 AM
Old 04-13-2012, 09:34 PM   #285
HighTechCoonass OP
Oddometer: 2,493
The need for a 3 position switch for fuel economy.... The "Power Controller" has almost no effect on fuel mileage.
Myself and my buddy on another F800gs (that had no power controller) We rode for miles and miles.... on every fill up we used the exact same fuel.
* note - he was carring a about an extra 40 lbs - if that makes a difference and he runs his bike a little harder.
HighTechCoonass screwed with this post 04-16-2012 at 07:29 AM
Closed Thread
Times are GMT -7.   It's 07:14 AM.
