Closed Thread
Old 09-12-2011, 06:06 PM   #61
CycleRider
CycleRider's Avatar
Oddometer: 662
Class
HCTA is definitely a class act! Because I sold my bike before I had a chance to install his product, I am getting a full refund (and I didn't even have to ask!).
Customer Service does not get any better than that!
Thank you, Sir!
TP ...
CycleRider is offline
Old 09-12-2011, 06:39 PM   #62
davidadv1
davidadv1's Avatar
Oddometer: 97
money sent
I know I'll like it
davidadv1 is offline
Old 09-13-2011, 07:24 PM   #63
HighTechCoonass OP
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,493
Wink
Dave, Shipped this morning... You will like it!!!
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is offline
Old 09-14-2011, 06:37 AM   #64
Grafspee
one bike is never enough
Oddometer: 208
I'll take one
Put me in for one -I'll send a PM
Grafspee is offline
Old 09-14-2011, 07:11 AM   #65
dom02
dom02's Avatar
Oddometer: 160
Easy to install & works!
Put mine in yesterday morning & went for a 400 mi ride. Much easier to feather throttle when pulling out. Worth every penny! Really didn't need to remove sensor, just disconnect plug from it & install new controller plug.
dom02 is offline
Old 09-14-2011, 10:51 AM   #66
Moto Mikey
Moto Mikey's Avatar
Oddometer: 444
Payment sent. Can't wait to try this out
Moto Mikey is offline
Old 09-14-2011, 06:00 PM   #67
drroccostein
Oddometer: 49
Thumb Damn Nice
HTCA the product is as described, with a simple 5 minute install I was up and running. The throttle response was linear and no where near as snatchy as the stock response. The lean backfire has been reduced drastically when you roll off the throttle, meaning better fuel ratio's. Didn't get a long ride in but what I did the improvement is very noticeable.
The one thing I did since the connectors are not water packs, I broke out the dielectric grease. This comes from my VW days, I learned the hard way a little water can do a lot of damage to the pins.
My only problem is where to put to sticker, I need a second to balance the aesthetics of the bike.
drroccostein is offline
Old 09-15-2011, 05:45 PM   #68
HighTechCoonass OP
Oddometer: 2,493
Laugh F800gs Snatchy Throttle Fixed! - the other option!
The problem is the EPA. Emissions .... The way BMW gets our bike to pass emissions standards to tune the bikes to run very lean.
The fix is to give the bike more fuel....
How to do this?
Change the air box temperature signal to the computer. Decrease the ambient air temperature by 35 - 36 degrees F... and your bike has a smoother throttle!!!! (only 16 deg F needed for the really hot days)
This gives the bike more fuel when the throttle is changing..... at a steady throttle state the computer uses the O2 sensor to control fuel amounts...
The to do this is to add a thermistor and add resistors to give the ECU (engine control module) an "adjusted" temperature reading.
see my Power Controller here....Made in USA $85 (dual setting)
http://www.advrider.com/forums/showthread.php?t=709574
the Booster Plug here....Made in Denmark.... Ebay...$150 (single setting)
http://www.boosterplug.com/shop/frontpage.html
the Accelerator here....Made in Denmark....sold only thru Cycleops....$120 (single setting)
http://www.sol2.be/Performance/ENG/Home/index.html
Lot and lots of Happy Customers!
HighTechCoonass screwed with this post 09-15-2011 at 06:32 PM
Old 09-15-2011, 06:04 PM   #69
HighTechCoonass OP
Oddometer: 2,493
I will ship you a second sticker to ballance you out!!!
Thanks!!!
Old 09-15-2011, 06:37 PM   #70
BMW_BIKER_KEITH
BMW_BIKER_KEITH's Avatar
Oddometer: 395
buy
Coonazz... I want to get one for my 8ooGSazz.
Howz doez i'z payzya?
2010 Lava F800GS...AKA "Dirty Harry"
1998 R1200C Classic Black...AKA "Dick The Cruiser"
BMW_BIKER_KEITH is offline
Old 09-15-2011, 06:48 PM   #71
toro618
toro618's Avatar
Oddometer: 979
After hooking up the unit a week ago, I finally put some miles on the bike (in pouring rain) and in the high 70's (switch on blue for below 85 degrees). If anyone else is like me, at certain speeds and turns you would be anticipating the bucking thats about to kick in. Well now, out of habbit you will still be aniticipating the bucking....make the slow turn in traffic....go through the gears....then realize there was no bucking.
I've been running the Akra can from day one. I don't know what this device does to the A/F ratio, and I don't really care because now my bike runs smooth.
toro618 is offline
Old 09-15-2011, 08:02 PM   #72
2Stamp
2Stamp's Avatar
Oddometer: 373
So, has anyone running a booster plug tried this one as well?
2Stamp is offline
Old 09-15-2011, 09:50 PM   #73
fly-n-brian
low and slow
fly-n-brian's Avatar
Oddometer: 6
It works great...
Hey Ritchie, your controller works like a charm, I've noticed a big difference in the throttle and the bike seems to run better. I originally thought it was going to be a hassle mounting the toggle under the seat to switch it back and forth, but not an issue. I just have to lift the seat a couple of inches to switch it. I haven't checked the fuel mileage yet, so I can't report if it helps or not. We finally started cooling down here in South Central Washington, but we were having 100 degree highs with low's in the 50's. Going over the Cascades to Seattle tomorrow, so will see how she does.... So far so good and loving it. Thanks for making it available.
Brian
fly-n-brian is offline
Old 09-16-2011, 07:18 AM   #74
MotrSklz
MotrSklz's Avatar
Oddometer: 129
Question
This may be a dumb question, but I assume the power controller will work on the F650GS (twin) as well?
Cheers
MotrSklz
MotrSklz is online now
Old 09-16-2011, 12:15 PM   #75
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,454
This. I have a booster plug but temperatures routinely get over 85* here so it sounds like it would be a good idea for my bike.
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline
Closed Thread
Times are GMT -7.   It's 02:48 AM.
