Closed Thread
Old 10-19-2011, 06:49 PM   #106
HighTechCoonass OP
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,478
Laugh
Poolsides unit....IICE to Power Controller Comparison....
we both provide a the -10 and -20 deg offset - is the same as the Power Controller.
IICE.....
PROS... 4 positions "normal / -10 deg c / -20 deg c / -30 deg C" offsets
(normal / -30 not needed IMO -Poolside is doing more mods (o2 and throttle sensor) later that may require these settings from what I read)
CONS....
no external temperature probe , plastic housing will not last, jumpers are a PITA, if you dont like it... tough luck! no returns!
Power Controller...
Pros... on the fly switchable , built to last, external temperature probe to get the most accurate offset that is needed for it to work best.
Originally Posted by soyanarchisto View Post
How is this product different from what is being offered here:
http://advrider.com/forums/showthread.php?t=667661
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass screwed with this post 10-20-2011 at 04:52 PM
HighTechCoonass is offline
Old 10-19-2011, 06:58 PM   #107
HighTechCoonass OP
Oddometer: 2,478
Laugh
....on the OEM plugs I now use a heat shrink with "hot glue" in the inside. Saves lot of time instead of wrapping in Rescue tape (silicone tape). Remember the plugs are allready "waterproof" rated. just going the extra mile....
also a note the epoxy sealed electronics are a little smaller now...
Originally Posted by toro618 View Post
I bought and use the first batch you made...works great. Other than the longer lead, is there any difference between the first batch and the latest? I did read somewhere you waterproofed the OEM plugs...any reason?
HighTechCoonass screwed with this post 10-19-2011 at 07:11 PM
Old 10-20-2011, 12:45 PM   #108
2Stamp
2Stamp's Avatar
Oddometer: 350
Originally Posted by YetiGS View Post
This. I have a booster plug but temperatures routinely get over 85* here so it sounds like it would be a good idea for my bike.
Still wondering if anyone has run both yet? As Yeti mentioned, I also get temps routinely over 85*, and very cool fall temps. This sounds good, but I have a Booster Plug already. Someone convince me this is better and what I'm looking for.
2Stamp is offline
Old 10-20-2011, 05:50 PM   #109
HighTechCoonass OP
Oddometer: 2,478
Wink
The only way to know for sure is to put the bike on a dyno and check the enrichment at the different ambient air temperatures.
You just have to ride and see the difference.... The science (air density tables) tell us that the enrichment above 85 is not needed....and the bikes work well above 85 switched in -18 ... still smooth.
There are a few of us doing the EXACT same enrichment methods... but I have a little less when hot and i still works so we call it good!
If you swap from a booster to a Power Controller I do think you will notice a difference... but the science tell us that it is so over compensation... and that level of enrichment is not needed... but it wont cause any problems that anyone is aware off.
"No need for over compensation -like taking a 4 hour Viagra pill
HighTechCoonass screwed with this post 10-20-2011 at 06:10 PM
Old 10-21-2011, 09:28 AM   #110
HighTechCoonass OP
Oddometer: 2,478
Laugh ideas for mounting the switch...
ideas....switch mounting... here shown is a short piece of copper plumbers strapping...the hole matches the switch mounting... notice i put some black tape on the frame on the bike. I passed a tyrap thru the holes and strapped to the back-side of the frame...hidden and out of the way on the left side on the bike....
HighTechCoonass screwed with this post 10-21-2011 at 09:34 AM
Old 10-26-2011, 09:58 AM   #111
HighTechCoonass OP
Oddometer: 2,478
Wink
http://www.advrider.com/forums/showthread.php?t=709574
lots of info and reviews in the link above.... I had a few mate ask where we get one?
EDIT for new source of Power Controller and Juice:
The Power Controller and Juice are available for purchase at: wukaking.com
More information about the continuing development and sale of the Power Controller and Juice can be followed here.
HighTechCoonass screwed with this post 05-25-2014 at 11:09 AM
Old 10-26-2011, 12:41 PM   #112
replicant
consummate n00b
Oddometer: 97
Originally Posted by eddyturn View Post
I like mine!
Seconded. The price-to-utility ratio on this is higher than anything else I've added to the bike.
replicant is offline
Old 10-27-2011, 06:30 PM   #113
HighTechCoonass OP
Oddometer: 2,478
Laugh
Thanks for the kind words mate!!!
Old 10-27-2011, 07:05 PM   #114
markymcd
markymcd's Avatar
Oddometer: 882
would be interested to hear if there are any folks with the 650 twin using it and what their thoughts are. Mine felt quite twitchy for the first 20,000km or so but I'm at 57,000 now and it seems a lot smoother. plus I've changed to the same sprockets as the 800, but that should actually make it more twitchy in theory but to me it's just more useable torque off-road in 2nd gear. 1st gear is the real issue.
Mark.
www.adventuredecals.com
markymcd is offline
Old 10-27-2011, 08:50 PM   #115
replicant
consummate n00b
Oddometer: 97
Mark.
I have a 650, with 27k miles and oem sprockets. I would say most but not all of the twitch is resolved by the power controller. But the other half of the reason I bought the thing was to deal with the weird flat spot in the mid-3000 rpm range during hard acceleration. With the controller there isn't any hesitation, it just goes.
Old 10-28-2011, 06:53 AM   #116
SportFaller
Dirt dont hurt, MUCH
SportFaller's Avatar
Oddometer: 668
put mine on last night and took it for a quick spin around the block (would have went further, but it was 30 degrees) and the jerky throttle is deffinatly a LOT better, cant wait to hit the trails.
HTCA: two things:
One, you might want to bag the small parts before boxing and shipping, when I got the box, the zip tie was hanging out and the colored tape spots were missing. no big deal, I have a lot of colored electrical tape.
Two, I should have asked for a second sticker, I gatta keep it symmetrical!
"The chokers, and the chain saws, and the log trucks have been stilled, now spotted owls, and hippy gals, run freely through the woods!"
Bikeless in WY
http://www.dakotadualsportriders.com
SportFaller is offline
Old 10-28-2011, 03:11 PM   #117
toowheels
on a mission...
toowheels's Avatar
Oddometer: 962
I've had mine on for just over a week and a half now. I've done a few rides and one on dirt. I'm very happy with the improvement! Thanks HTCA
I haven't noticed any real change in fuel consumption either.
Dave
Moto Overland [MOD] -Skid Plates, Top racks, Tool Boxes etc for Adventure bikes
www.motooverland.com
toowheels is offline
Old 10-28-2011, 08:13 PM   #118
Tor
Native Viking
Tor's Avatar
Oddometer: 803
Richard,
Just sent you funds for one via Paypal for my F8GS. Wife probably wants one too at a later point for her 650GS.
"Be Always Sure You Are Right - Then Go Ahead"
2005 Honda ST1300 / 2010 BMW F800 Gelände-Straße
Tor is offline
Old 10-29-2011, 09:50 PM   #119
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Been running one for a few thousand miles now. Works great. Smooth as butttah.
Ride more, bark less
Gangplank is offline
Old 10-30-2011, 06:48 PM   #120
HighTechCoonass OP
Oddometer: 2,478
Laugh
all recent orders have been shipped! Thanks fellows glad you like um!
HighTechCoonass screwed with this post 12-27-2011 at 09:16 AM
Closed Thread
Times are GMT -7.   It's 07:43 AM.
