Closed Thread
Old 11-02-2011, 04:51 AM   #121
Tor
Native Viking
Tor's Avatar
Oddometer: 803
Got it yesterday. Thanks Rich.
Installed it yesterday afternoon. Straight forward install. It's getting packed under the cover now with Autocom, Powerlets, GPS connections. Anyway,,,,initial feel: Much smoother coming out of closed throttle. Much smoother going into closed throttle. Lost a approx. 3k rpm flat spot that sometimes materialized itself. Started her up this morning at about 32 degr. for work and initial idle seemed smoother, and maybe a little lower rpm.
So if you guys get this think, (and don't forget to take the slack out of the throttle cable,,,,,w/o increased rpm with handlebars in full left lock) you'll be pleased.
Should have done this before. Well worth the money.
"Be Always Sure You Are Right - Then Go Ahead"
2005 Honda ST1300 / 2010 BMW F800 Gelände-Straße
Tor is offline
Old 11-03-2011, 10:46 PM   #122
dam elec
Oddometer: 21
Do you also make one for the KTM adventure?
dam elec is offline
Old 11-05-2011, 04:49 PM   #123
HighTechCoonass OP
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,478
Laugh pictures of the latest Power Controller.......
30" switch leed.....
Epoxy electronics....
Heat shrinked, with hot glue BMW connectors...
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass screwed with this post 11-05-2011 at 04:56 PM
HighTechCoonass is offline
Old 11-05-2011, 04:57 PM   #124
HighTechCoonass OP
Oddometer: 2,478
Laugh
Old 11-05-2011, 05:00 PM   #125
HighTechCoonass OP
Oddometer: 2,478
Laugh
If I had a bike to test.... yes I could build one!!! I will work on this....
Old 11-05-2011, 07:01 PM   #126
dam elec
Oddometer: 21
That would be great.
Let me know if I can be of any help; pictures, testing etc. etc.
The "Accelerator" at Cyclops goes for 170 dollars; just a bit too steep for me; like you price better.
dam elec is offline
Old 11-05-2011, 08:17 PM   #127
beeper
Badger tickler
beeper's Avatar
Oddometer: 773
I'm saving up for one of these, the latest edition looks great.
'12 F800GS
'00 Bandit 1200
'74 Honda CL360
beeper is offline
Old 11-05-2011, 08:30 PM   #128
toowheels
on a mission...
toowheels's Avatar
Oddometer: 963
Very happy with mine too Ritchie! It works!
The install is ridiculously easy too.
I'll try it out at some 0* C temps tomorrow
Friend of mine just got a 990 Adv too and says the throttle is not as smooth as the F8 so it sounds like they need help too.
Dave
Moto Overland [MOD] -Skid Plates, Top racks, Tool Boxes etc for Adventure bikes
www.motooverland.com
toowheels is offline
Old 11-06-2011, 05:58 AM   #129
toro618
toro618's Avatar
Oddometer: 966
From a performance stand point, is there a difference between the first batch you made (which I havee), and this latest version? Is it all the same electronics but sealed better?
toro618 is offline
Old 11-06-2011, 07:28 AM   #130
HighTechCoonass OP
Oddometer: 2,478
Laugh the changes...
good question... same exact electronics!, the circuit board is just smaller.
differences...................................
1. The switch whip is longer
2. The BMW waterproof plugs were double sealed with "rescue" silicone tape (the was time consuming for me). Now they are sealed with adhesive lined heat shrink.
3. Epoxy electronics are now molded in smaller mold and then wrapped in heat shrink.
4. Switch is painted Red and Blue.
5. Every unit is shipped with a "WUKA KING Performance Products" decal.
Again Thanks for the great reviews!!!
Old 11-06-2011, 08:48 AM   #131
Tor
Native Viking
Tor's Avatar
Oddometer: 803
Just a question Rich,,,,
why wold you use a switch? Because the sensor don't have a res. range wide enough?
Tor is offline
Old 11-06-2011, 09:28 AM   #132
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
New edition looks good. My original serial #1 production unit is working great. Super happy with it and would highly recommend this unit.
Ordered and quickly shipped.
Thanks again HTC!
Ride more, bark less
Gangplank is offline
Old 11-06-2011, 11:15 AM   #133
HighTechCoonass OP
Oddometer: 2,478
Laugh
for two settings...read the first post... -36 degs F offset setting to the ECM and -18 deg setting.
HighTechCoonass screwed with this post 12-27-2011 at 09:17 AM
Old 11-07-2011, 06:10 AM   #134
Hikertrash
Oddometer: 2,775
Originally Posted by markymcd View Post
would be interested to hear if there are any folks with the 650 twin using it and what their thoughts are. Mine felt quite twitchy for the first 20,000km or so but I'm at 57,000 now and it seems a lot smoother. plus I've changed to the same sprockets as the 800, but that should actually make it more twitchy in theory but to me it's just more useable torque off-road in 2nd gear. 1st gear is the real issue.
Mark.
I ordered one and used for about a week on my F650 twin. It did run a bit smoother in the lower gears after shifting, but not enough to warrant the cost albeit minimal. HTC took my controller back and refunded my $$ as soon as he received my controller. With a 100% refund if unhappy, it's worth a shot to try out IMO. I works for many, just not for me and my bike.
Hikertrash is offline
Old 11-11-2011, 05:53 PM   #135
sjarrell
sjarrell's Avatar
Oddometer: 7
Originally Posted by HighTechCoonass View Post
for two settings...read the first post... -36 degs F setting and -18 deg setting.
Two questions...
  1. Why not just go ahead and switch it automatically based on the outside air temp instead of using a manual switch? Seems like that would be very simple and convenient.
  2. Taking the above question a step further, would it make sense to make a controller that constantly varied the differential temperature adjustment based on the outside air temp versus having just two static manual settings?
  3. How do we go about ordering these?
Thanks,
Steve
sjarrell is offline
Closed Thread
Times are GMT -7.   It's 03:16 AM.
