Old 08-29-2014, 04:48 AM   #1
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 602
Starting my 950 ADV
Sometime it starts right up smooth as cutting warm butter. Sometimes it goes clank clank click clic clank like an old sherman tank trying to start. Typically, I give it one twist of the throttle to get some gas moving then push the starter button and twist again...
Am I just doing something wrong?
"if your not getting older, your dead"
rossphoto is offline   Reply With Quote
Old 08-29-2014, 04:56 AM   #2
bomose
bomose's Avatar
Oddometer: 1,284
It could be the battery.Mine would do that even when it showed 12.5 volts at rest. Put a meter on it and see what the voltage reading is when you press the starter. Mine would drop to 6V.
I prefer a short life with width to a narrow one with length-Avicenna
http://www.advrider.com/forums/showthread.php?t=810149 Ouray Adv
http://www.advrider.com/forums/showthread.php?t=800723 Cortez & Moab
http://www.advrider.com/forums/showt...=955211Chasing Dinosaurs
bomose is offline   Reply With Quote
Old 08-29-2014, 05:57 AM   #3
stupot
stupot's Avatar
Oddometer: 124
My 950 starts first push when it's cold but can be a little more reluctant once she is warm.
stupot is online now   Reply With Quote
Old 08-29-2014, 07:11 AM   #4
sno
On a mission!
sno's Avatar
Oddometer: 132
Try this Ross.
Full choke when cold. As the rpm's pic up introduce a little throttle and back off the choke.
Warm restart. 1/4 choke as rpm's pic up let the choke off.
You also may want to set your idle adjuster 1/4 to half turn higher when starting then dial it back after engine comes to temp.
sno is offline   Reply With Quote
Old 08-29-2014, 12:13 PM   #5
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,467
Try not touching the throttle, 1/2 to 3/4 choke and hit the button for short bursts. Twisting the throttle isn't moving any gas. There are CV carbs.
Mine sometimes starts like crap, just as you described, but my bike has the amazing self-adjusting fuel screw syndrome and that usually means I need to pop the carbs off and re-check them.
When it's warm a touch of the button and she's running.
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 08-29-2014, 01:34 PM   #6
Denalidirt
High Plains Drifter
Denalidirt's Avatar
Oddometer: 928
Starter solenoid
Mine made that kinda sound. It was a recall.
Denalidirt is offline   Reply With Quote
Old 08-30-2014, 07:02 AM   #7
gearheadE30
gearheadE30's Avatar
Oddometer: 966
I would avoid using the throttle when starting. Mine still has the old-style torque limiter which seems to be going strong and rarely skips, but if I open the throttle, it will skip every time, and make some nasty noises.
2005.5 KTM 950 Adventure and 2012 KTM 200 XC-W
1991 BMW 318is turbo track car
1989 Chevrolet Caprice Classic Wagon sleeper tow car
1992 Subaru SVX daily
3 Months Exploring the US on a 950
gearheadE30 is offline   Reply With Quote
Old 08-30-2014, 07:09 AM   #8
rossphoto OP
GDTRFB
rossphoto's Avatar
Oddometer: 602
Yes it seems to do much better without the throttle...
Old 08-30-2014, 07:31 PM   #9
Racer111v
Racer111v's Avatar
Oddometer: 851
Mine always likes the throttle cracked. If I don't it may kick back and lock the starter/sprag. I can unlock it by putting it in fourth gear and rocking it backwards. It took a while to figure that deal out. I imagine this is what they were trying to prevent with the updated sprag that created other issues...........
2004 KTM 950 ADV ...............................1979 Suzuki RM400 VMX Race bike
2006 DR-Z400E plated........................... 2001 Ducati ST2 944
2001 YZ250N 2T plated.......................... 1986 Yamaha FJ1200
Racer111v is offline   Reply With Quote
Old 08-30-2014, 10:49 PM   #10
MrEndo
MrEndo's Avatar
Oddometer: 421
Sounds like the starter bendix recall
2015 Harley Ultra Limited
2013 350 EXC-F (Wife's)
2008 530 EXC-R/2008 Beta Rev4T
2006 950 Adv S/2002 640 Adv/1970 Yamaha RT1
MrEndo is offline   Reply With Quote
Times are GMT -7.   It's 04:08 AM.
