Old 05-14-2012, 06:05 PM   #76
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,152
This is what I used, I'll just have to see how well it holds up:
traveltoad is online now   Reply With Quote
Old 05-14-2012, 06:20 PM   #77
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 3,668
Nice...time for another run through the sandwash........let's test these babies out....
MTS 1200 Pikes Peak....Touring Beast
950SE......Desert Beast
'Berg 570..Trail Beast
Nowwhat is offline   Reply With Quote
Old 05-14-2012, 07:49 PM   #78
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,152
Old 05-14-2012, 08:17 PM   #79
pizzaboy
hook-em
pizzaboy's Avatar
Oddometer: 514
Sure wouldn't mind some of these for the stocker tank....
Indecision always goes to the left...
'09 BMW R1200GSA
'09 KTM 950SER Erz
pizzaboy is offline   Reply With Quote
Old 05-15-2012, 05:43 AM   #80
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 581
Carbon performance
I think Carbon Performance makes them for the stocker.
dogsslober is offline   Reply With Quote
Old 05-15-2012, 06:20 AM   #81
ktm950se OP
ktm950se's Avatar
Oddometer: 1,385
As I started this thread, its only fitting for me to say, as well, PM sent.
ktm950se
ktm950se is offline   Reply With Quote
Old 05-15-2012, 07:52 PM   #82
triplenickel
triplenickel's Avatar
Oddometer: 2,262
Get your orders in guys, I want mine!
07 SE
PG007
Old 05-15-2012, 09:24 PM   #83
spencergt66
Oddometer: 359
Totally worth it
If anyone is on the fence about these guards I can assure you that they are made to last. Daryl spent a lot of time a several visits to make sure all the test pieces and molds were correct to ensure a proper quality part. I have several other off the shelf carbon parts and none even come close to these.
spencergt66 is offline   Reply With Quote
Old 05-17-2012, 08:30 AM   #84
kanur
kanur's Avatar
Oddometer: 497
Got mine and they look great
Now I need to round up some clamps to get them installed.
I heard the North Star saying, kid you're so lost even I can't bring you home. RIP Jason Molina
kanur is offline   Reply With Quote
Old 05-17-2012, 10:17 AM   #85
Cyclops Motorsports
Cyclops Motorsports's Avatar
Oddometer: 945
Thank You
just a note..
I had a PM about one side did not quite fit as snug as the other. This could be due to tank swelling or something else.
Be cautious not to flex the guards to much on install . It would be better to use a bit more adhesive and allow a slight gap then to have the guard trying to pull itself off the tank.
If anyone has any issues please let me know..Your feed back is extremely important to me.
When Quality matters,Its all about choices.
Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
http://youtu.be/1fmEJO3ftFI
Cyclops Motorsports is online now   Reply With Quote
Old 05-18-2012, 08:05 AM   #86
kanur
kanur's Avatar
Oddometer: 497
Well I got mine mounted and I think they are going to be great.
On a dry trial fit I found the right side fit very well and the left did not follow the tank as well. Daryl had noted this may be the case in a post above. There are butt loads of posts about Safari tanks not fitting well or deforming when removed,ect, ect....so I'm sure no two are the same. Once the adhesive was applied it fit fine. This is how I did it.
I resisted the urge to spread it out and just left it in globs. My father in law is a wood working hobbiest and has every kind of clamp known to man so I borrowed an assortment before starting and guess what? None of them would work. After some head scratching and a beer or two this is what I came up with.
Cam straps from my white water gear bag. These worked great for holding them in place without flexing them. The painters tape was probably not needed but it made me feel better. I'll post up a finished pic when after I get it all back together.
Old 05-18-2012, 12:44 PM   #87
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,152
Damn I wish I had thought of that.
Old 05-18-2012, 01:30 PM   #88
ktm950se OP
ktm950se's Avatar
Oddometer: 1,385
OK, So what is the recommended silicone to use to mount these?
Is it the Dow Corning 732 shown if this pic, or something else?
I want to have a tube on hand when my guards arrive so I can mount them immediately.
ktm950se
Old 05-19-2012, 07:33 AM   #89
Cyclops Motorsports
Oddometer: 945
ktm950se
Any good silicon based ADHESIVE will work. I just installed these on my 950 adv using DAP marine grade silicone adhesive.available in any hardware store
Old 05-19-2012, 07:49 AM   #90
Questor
More Undestructable
Questor's Avatar
Oddometer: 3,580
Here's how I did it...
Step 1: Find motorcycle.
Step 2:
Find where the guard goes.
Step 3: Use RVT adhesive.
Step 4: Use clamps.
Step 5: Wait 24 - 36 hours.
Step 6: Admire how nice the new guards are.
Thanks Cyclops.
Q~
Questor screwed with this post 05-20-2012 at 06:11 AM
Times are GMT -7.   It's 01:49 PM.
