Old 04-03-2012, 10:17 AM   #1
HPMGuy OP
Oddometer: 264
KTM forks on your Airhead! Group Buy Two
Group Buy Number Two for the R-Dubb designed triple clamps that will mount KTM 50mm Extremes, 4860's, or 43mm forks to your Airhead BMW.
Many have expressed interest in another run of these triples, so I am starting a list to see if we can get enough to do a second run. A lot of info can be found about this setup here on the previous group buy thread.
Pricing will remain the same as the last run, $536 for the Upper and Lower Triples, New Stem pressed in place, Stem Top bolt/washer and hardware.
I will PM everyone on the list to confirm interest, and then chart it here so we can see where we stand.
Also, there has been some interest expressed in a lower triple with a greater depth to properly grip the 4860's that come on the 950/990 Adventure Bikes. If anyone else is interested in this, join in as well. If we can get a few takers the cost should be close to the same as the regular setups.
Guy
HPMGuy screwed with this post 04-03-2012 at 10:34 AM
HPMGuy is offline   Reply With Quote
Old 04-03-2012, 11:31 AM   #2
Renner
infamous wrench
Renner's Avatar
Oddometer: 2,177
in, 4860
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton
"...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater-
Renner is online now   Reply With Quote
Old 04-03-2012, 12:07 PM   #3
Beater
Dirty
Beater's Avatar
Oddometer: 3,202
I have an interesting question ... but I have some DRZ400 forks (49mm) and was curious of the design for these triples. I was wondering if your offset was the BMW standard offset (20mm? 30mm?)?
I was also thinking that 49mm would be close enough to 50mm to work? Thoughts?
The DRZ400 triple is nice and beefy, but the offset is ~15mm (guess) and I am unable to make tight turns. Thanks in advance ....
Fred
Fred
'85 R80RT G/Sified <|> '91 R100GS Bumblebee (103K miles and climbing) <|> '73 R75/5 LWB
Airhead Zen: Ride - Repair - Ride - Maintain - Ride - Repeat
Beater is offline   Reply With Quote
Old 04-03-2012, 04:23 PM   #4
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,223
Looks like 38, based on the drawing in another thread.
Old 04-03-2012, 09:22 PM   #5
mendoje
Oddometer: 235
Oh boy, I've been waiting for this thread to start. I'm still in!
One (1) set, for 50mm Extremes, black, including stem and nut, and hardware.
If others are also interested in a group buy for a Sub Mount and Tower Pin bracket for a Scotts damper, I'm also in!
Thanks Guy!
Jeff
2004 BMW R1100S / 2003 Ducati M800Sie / 1986 R80 G/S / 1993 Suzuki RMX250 / 1981 BMW R100RS (Sold ) / 1977 Kawasaki KE100 (1st Bike )
mendoje is offline   Reply With Quote
Old 04-03-2012, 09:30 PM   #6
mendoje
Oddometer: 235
I'm doing the same thing, I've also got some 49mm DRZ400S forks. Here are my thoughts, post # 141:
http://www.advrider.com/forums/showt...696019&page=10
Jeff
Fred
Old 04-04-2012, 03:47 AM   #7
Chadleys1
working on it
Chadleys1's Avatar
Oddometer: 564
Excellent
I am interested in the trees for using the WP front end off the KTM 950/990 on my airhead GS, with the extra depth (drop) in the lower tree.
These triple clamps will be compatible with a Scott's steering dampener set up too, correct? I'll have to start getting some money together for one of those.
The last run of HPMGuy's triples based on R-Dubb's design came out just beautifully from the pics I've seen, and the feedback from the lucky buyers. I look forward to seeing them in person.
Good News !
-Chadley
"It's not a death machine, Mom, it's a LIFE machine" - a motorcyclist
Chadleys1 is offline   Reply With Quote
Old 04-04-2012, 07:50 AM   #8
Beater
Dirty
Beater's Avatar
Oddometer: 3,202
If this is the drawing .... I'm in. I'm pretty sure I can make these work with the DRZ forks (thanks mendoje!), and get another 10 degrees of turn on each side. It does say the offest is 38mm (Thanks Anton!).
I'm in for the 50mm triples.
PS - The diameter of the fork mount is 50mm, correct? I do not see an explicit radius or diameter mentioned. On the left fork mount I do see a radial arrow (bold) that does not have a numerical label.
Fred
Beater screwed with this post 04-04-2012 at 12:50 PM
Old 04-06-2012, 04:15 PM   #9
OZbeemer
OZbeemer's Avatar
Oddometer: 436
In for one.
Since it seems that the cartridge group buy is not going to happen I feel that this is the next best option. I will be in for one as well. I will have to do some research for the project. Am I correct that I will need a full KTM front end? forks, wheel, brake set-up? I have yet to go through all of SOLO LOBO's and Airhead Wranglers write-ups. If anyone has the time I could use a little clarifying of the full set-up.
OZbeemer
OZbeemer is offline   Reply With Quote
Old 04-09-2012, 06:46 AM   #10
hoss18
hoss18's Avatar
Oddometer: 123
triple
Im also waiting to see if the cartridge deal comes off - so far it doesnt look good. Can you put me down for a set of these just in case. Thanks
hoss18 is offline   Reply With Quote
Old 04-11-2012, 10:07 AM   #11
Monterey_BS
On or Off - not sure
Monterey_BS's Avatar
Oddometer: 228
In for a set of triples
I've an '81 G/S in serious need of front end help. I'm not sure of the process here, but I'll pony up for a set of triples, as well.
Monterey_BS is offline   Reply With Quote
Old 04-12-2012, 07:46 AM   #12
OZbeemer
OZbeemer's Avatar
Oddometer: 436
How many do we need to make this worthwhile. I am just wondering about how likely this buy is. With the cartridge deal seemingly falling through, I would like to be able to focus on collecting the parts that I need to do this conversion.
Old 04-13-2012, 07:00 AM   #13
OZbeemer
OZbeemer's Avatar
Oddometer: 436
PM sent
Old 04-30-2012, 04:20 AM   #14
hoss18
hoss18's Avatar
Oddometer: 123
Status?
Bump de di bump bump
Old 07-04-2012, 12:32 PM   #15
HPMGuy OP
Oddometer: 264
Sorry for going AWOL, the shops been going crazy lately leaving me no time for additional projects. Hopefully things will cool of shortly and I can get back to work on this. I'll keep you posted.
For those that are waiting for a set of the triples for the 4860 forks, I have one complete set left that has been unclaimed from the last buy. PM me if interested.
Times are GMT -7.   It's 11:21 AM.
