Old 04-05-2012, 06:38 AM   #1
BuilderBob OP
BuilderBob's Avatar
Oddometer: 70
Electronic Cruise Control
Several years ago I installed and Audiovox electronic cruise control unit on the FJR that I had at that time. It worked great. The K1200GT that I just traded for the GS had cruise from the factory. I liked that too.
The GS has a Wunderlich throttle lock that the previous owner installed, but I prefer a dynamic electronic unit that adjusts for inclines, headwinds, etc.
I'm looking at a Rostra unit. All electronic, no vacuum supply needed. At about $250, it's a lot cheaper than the MC Cruise unit.
So my question is, has anyone installed a similar device? Short of that, can anyone tell me where to look for the VSS wire and how many pulses per second it generates?
I'm taking a trip out west this summer and would love to have the unit installed and operating by then.
My Blog ----> http://soundquarters.com/bobsblog/
BuilderBob is offline   Reply With Quote
Old 04-05-2012, 07:14 AM   #2
GB
Mod Squad
GB's Avatar
Oddometer: 56,671
I haven't seen anyone install such a unit. The MC Cruise works well but it's $pendy.
Old 04-05-2012, 10:24 AM   #3
señormoto
Supermoto Abuser
señormoto's Avatar
Oddometer: 1,110
Sounds awesome! Do you have a link to the model you're referring to?
I have a feeling that there are some decisions being made on certain teams lately to make things more complex in order to ensure a certain technological standard of confusion is met.
señormoto is offline   Reply With Quote
Old 04-05-2012, 11:12 AM   #4
BuilderBob OP
BuilderBob's Avatar
Oddometer: 70
Why yes, I do. Here's a link to Rostra's site: http://www.rostra.com/main/rostra-support.html
I have purchased the universal unit, model #250-1223 with the dash mounted controller (extra).
There are several on ebay, Amazon has them, and I saw them on Summit Racing's site.
First one who figures this thing out has to share with the rest!
Old 04-05-2012, 11:34 AM   #5
rdcyclist
rdcyclist's Avatar
Oddometer: 1,244
There are a number of threads about this in the Oilhead Asylum. IIRC, the guys that used the Rostra unit had to use the magnets on the wheel method of getting VSS.
Search is your friend...
rdcyclist is offline   Reply With Quote
Old 04-05-2012, 11:53 AM   #6
BuilderBob OP
BuilderBob's Avatar
Oddometer: 70
I did a search the parallel forum, but not in the oilhead forum. I'll take a look. I'd prefer to use a VSS signal if at all possible. That not being an available option, I'll use magnets.
Old 04-05-2012, 01:01 PM   #7
Dieselboy
Journey not Destination
Dieselboy's Avatar
Oddometer: 1,158
Found reference to VSS on K12s found at the GPS plug:
http://www.sport-touring.eu/files/e6...c589589-35.php
Long shot, but perhaps our aux plug over the battery carries a signal?
Dieselboy
The Adventure Continues
Dieselboy is offline   Reply With Quote
Old 04-05-2012, 01:28 PM   #8
BuilderBob OP
BuilderBob's Avatar
Oddometer: 70
Cool! You might be on to something there!
I seem to remember that my GT had 3 wires left bundled up under the battery cover. 2 of them were switched power for an accessory (GPS). Always wondered what the third wire was for. Maybe the GS has that wire too.
Old 04-05-2012, 02:41 PM   #9
afterburn
afterburn's Avatar
Oddometer: 11
Hi, I'm the owner of the referenced site. :) A friend of mine put the same cruise control on his K1200S and made a how-to about it. See here: http://www.murphskits.com/catalog/do...200S_Final.pdf
Of course most of that will be useless, but I think it contains some tips and hints you may find useful when you do your cruise on your bike.
afterburn is offline   Reply With Quote
Old 04-05-2012, 03:36 PM   #10
Dieselboy
Dieselboy's Avatar
Oddometer: 1,158
Wow! First post. From Netherlands. Different site. Not contacted. You have some amazing snooping software at work!
Do you know If the Vss rate 6 pulses per minute as I saw referenced for the rt-p elsewhere?
Hope this info crosses over. It would be nice if this works. Thanks
Dieselboy
Old 04-05-2012, 04:15 PM   #11
BuilderBob OP
BuilderBob's Avatar
Oddometer: 70
Thanks afterburn. I got your email. Thanks for the speedy reply! I'll dig into it a little later. Have to install a 685 kit on the KLR this weekend, but your info has been a great help!
I contacted him via his web site. Glad that he posted here as well. Hopefully we'll be on on our way to a successful cruise installation soon!
Old 04-05-2012, 10:36 PM   #12
afterburn
afterburn's Avatar
Oddometer: 11
I have no idea what the pulse rate is. For the power commander all I care about is having usable signal I can calibrate the PCV against.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits | homepage | gallery
BMW K1200S 'tri-color ICBM' | ABS/ESA | HP2S radial masters | Akrapovic | some other bits
2007: N36°08'43", 2009: N71°10'21", 2010: E28°38'54''
Old 04-06-2012, 07:06 AM   #13
Dieselboy
Dieselboy's Avatar
Oddometer: 1,158
Ah....thanks...glad you didn't string me along....(I would have)
Thanks anyway, BuilderBob appears to have the ball under control.
Dieselboy
Dieselboy screwed with this post 04-06-2012 at 08:30 AM
Old 04-10-2012, 03:10 PM   #14
BuilderBob OP
BuilderBob's Avatar
Oddometer: 70
Well, the Rostra CC kit arrived today, so I guess that will be my next project. Have to finish buttoning up the KLR first. I'm wrapping up the big-bore install on that pig.
Old 04-12-2012, 09:05 PM   #15
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,393
Keep good notes and take some pics of the install BuilderBob.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Times are GMT -7.   It's 06:47 PM.
