Old 04-05-2012, 04:46 PM   #1
motoplus40 OP
Oddometer: 32
1150 GS caliper piston mystery
2001 1150 GS, 37,400 mi.
I was following the rear brake pad replacement manual from the hall of wisdom and everything was going well. I was taking advantage of a rear tire renewal and I only wanted to disassemble and lubricate the rear caliper assembly and inspect the pads.
I separated the carrier and caliper but when I went to push back both pistons with a block of wood they wouldn't move. I didn't have a small c-clamp, tried a larger one which really could not get a centered purchase on one of the pistons, and then figured, no problem, when I reinstall I will use the hydraulic brake system pressure to get them moving.
But after I remounted the caliper, the pistons would not budge.
When I pumped the pedal the (original rubber) brake line bulged just above the banjo crimp, which looked a little ominous but I was getting pressure.
Brake worked fine before I disassembled. I didn't touch the foot brake while I did the work. The pistons are equally showing about 5/16" out of the caliper.
Wondering what I try next: more c-clamp pressure, disassemble and rebuild caliper, and how the hell did I screw this up?
motoplus40 is offline   Reply With Quote
Old 04-05-2012, 06:40 PM   #2
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 12,193
Don't know.
But be careful with C clamps on the piston face, they are rather fragile and you could punch a hole in there easily.
(Don't ask me how I know)
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Old 04-05-2012, 08:00 PM   #3
JurgenB
daily rider
JurgenB's Avatar
Oddometer: 396
The c-clamp action has possibly tilted the piston and jammed it. I suggest that you install a suitable grease nipple instead of the bleed screw and press the piston out with a grease pump. After that, carefully clean all parts and pieces, replace gaskets and put the caliper back together. If the piston was jammed, it and/or the caliper bore may be damaged beyond repair.
Jürgen
The Red Rocks
2014 R1200GS
2004 R1150GS ADV parked in Heidelberg
JurgenB is offline   Reply With Quote
Old 04-06-2012, 04:54 AM   #4
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,312
You have a bad brake hose! Not uncommon. It may be blocking the fluid from returning to the reservoir, but in any case it's bad. You saw it with your own eyes.
Old 04-06-2012, 05:42 AM   #5
motoplus40 OP
Oddometer: 32
next step
Ok my brain has been released from inaction:
No more attempts to encourage pistons to go back, and now accepting the fact I have to take this apart.
It may be that the pistons were canted when I tried to push them in. but they resisted even the early attempt to push by hand so I had the idea that they were stuck before..
Yes, I did see the bubble in the brake line just before the crimp which suggested a bad line. Maybe that has something to do with the immovable pistons... (I will also finally stop resisting that I have to change to steel braided lines this year.)
So perhaps the mystery will be solved when I drain the master cylinder and the line to the caliper. If not, it is on to the "grease pressure treatment" to release pistons and then rebuild (I don't even want to think about if I ruined the caliper or pistons, I don't see any replacements for the pistons, that would mean $450 for a caliper, then I would HAVE to win a new bike at the national rally in July.)
Guess I gotta get back to the garage.
Old 04-06-2012, 07:48 AM   #6
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,593
First, disconnect the brake line at the caliper and try moving the pistons, watching to catch any brake fluid that squirts out of the open hole. Personally, I would never introduce anything like grease into a brake system part no matter how well you clean it. It would be better to use compressed air if you want to try to force them out.
Or, just go to the worst case and replace it. I recently had to replace a rear caliper on my 1150GS and got more than a half dozen offers to sell used ones in the flea market from $65 to about $120. Beemerboneyard has used ones for $115. I got a very good, complete used rear caliper for $100/shipped from someone I know in this forum. No need to buy a new one for $425!
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance is offline   Reply With Quote
Old 04-06-2012, 08:10 AM   #7
I GS 1
I 90S I
I GS 1's Avatar
Oddometer: 651
I agree, I wouldn't go anywhere near it with grease. If you did you would end up replacing the whole system
I GS 1 is offline   Reply With Quote
Old 04-06-2012, 08:13 AM   #8
rebelpacket
four-stroke earth-saw
rebelpacket's Avatar
Oddometer: 730
Stop looking to the caliper for the problem.
Anton's assesment is correct. A bulge in the brake line indicates its failed. Since yours is a 2001, if you haven't replaced the lines yet, its most definitely the problem.
Replace the lines with the galfer kit. Do the front ones while your at it if they haven't been done already.
Buy it, use it, break it, fix it.
rebelpacket is offline   Reply With Quote
Old 04-06-2012, 09:04 AM   #9
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,817
Grease won't hurt anything and is a good idea. You can merely flush out the grease after things are working normally. But first, I would try compressed air...keep your fingers away from the pistons while trying compressed anything.......
Anton is likely correct (He usually is) you've got debris in your brake system from the OE rubber lines.
def is offline   Reply With Quote
Old 04-06-2012, 09:36 AM   #10
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 12,193
It helps to fill out your profile.
Where are you?
I can get stainless lines cooked to order at a local aircraft supply.
Old 04-06-2012, 09:39 AM   #11
motoplus40 OP
Oddometer: 32
I am in NYC, specifically in Queens, 5th ManCave on the right.
Old 04-06-2012, 11:05 AM   #12
Beezer
Oddometer: 5,945
happened on my Y2K as well.... the rear line ballooned up. I got a replacement made at the local commercial hydraulic shop for $30. BTW, my front lines went first... they came apart inside and and blocked the fluid from returning so the brakes would stay on. They also barfed rubber hunks into the ($2200) ABS module.
Beezer is offline   Reply With Quote
Old 04-06-2012, 11:32 AM   #13
motoplus40 OP
Oddometer: 32
resolution and denouement
It was the brake line as Anton et al predicted. Separated the caliper from the banjo, pistons went in, pressed on foot brake the bubble started in the brake line, little more pedal pressure, something popped and brake fluid flowed, bubble deflated. I probably added to the problem by twisting the brake line a little too much when disassembling.
So now I am into new stainless lines front and rear. But how far do I go with this renovation? Does Beezer's-barfing-front- brake-lines experience suggest I have to go looking for brake line bits throughout, i.e. rebuild the caliper anyway, and somehow clean out the ABS unit? Beezer, did you actually have to buy a new ABS unit because of the barfing?
Old 04-06-2012, 03:42 PM   #14
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,460
I did this last year after my brake line did what yours did. It bulges, but really it comes apart inside forming a sort of check valve. Fluid gets past the flap, but cannot return back to the master cylinder. Hence: pistons stuck.
You have an '01. No servos. The BMW uses hard-piped brake lines to the ABS unit, so it's really very simple. You have one brake line from the front master cylinder to a hard pipe, which feeds the ABS unit. You have another line from the hard pipe coming from the ABS unit to the cross over, and then the crossover, which is a hard line, to each caliper. The two hard lines are sort of in the vicinity of the front shock. Very easy.
In the rear, you have a hard pipe to the ABS unit from the master cylinder, so no stainless line needed. You will have a short line to the rear caliper from a hard pipe which comes off the ABS. The hard line comes from the ABS almost to the right rear passenge footpeg. Connect to there and then to the rear caliper. Also very simple.
That's the kit you can order from Spiegler. It came in about 4 days and had everything I needed aside from brake fluid. I think the change took me about 3 hours at an extremely liesurely pace and about 7 pints.
From master cylinder to ABS line:
Sort of just above the front shock:
Front crossover
rear brake
I made this one large, if you look carefully you can see both front connections and the rear:
Bike:
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug screwed with this post 04-06-2012 at 04:06 PM
Schlug is offline   Reply With Quote
Old 04-07-2012, 12:35 PM   #15
I GS 1
I 90S I
I GS 1's Avatar
Oddometer: 651
Caution. I would be very careful following this advice the flushing fluid (not specified) and the grease could harm seals/boots etc. and I am not sure how you old now if you got it all out. IMHO You would be best sticking to air
Times are GMT -7.   It's 04:23 PM.
