Old 04-06-2012, 07:11 AM   #1
scapegoat OP
Pushin forward back
scapegoat's Avatar
Oddometer: 2,901
battery cranking voltage drop?
I have a FXDXT that has a OEM AGM in it thats now 5 years old. If it sits for a few days and I take a read just cranking it over the voltage reads 9.5+ -. Voltage after several days of sitting reads about 12.5 12.6. Info Ive read says voltage a couple days after a full charge or ride should still be 12.8. Ive never had a battery stay that far up on voltage that I can recall. Que pasa?
Reality is merely an illusion, albeit a very persistent one.
scapegoat is offline   Reply With Quote
Old 04-06-2012, 07:47 AM   #2
Swinerider
Swinerider's Avatar
Oddometer: 3
Any twelve volt battery should be 12.6 fully charged, more would be unusual, sounds like your battery is just weak (5 years old is an eternity for any motorcycle battery!!!) or you have a heavy draw. I recently had a problem starting even with a new lithium battery eventually found the starter wire right on the starter was a little loose and corroded causing a very high draw when cranking.Replace the battery first, its on its last leg!
Swinerider is offline   Reply With Quote
Old 04-06-2012, 09:04 AM   #3
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,744
12.6 that's about right for most AGMs, but all depends on the manufacturer. 12.74 and above is 100% SOC for an Odissey.
Best battery info out there, charge tables are in there and they do say for AGMs to check with the manufacturer as to what the voltage should be at 100% SOC.
http://www.batteryfaq.org/
Only way you'll know if your battery is any good is with a load test.
Have tools, will travel!
Old 04-06-2012, 09:34 AM   #4
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,352
Do you have trouble with it starting after sitting for a while? Does it have any parasitic draw?
If you are not going to use it for a couple weeks sometime, take a reading and then leave the battery disconnected for that time and see what the state of charge is when you get back. Also, washing the battery with soap and water would be a good idea if you have a concern with it losing a charge.
GreaseMonkey is online now   Reply With Quote
Old 04-06-2012, 04:31 PM   #5
erkmania
Still Adventuring
erkmania's Avatar
Oddometer: 992
10.2 volts is about the minimum you want while cranking. It sounds like your battery is on its way out.
-Sticks and stones, love.
-Insurmountable problems exist in the imaginations of the less traveled.
2011 BMW R1200GS, 2004 KTM 950, 1996 ATK 605 ESDS
erkmania is offline   Reply With Quote
Old 04-06-2012, 04:38 PM   #6
OldPete
Be aware
OldPete's Avatar
Oddometer: 5,667
Replace the battery and go for heavyer gage battery cables.
Big twins benefit from cable up-grade.
OldPete is online now   Reply With Quote
Old 04-06-2012, 07:27 PM   #7
Gray_Rider
Gray_Rider's Avatar
Oddometer: 270
+1000 - general rule is if it drops below 10V at cranking, it is time to replace it.
Steve
Gray_Rider is offline   Reply With Quote
Old 04-06-2012, 07:33 PM   #8
scapegoat OP
Pushin forward back
scapegoat's Avatar
Oddometer: 2,901
Well that solves that one. Thanks Guys
Times are GMT -7.   It's 04:29 PM.
