Old 09-15-2013, 06:16 PM   #76
Gryphon12
Gryphon12's Avatar
Oddometer: 1,325
Is the subframe strong enough to add some frames via that top bolt for the seat? Not good getting even soft luggage if the subframe won't hold any weight. It looks very skimpy from the outside. What is underneath?
1990 Honda NT-650 Hawk-GT
Never doubt that a small group of thoughtful, committed citizens can change the world;
indeed, it's the only thing that ever has. - Margaret Mead
Gryphon12 is offline   Reply With Quote
Old 09-15-2013, 07:18 PM   #77
everetto
everetto's Avatar
Oddometer: 325
Sub frame is strong enough to carry a passenger.
everetto is offline   Reply With Quote
Old 09-15-2013, 09:07 PM   #78
tallrider
tallrider's Avatar
Oddometer: 65
Here is a pic with the covers off. Lots of metal back there. I made a rack that plugs into the sockets where the seat goes.
Made the rack out of 1/2 inch thinwall chrome molly. Works well buts looks a little vintage, maybe I'll try again some day out of carbon fiber. I don't seem to have a pic off it and I am away from the bike.
tallrider is offline   Reply With Quote
Old 09-16-2013, 08:54 AM   #79
Gryphon12
Gryphon12's Avatar
Oddometer: 1,325
Very cool. Thanks very much for the photos.
Old 11-29-2013, 08:12 AM   #80
everetto
everetto's Avatar
Oddometer: 325
Yesterday while riding at a "very good clip" I detected a quick blur out of my peripheral vision; the bar-end slider bolt had loosened up enough that the entire slider/weight assembly flew out, with the brand new CRG Arrow mirror attached - costly little event. Guess I will check the bolts more often and also try some locktite.
Old 12-11-2013, 04:32 PM   #81
The Wolf
Among The Living
Oddometer: 320
I lost a mirror once, too. the motor vibes a lot so it kind of mandatory to check your bolts every few hundred miles. my clutch cover bolts keep loosening up causing oil seepage. i was told that ktmna is now telling their techs to use 5nm more torque than what is listed in the service manual.
also don forget to keep an eye on the rad cap. when summer comes and your bike gets hot, it can loosen up.
My rc is in the shop right now for the ignition interlock system locking up the bike. i feel like ive had every single problem that i could have happen to my 2012. im dissapointed honestly, but i love the bike so much i keep looking past that.
The Wolf is offline   Reply With Quote
Old 12-13-2013, 09:19 AM   #82
everetto
everetto's Avatar
Oddometer: 325
Checked my clutch cover bolts and sure enough they were not snug, no oil seepage yet, but it probably would not have been long.
Instead of buying a new CRG mirror I filed and sanded the road rash and repainted it and put in a new piece of glass. $15 instead of $90 or so.
Old 12-13-2013, 11:15 AM   #83
The Wolf
Among The Living
Oddometer: 320
i use a spot of blue loctite on just about everything that isnt on the motor. has worked out well so far. another few bolts to look at are the three bolts that mount the stock muffler. ive lost all three in two years, and im currently running some grade8 fasteners with lock washers. theyve stayed in place since the switch.
Old 12-13-2013, 01:52 PM   #84
fast4d
Oddometer: 2,289
I use locite on everything. even fairing/body screws. I lost 3 - 4 before I loctite them.
Alan
2011 KTM RC8R
2012 BMW S1000RR
2000 Kawasaki ZRX1100
2013 KTM SMT 990
fast4d is offline   Reply With Quote
Old 12-13-2013, 05:33 PM   #85
tallrider
tallrider's Avatar
Oddometer: 65
I use the CRG's also. Mounted them to the original bar end weights by necking a section where the mirror clamps. The weight is held in place by wedging due to the slope on the bar weights and the end plug. I used a delrin washer here to lubricate the wedge. Grease would also work as long as you keep it off the part that clamps against the inside of the bar. Several thousand miles with no issues.
Old 12-13-2013, 07:02 PM   #86
steved57
steved57's Avatar
Oddometer: 343
I have a 2010 RC8 but Im too stupid to add pics so you will just have to believe me
AMA Earned Life Member
2014 NORRA Mexican 1000
2014 Husaberg FE 350
2010 KTM 990 Supermoto
2010 KTM RC8
steved57 is offline   Reply With Quote
Old 12-14-2013, 08:26 AM   #87
everetto
everetto's Avatar
Oddometer: 325
Lightweight wheels......
I've got the bug for some light wheels; the Marchesini forged are great looking light wheels, but typically quite expensive if you can't find a used set, which has me thinking about a set of those gorgeous BST carbon......
Old 12-14-2013, 12:43 PM   #88
The Wolf
Among The Living
Oddometer: 320
bst's for the street? probably not the best idea
Old 12-14-2013, 01:12 PM   #89
apessino
apessino's Avatar
Oddometer: 1,276
Yeah, I must agree... CF wheels are crazy light and stiff, but also brittle. A friend of mine had them on his 1098, went over a wood plank on the road and the front wheel split.
14 BMW HP4 Competition 13 KTM RC8R 10 BMW S1000RR 09 BMW K1300S
11 Ducati Diavel Carbon Red 07 Aprilia RSV Factory
apessino is offline   Reply With Quote
Old 12-14-2013, 01:53 PM   #90
NuckaMan
Space Available
Oddometer: 350
Once you study and understand carbon fiber technology, you will not want to use it on as a rim.
Body panels, fairings, support structures...sure, but not as a wheel, especially for street use. If you must have the most exotic but don't have military clearance...hold on for a few more years. Wait until nanometal coating technology matures and becomes more commercially available. Than we will see some crazy light wheels that will be safe to everyday use.
2008 BMW GS Adv
2012 Kawasaki Concours 14
2013 Triumph Bonneville
NuckaMan is offline   Reply With Quote
Times are GMT -7.   It's 02:48 AM.
