04-14-2012, 04:14 AM
#46 |
www.ridingacross.com
Oddometer: 181
Good luck!!
LadyCruiser ![]() https://www.facebook.com/RidingAcrossAmerica - coming soon!!! "like it" ![]() http://advrider.com/forums/showthread.php?t=719974 |
04-14-2012, 04:22 AM
#47 |
Oddometer: 211
Listened to the radio interview via the blog. Nice work getting the coverage.
Hope the last minute planning is going well and good luck for the trip. I'll be following it... James
2009 XT660Z Tenere, 1998 XR600R, 1996 XR600R My ride reports: 10 days adventure riding in the Pyrenees, Mountains and deserts, a Spanish adventure , Four days sports touring in France. Or not..., The Slow Way Down - Three days in NSW, Australia |
04-14-2012, 06:40 AM
#48 |
Oddometer: 156
Temporary stall...
We've hit a slight issue which is likely to cost us a few days on the departure date. We managed to get hold of some kick start kicks from Suzuki but whilst fitting managed to screw up the clutch basket. In hindsight it was a school boy error but we attempted to use the lugs on the basket to keep the it positioned whilst we tightened the main clutch bolt.
.... inevitably, one of them snapped. We're sourcing a new basket as I type and will hopefully only cost us a couple of days at max but it doesn't seem to be a part too well stocked here in the UK. ![]() I'm gutted!!
Read more about our round the world DRz 400 trip on our website here: www.toughmiles.com Find us on Facebook here: www.facebook.com/toughmiles |
04-14-2012, 06:41 AM
#49 |
Oddometer: 156
:-) Thanks for following.
04-14-2012, 10:38 AM
#50 |
on the road o'dreams
Oddometer: 5,503
Bad luck, but doesn't look fatal. Other than breaking the basket, how did the install of the kick start mechanism go? Anyone in the UK who knows how to do this install properly? Hope so!
In very early days of the DRZ400 here in the US, Suzuki offered the kick start option for the "E" model version for just $200 (this included Labor!)to anyone who bought a new bike. I never did it, as reports on battery life and starting reliability were very good. My bike never failed to start once in 3 years of ownership, all on original battery. But for your trip, I can understand doing this. Hope it wasn't to expensive. In 2000, the US initially got 2 DRZ400 models. The "K" (kick start only, off road) and the "E" model (electric start only, off road). But within a year (by 2001 or '02 I believe) the DRZ400S was brought in. That is the model you guys have. It is a substantially different machine to the "E" or "K" models. Different head, cams, carb, timing, different sub frame and more. I believe the Stator and electrics are also substantially changed from the E and K models. But the changes to the "S" model bodes well for a RTW travel bike, IMO. A "real" charging system and stronger rear sub frame can only be a good thing on an Adventure bike. Good luck with the Kicker install ... I hope you never need it!
04-14-2012, 01:00 PM
#51 | |
Oddometer: 156
Other than the silly error we made, the install is relatively straight forward. There is a superb step by step guide here: http://mr-cob.smugmug.com/gallery/136763 It includes crucial info not contained in the instructions supplied with the kit so be sure to check it out if you ever install one. We didn't know if the kick start is necessary or not but we started considering being stuck in the middle of a marsh or bog in Siberia for example trying to bump the bike. Not a nice thought. The successful installation of the kick start on the second bike fired the bike up on the second kick. It works like a dream and is remarkably easy to turn over. I must add... the kit is not light. Heavier than I expected but for the peace of mind it brings, I'm happy we went ahead with them. We've managed to source a new clutch basket so with any luck it's only stalled the departure a couple of days.
04-14-2012, 01:22 PM
#52 |
Oddometer: 5,503
Sounds good! Best of luck on your soon to be launch!
![]() If your DRZ's are like my DR650, then the bike will bump start and run even with a dead battery. (be good to know this one way or the other) But I get your point, bumping starting in soft dirt or sand is a PITA. Also, can't recall on DRZ, but the DR650 headlight does NOT cut out when ignition switch is pushed like on some bikes. I know in UK many bikes have headlight ON/OFF switch. I would get in the habit of always shutting off headlight before cranking. Over long run will help battery life. I put a switch on my bike for just this reason. Cheers! Adv Grifter screwed with this post 04-14-2012 at 07:52 PM |
04-14-2012, 02:36 PM
#53 | |
Oddometer: 139
Really looking forward to your trip report, and best wishes on your journey ![]() ![]()
04-14-2012, 06:04 PM
#54 |
OH.THAT'S GONNA HURT
Oddometer: 3,923
To bad your not in the USA, as clutch baskets are a dime a dozen used on ebay. I've had difficulty using the kick starter when cold, but wanted it anyway as an emergency back up. Head light cutoff is easy and a worthy mod in conserving power. I would be leary of using too much electric gadgets on the DRZ, it's only 200 watts at best. If your running extra electrics you really need a way to monitor the voltage. Here's a handy little idiot light.
Here's an all things DRZ for a long list of mods. This maybe too late for you, but watch the DRZ counter shaft for leaks. It is well documented on Thumper Talk, do a search, if it starts leaking it could be a warning that the tranny is going bad. I heartily recommend taking a counter shaft seal, spacer and O-ring, it's a 30 mm socket to remove the CS nut. PLus you better have a steel rear sprocket and not alloy.
2004 BMW R1150RS 1984 BMW R80G/S (wrenching index) 2003 Suzuki DRZ 400S (TAT Prep) One More DRZ does the TAT (Ride Report) |
04-14-2012, 10:54 PM
#55 | |
Oddometer: 1,393
Yeah that dash is scary.............About the cancer death rates being lower? Well, it aint about life style. Its all about lower reporting rates and lower life expectancy. Many cancers appear later in life. People in those countries dont usually see 70 to 90 yrs old which is when most of the reported cancers occur.
04-15-2012, 01:40 AM
#56 |
Oddometer: 128
Very cool!
That seat is near identical to mine. I also ride a DRZ400s and I have five discs missing in my lower back. With the stock seat I was in excruciating pain after 50-75 miles. I snagged a used Russel Day Long seat on ebay with the same wing design. I have regularly done 300-400 miles in a day with no issue now. I feel that general seat design is a MUST for DRZs. I will continue to follow your progress! |
04-15-2012, 02:46 AM
#57 | |
Oddometer: 523
![]() RM125Z in my case...
Here.... my XR250 leaner side car build http://www.advrider.com/forums/showthread.php?t=716993 |
04-15-2012, 07:00 AM
#58 |
Oddometer: 24
Good Luck!
THIS IS HAPPENING! Good luck guys!
04-15-2012, 11:26 AM
#59 |
Oddometer: 347
Nice choice of bikes, you're definitely prepared to take the roads - no, tracks less travelled.
I'm in for sure, have a good start to your trip of a lifetime! |
04-15-2012, 06:52 PM
#60 |
Oddometer: 3,923
all balls update- 10,000 miles rear wheel bearing on the caliper side shows wear and is a little gritty, seal is shot. BTW- best to use steel sleeved axle spacers. The AL ones don't last long.
