02-09-2012, 05:30 AM
#1 |
Misadventurer
Oddometer: 910
XML to GPX File Question
I am trying to download a file to my Iphone Motion X GPS app
The app only works with GPX Files (think) The file I am trying to open is a XML file. Can this be converted to a gpx file?
Calmer than you are. |
02-09-2012, 05:53 AM
#2 |
Scott Whitney
Oddometer: 2,226
Depending on the data format, it might be as simple as changing the filename extension from .xml to .gpx.
02-09-2012, 06:02 AM
#3 |
Misadventurer
Oddometer: 910
When I look at the properties of the file from the source it is shown as a GPX
When I download it it is only possible to download as a XML From Here: http://texasadventure.net/bigbendrideguide
02-09-2012, 09:36 AM
#4 |
Oddometer: 1,138
HogWild has it right.
I'm no computer whiz but hogwild is correct, confirmed by downloading from the link you provided.
On a PC; R click the file and "Save Target", as you said it will be saved as an XML file. R click the file you saved and then "Open with" and find the application you are wanting to use, opened fine with MapSource. If it opens and looks fine do a "Save as" and be sure to select .gpx. I'm sure you could just modify the original file extension but you might as well open it to see if it is corrupt. Not sure how this works on a Mac or phone. I think GPX files are a type of XML. Bruce |
02-09-2012, 10:54 AM
#5 |
Misadventurer
Oddometer: 910
Hmmm...I have tried it about 5 times, and it can only be saved as a XML. I am trying to open with google earth, and I keep getting an error. I don't own a Garmin product, and don't have Mapsource The goofy way I have to load it into my Iphone only recognizes a GPX format, Ill email Motion X and see what they come up with
02-09-2012, 11:33 AM
#6 | |
Rusty 2009 BMW R1200GS Adventure 1999 DR650 2007 DR200 |
02-09-2012, 11:35 AM
#7 |
Are you trying to download it on your iphone? Or on a Mac/PC for transferring to the iphone?. If the first, I can see how that would be an issue.
02-09-2012, 11:48 AM
#8 |
Misadventurer
Oddometer: 910
Thanks for the quick responses.
I am trying to download it to my computer as a GPX, and then I can open it with a nav program from my Iphone after the transfer. I think I can rename it as mentioned before. I think the problem is the Iphone nav app only recognizes files with a GPX file extension
02-09-2012, 11:58 AM
#9 |
Oddometer: 1,138
Agreed, while these are XML they are of a GPX layout. Opening the file in an text editor tells you that and they do open in MapSource and BaseCamp so
How can he change the file extension from XML to GPX without using separate software? Bruce |
02-09-2012, 12:07 PM
#10 |
Misadventurer
Oddometer: 910
Got it, I saved them as a XML, and then email them to a gmail account. I simply Rclick the attachment and save as a .GPX
That seems kinda like going around the block to get next door, but it works.
02-09-2012, 12:13 PM
#11 |
Oddometer: 1,138
So is there an easier way to change a file extension in windows?
Bruce |
02-09-2012, 03:28 PM
#12 |
Scott Whitney
Oddometer: 2,226
Yes, you save it to your hard disk as .XML. Then using Explorer (the file manager, not Internet Explorer), you find the file where you saved it and right-click on the file then select Rename. Then delete the XML and replace it with GPX. It should take less than 10 seconds to do this.
02-09-2012, 05:00 PM
#13 |
Oddometer: 1,138
That's what I thought but on my Win7 machine that changes the name to .gpx but the "type" and file properties still say XML.
Bruce |
02-09-2012, 05:13 PM
#14 | |
Oddometer: 1,422
Having a look at the website (web development is my profession), it appears to be misconfigured. I don't encounter the same problem you have when I download them, but I do see a different/related bug. Looking at the download for "Ride 1: The Real River Road", the filename is "the_real_river_road.gpx" on the website. If the name is anything else when you download it to your computer, then you should be able to rename it to "the_real_river_road.gpx". Are you using a Mac or PC? What web browser are you using? That will help us give you accurate instructions if you're not sure how to rename the file. Once you've got the file named correctly, the best way to import files into MotionX is using iTunes Drag and Drop file management. You can find instructions for this in the MotionX manual. Also, It would be a good idea to email whoever made the website and let him know his server is miss-configured (he needs to properly setup the mime type header for those downloads).
We're building a community to help noobs choose the right oil: Stack Exchange's Proposed Motorcycle Community abhibeckert screwed with this post 02-09-2012 at 05:26 PM |
02-09-2012, 05:23 PM
#15 | |
Oddometer: 1,422
Beware sometimes your computer will only show you part of the name, maybe the real name is "blah.gpx.xml" and all it shows is "blah.gpx". Usually you can see the full name in properties, to verify if this is happening.
We're building a community to help noobs choose the right oil: Stack Exchange's Proposed Motorcycle Community |
