04-29-2012, 12:31 PM
#76 |
Oddometer: 7,981
Yo B,
Aren't you gapping those rings a bit loose? .0020 for the top ring?? I thought it was .0012. And how in the hell does a pistons compression ratio dictate which ring set it gets??
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
04-29-2012, 03:15 PM
#77 | |
CDI REPAIR
Oddometer: 3,312
Well for your 2nd question.........i have no idea,,,,it seems the 10.5 gets a 2mm oil rig spacer.......and the 11.25 gets a 4mm spacer......CW thinks it`s due to them being to cheap to manufacture a new mold...and they just move the pin hole for different compression ratios ..and this moving the pin down makes it so they have to go with thinner oil ring spacing ..not sure on it though.. Now for your first question...i had this all typed and ADVrider lost it... ![]() ![]() Alrighty then............ JE specs the ring gap on the top ring on their 2618 alloy pistons as: BORE X .0045 So 4.015 x 0.0045 = 0.018 and that`s their minumum gap.... The second ring specs at : Bore x 0.050 So 4.015 x 0.0050 = 0.020 These are minumum gaps.....i sety my last 101mm at these,,it was fine i thought... CW said i should go 20 thou on the top ring and 22 thou on the second ring due to it being an air cooled engine which can run hot...and butt the ring gap together....since it`s only .002 over minmum spec....sounded fair to me ![]() ![]() B
01 XR650L,102mm JE 11.25:1 ..NX650 second gear,FMX650 fifth gear,ported CW head,KW valve train,MegaCycle 173X25.Cycra probend CRM,Scott`s sharkfin,Xr`s Only casesaver.FMF "Q2",Sutton Oil Cooler,Clarke 4.0,Red XR`s Only skidplate,Doubletake mirrors,Manracks Rotopax rack..one Minature Schnauzer
techforlife screwed with this post 04-29-2012 at 03:25 PM |
04-29-2012, 03:43 PM
#78 |
Oddometer: 7,981
Just looked at the OE service manual.
Top ring .008/.0016 Second ring .014/.022
04-29-2012, 03:45 PM
#79 |
CDI REPAIR
Oddometer: 3,312
So.........CW said to prime the crank,,i thought this was a great idea.....gets some oil into it well before start up...so i took a squirt bottle full of oil...poured it into the crank end.........
![]() Then hit it with some air to get it spraying out the rod thrust washers.. ![]() Then i refilled the crank and left it full.i expect most of the oil will not stay in there,,but prelubing anything is a great idea... ![]() ![]() So then i had to carry this lump of crap up the stairs and across the yard to the garage,,good thing the garage is close,,,these are not fun to carry... Then i took and went through 2 rolls of masking tape and cardboard to prevent scatching the crap out of the new paint work... ![]() I even add more cardboard,,made no difference...still scratched the f`in paint..........f`in powdercoat..hate the shit....chips to easy...and when you tighten bolts it splinters off........won`t do that again.........or maybe i will,,,,it`s easier,i`m lazy..........screwit... ![]() So i got the heavy lump of crap in..no fun there,,never is ![]() ![]() Then,,since i had beer and it was fairly nice out...i put Marks cooler back on..![]() And the passenger front peg,bracket,skidplate and rear brake lever........and bled the rear brakes for fun... B
techforlife screwed with this post 04-29-2012 at 03:55 PM |
04-29-2012, 03:47 PM
#80 | |
CDI REPAIR
Oddometer: 3,312
Yup.good for their OE rings maybe..ring gap depends on cylinder expansion and mostly the material the rings are made of,,different rings expand at different rates.....but to be safe i go with the piston manufacturers specs everytime,,,,,,CW confirms this too..... B
techforlife screwed with this post 04-29-2012 at 03:52 PM |
04-29-2012, 03:50 PM
#81 |
Oddometer: 7,981
B,
BTW... The lump goes in MUCH easier with the oil feed hoses OFF...
04-29-2012, 03:59 PM
#82 | |
CDI REPAIR
Oddometer: 3,312
Yeah.i know........but they are a pain in the arse to get in after i find...the inner bolt is a real prick to get at,,even with flex sockets ....i left them off last time i put it in,,it was a little easier,but i was swearing a blue streak trying to get that 8mm bolt in![]() ![]() B
04-29-2012, 04:10 PM
#83 |
CDI REPAIR
Oddometer: 3,312
![]() B
04-29-2012, 05:40 PM
#84 |
Oddometer: 7,981
Oil Line Bolts
Oh Man, that shitz easy. 1/4' drive wobble socket with a 6" extension. And to keep the bolt stuck to the socket just put a dab of wheel bearing grease in it.
EASY PEASY
04-30-2012, 06:48 AM
#85 |
Oddometer: 660
Looks Like Fun
Really enjoying this thread and made a few observations:
RZ Rob |
04-30-2012, 06:56 AM
#86 |
Oddometer: 7,981
What's the matter with canned beer??
04-30-2012, 07:36 AM
#87 | |
Oddometer: 3,809
"Deeply flawed people make deeply flawed decisions." |
04-30-2012, 02:09 PM
#88 | |
CDI REPAIR
Oddometer: 3,312
Thanks Rob.......i need the encouragement.........with the shit i got at work with employees thinking they don`t need to work i`m finding it hard to be motivated when i get home,,instead of drinking my face off ![]() ![]() I painted anything black that looked crappy,,except the pegs,,,turned out good,,,,,,IMS pegs..........well i got ebay 13 dollar cheapies on here,,seem to work well ![]() The tires are 5.10 -18 rear........they work well in wet rocks,,river crossings and fairly decent in gravel........in mud they are freekin scary as hell........so in the spring/fall i run either an MT21 rear or D606......on the front i like the MT21 all rear round.......I`ll see if i can get the wife to show a test run up the street ,,but i have no camcorder so it`s gonna be from a digicam at best.unless i get off my arse and get a GoPro ![]() ![]() ![]() B
04-30-2012, 02:12 PM
#89 |
CDI REPAIR
Oddometer: 3,312
Yup,canned beer in the garage.........i don`t like beer bottles in the garage as i`m forever knocking them over,,cans are shorter,,,,,,don`t get knocked over as easy,,,and i`m not licking the floor when i spill em ![]() ![]() ![]() B
04-30-2012, 02:18 PM
#90 | |
CDI REPAIR
Oddometer: 3,312
But.......a higher comp piston will usually run hotter than a lower comp one,,,and that affects the gap for sure........ ........... IMHO anyway....... ![]() So hows the KLR running Chris ![]() B
