Old 05-05-2012, 06:01 AM   #151
JRWooden
Oddometer: 4,268
About a month ago, I contacted one of the major electronics importer shops.
They figured finding the part would be a cinch (I gave the both the -12 and the -20 P/Ns),
they have offices in Japan and spread across Asia...
The guy came back empty-handed about a week ago....
PS:
If you have not read the latest on this thread:
http://www.advrider.com/forums/showthread.php?t=706033
(page 27 - post 399)
BMW has re-designed the flywheel to allow the stator to be cooled by air/oil flow....
JRWooden screwed with this post 05-05-2012 at 06:19 AM
Old 05-31-2012, 03:13 PM   #152
lawe
lawe
Oddometer: 141
I had luck and got a Shindengen FH020AA regulator from roadstercycle.com. Don't think he got any left though....
Got the local shop to cut and bend a stainless bracket
Cut the old wires, did some soldering and mounted the bracket. As You can see I moved the regulator a bit up/forward compared to stock since this little baby with it's connectors is a bit longer than the stock r/r .
Almost done! (I know: They are owersized. But the wire was in the package and I think they look nice )
Done!
And the result at idle after 30 seconds
It's no problem mounting the regulator. It took me an hour or so. It fits nicely where the stock regulator is. The hard part is getting hold of a Shindengen regulator.
Hopefully my new Deka battery will have a long and prosperous life now.
Lars
Umeň, Sweden
BMW F650GS -05, F800GS -08
lawe is offline   Reply With Quote
Old 05-31-2012, 03:48 PM   #153
ebrabaek OP
Oddometer: 4,763
Done!
Det ser findt ud..... Very nice and clean install..... At least your battery will be good from here on out.....
Hej hej..
Erling
Old 06-02-2012, 07:36 AM   #154
JRWooden
Oddometer: 4,268
Lawe:
Very nice!
If you saved the old harness plugs could you please post the part numbers and mfg. data from them?
I am looking into an alternate fix for the crappy stator and need to source plugs.
If you don't have them no big deal I'll take mine appart when I get home ... I'm on the road now and don't want to be messing with stuff at the moment
Old 06-02-2012, 07:56 AM   #155
lawe
lawe
Oddometer: 141
Originally Posted by JRWooden View Post
Lawe:
Very nice!
I didn't touch any harness plugs on my install. I just cut the wires 3 inches from the stock regulator and soldered new wires onto them. You can see in one of the pictures where the yellow ones from the stator are soldered with the fat red ones.
Lars
Umeň, Sweden
Old 06-02-2012, 06:34 PM   #156
JRWooden
Oddometer: 4,268
Lars:
Ahhhhhhhhhhh ok, thanks I wasn't sure which side you cut into ... better the R/R side to be sure!
Old 06-07-2012, 04:49 PM   #157
ebrabaek OP
Oddometer: 4,763
Ok....so after many busy days... I finally got to making the aluminum bracket for the R/R......Left...Aluminum...right.... ummmmm... CF....
Erling
Old 06-07-2012, 09:00 PM   #158
JoelWisman
JoelWisman's Avatar
Oddometer: 1,392
Looks awesome! Now if you really want to go all out, sand or blast it till the finish is matt, or anodize it and you will have the maximum in heat conductivity, radiation, and emicivity, but that will be overkill :)
Owned to date. Honda Aero 50, Honda Elite 80, Honda Elite 250x2, Suzuki Katana, Suzuki RF600, Yamaha YZF1000R, Kymco Xciting 500, Suzuki GS500, Suzuki Burgman 650, BMW F800GSx2, BMW S1000RR, Aprilia Scarabeo 200, Aprilia Caponord, Aprilia Sportcity 250
I love and miss you Jeneca and I'm sorry.
JoelWisman is offline   Reply With Quote
Old 06-08-2012, 06:29 AM   #159
ebrabaek OP
Oddometer: 4,763
Thanks Joel......I am planning on having it anodized.as it sort of stands out like this. I was sitting looking at the setup,and was pondering weather the bracket could act as a negative heat transfer....capturing all the engine heat...delivering that to the R/R..... But I suspect that that heat is less temperature wise than the heat coming of the R/R. Been a while since i worked thick aluminum.... Almost ripped off my arm when the hole saw caught....
Erling
Old 06-08-2012, 06:47 AM   #160
JRWooden
Oddometer: 4,268
Here I have a slightly different opinion than Joel.....
REAL overkill would be sandblast then anodize and THEN apply heat sink ("thermal") grease to the metal-to-metal contact points between the R/R and the bracket, and the bracket and frame-tube
Old 06-08-2012, 06:52 AM   #161
ebrabaek OP
Oddometer: 4,763
...And have the beverage storage container drain relocated to the R/R cooling fins....where after it drips down on the stator case..... Now were talking.....
Erling
Old 06-08-2012, 06:55 AM   #162
JRWooden
Oddometer: 4,268
Originally Posted by ebrabaek View Post
...beverage storage container
Please post details on this farkle immediately ....
Old 06-08-2012, 08:11 AM   #163
ebrabaek OP
Oddometer: 4,763
Shhhhhhh.... I already have said too much......
Erling
Old 06-10-2012, 10:17 AM   #164
JoelWisman
JoelWisman's Avatar
Oddometer: 1,392
Send me a chilled beverage container immediately! My stator and R/R were designed robust from the factory, but if we could add a pump and a hose I could run it up my jacket to my coolmax garments that are supposed to last hours but dry out immediately. It's fracking hot in Missouri!
Old 06-10-2012, 10:55 AM   #165
ebrabaek OP
Oddometer: 4,763
Erling
Times are GMT -7.   It's 03:51 PM.
