Old 01-29-2013, 10:18 AM   #31
Stroker
motorcycle traveler
Oddometer: 182
shocks
My rig is on the heavy side but a Wilbers model 641w/option 625(remote adjustable preload) and a 59/59-245-175 coil spring works for me. I believe that the Paralever geometry is slightly different between the 1100 and 1150 models. If you have a sway-bar the sidecar and rear suspension will affect each other as well. On the front I have a YSS shock with a Hyper-Pro coil spring, 1cm longer than stock with adjustability for another 1cm. This takes care of the smaller front wheel. I'll check the front coil spec ASAP.
Stroker is offline   Reply With Quote
Old 01-29-2013, 11:29 AM   #32
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,804
Originally Posted by eastbloc View Post
My OEM front shock has given up the ghost after 12 years of duty -- I find myself bottoming out over speed humps and big potholes.
Who has replaced their front, with what, and what parameters? Did you go for a stiffer/longer/shorter spring? I see it as a good opportunity to boost up my ground clearance, which has diminished considerably from the steering mod combined with the Stroker front wheel. I do have a spare Adventure shock laying around somewhere, which might do the trick and last a few more thou, but I'd rather have it sorted for good seeing as how I have proper shocks on the side and the rear now.
A couple of thoughts my fronts got a 12-56 with the shortened A frame the lever compressing the spring is shorter I don't seem to need as much spring. One of Strokers wheels and my install of a 145/65/15 front tire tipped me down, it didn't seem to make much difference in handling but I was down to about 6+." clearance under the sub frame, I had no pre load on front Ohlins cranked in 1/4" pre load and a 3/8" spacer at top of front shock and my subframe sits level. 65 series tires front and rear.
While in garage this morning I checked my other GS it has a shortened torque arm in the rear, that pulls the front end up its got just over 8" under the skid plate, Tug GS has just over 7" I bought another billet torque arm and will be shortening it to see if I can get a little more height.Even for a serial tweaker this sidecar stuff is tedious. DB
Patience: A minor form of despair disguised as a virture.
Ambrose Bierce
davebig is offline   Reply With Quote
Old 01-29-2013, 09:26 PM   #33
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,916
I got my stock wheel with a DMC trail reducer, and I use an Ohlins 216 shock with a Adventure-length shaft. It has a 15/62 spring which is rated at 354 lbs/inch. Last summer was the first season using it, and I was really pleased with it.
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 03-28-2013, 07:00 PM   #34
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,804
Ordered a New Rear Shock
http://www.yacugar.com/products/shoc...k-options.html
Mikepa's images of busted Ohlins, gave me pause to wonder, my current shocks have allot of miles but not many with a chair.
I called Ted Porter :http://www.beemershop.com/ in CA about buying a Wilbers for the rear of my CSM GSA rig, I've been one of Teds customers before and like him.I have Ohlins and have no complaints but only about 4k miles with chair. He suggested the Yacugar it's on sale and has a 16mm shaft and steel body, they and Hyperpro are evidently the leftovers from WP that KTM acquired and moved to Austria. Ted had lots of reasons that he felt Ohlins were not sidecar suitable mostly cause they are lightly built as a performance shock.They have 4-5wk lead time so we shall see.DB
Ambrose Bierce
Old 03-28-2013, 09:28 PM   #35
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,916
DB--How big a spring you getting?
WUMPA
Sidecardogs.com
Old 03-28-2013, 10:17 PM   #36
eastbloc
comprador bourgeois
eastbloc's Avatar
Oddometer: 1,356
If I recall correctly, I got a 500lb spring on my Ohlins rebuild (or whatever the stiffest possible from the OEM was) and it's perfect for me at 235lbs.
eastbloc is offline   Reply With Quote
Old 03-29-2013, 05:01 AM   #37
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,804
Good question, they demand that they take your info and select what spring Yacugar thinks is right to start out with or they won't warranty the shock should it be damaged, so I estimated the chair at 350,GSA with Jesse luggage etc remembering that I think you scaled yours and said it weighed 850ish I said it should come in around 900ish.DB
Ambrose Bierce
Old 03-29-2013, 10:56 AM   #38
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,916
Interesting approach. Wouldja ask Ted to find out what spring they end up choosing for you so you can post it up here or on your "small Schnauzer" thread, then later you can tell us if they guessed right or not?
FWIW, on my rear Ohlins, I have a very very big spring, I use no preload (for maximum travel and most comfortable on-road ride), and I have the rebound damping turned up pretty high.
WUMPA
Sidecardogs.com
Old 03-29-2013, 11:26 AM   #39
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,804
I had planned to post, I'm up two numbers over what Ohlins like for 1150gsa's spring rate per Stieg Pettersens recommendation for loaded GS's and it felt too stiff but it could be the spring roads etc, I've wanted a spare shock as I have a spare front Ohlins so as not to be caught with a broken rig for too long, but the swaybar adds spring rate also and I'm cranking in a little swaybar today.DB
Ambrose Bierce
Old 03-29-2013, 07:28 PM   #40
brstar
brstar's Avatar
Oddometer: 457
Laugh Founales
Bought this fournales shock (unused but cheap) second hand a few years back. It was to fit a GS 1150 I think but may be an 1100. Next to it is the stock shock from my Vstrom that was not up to sidecar duties so I adapted the Fournale to fit and it works a treat so far. Ride height? Just add more pressure. gives a very smooth ride and is next to impossible to bottom out. Bonus for me was a bit more ground clearance over the Suzuki shock.
Down side?
A bit tedious to adjust pressures.
Pricey new and it would be better if I had a sway bar fitted as it leans a bit in corners.
For some they may be nervous about sudden pressure loss making the hack all but unridable but it is not my experience so far.
Oh and I had to get a special hand pump rated to 600psi as I run between 300 to 400 psi. The shock is rated to 4000psi fail I believe.
I know this is about Beemers but the shock is applicable.
Cheers Bruce
brstar is offline   Reply With Quote
Old 04-03-2013, 07:17 AM   #41
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,804
Front toooooo !
I thought about it some more and remembered "half measures availed us nothing" called Ted Porter and fount the Yacougar fronts also have a 16mm shaft and steel body and ordered one of them also.DB
Ambrose Bierce
Old 04-03-2013, 09:08 AM   #42
claude
Sidecar Jockey
Oddometer: 3,824
I know there are many knowledgeble people involved in thsi discussion but for the newbies It is important for them to realize that there will never be a perfect shock under all conditions. What works will work but it can always be improved upon when conditions change. Establishing a decent baseline is a big plus and from there fine tuning can take place for conditions at hand and of course riding styles. If we all ran on the same surfaces all the time and with the same outfits and driving styles we could compare apples to apples a little easier. Good shocks are a good thing...personally my own outfit lacks good shocks in a huge way but it still gets around pretty well. Of course 'rebuildable' is aplus as well as options to change spring rates. The discussion of spring rates can also be apples to oranges of course. This is especially true on the sidecar itself as there are too many variables on how they are mounted as far as angle goes and where they are mounted on the actual swingarm in relation to the axle and also the length of the swingarm would come into play. A while back there were negative reports of progressive shocks failing on some sidecars. Much has to do with how the whock is mounted and so forth. To help alleviate the problem Some went to twin shocks. Was this th eanswewr? Who knows. We have yet to have a shock failure over there using asingle shocks even though we have had rigs in south america and south africa as well as one heading across russia and siberia soon. Will there be shock failures? Probably at some point as they are a mechanical device. Carry a spare? Not abad idea if one is in the true outback . Thanks Davebig...will be putting on your shocks soon.
Claude
http://freedomsidecars.com/
claude screwed with this post 04-03-2013 at 09:23 AM
Old 04-03-2013, 09:57 AM   #43
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,804
Claude
There he goes again with his rational thought program !! Claude we're in a world of non mechanics who name their rigs and think problems stem from bad karma !
Your kinder than I am, they make me shake my head and wonder.
I wonder what a BMW engineer would think if you told him you where going to overload his tires, brakes and suspension by about 40-50% and you expected everything to work just dandy !!!!!!! LOLOLOLOLOLOL
Ambrose Bierce
Old 04-03-2013, 10:45 AM   #44
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,321
He would say "Das ist sehr gut!", but deny it when the warranty people ask about it.........
apologies for incorrect grammer, way too many years since high school German.
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 04-03-2013, 11:04 AM   #45
claude
Sidecar Jockey
Oddometer: 3,824
Boys and Girls we are sidecarists..and we are outside the box. Actually ( seriously whatever) we are looking more and more into other shock options moreso related to dual track vehicles. The cornering forces and handling characteristics we contend with in the sidecar world are different than in the solo bike arena. Also the ones who manufactiure shocks for solo bikes have their market and are good with that...and...rightfully so. Sidecars are NOT motorcycles and never will be. So...no slams here to the shock manufacturers at all but there may be better solutions to meet our known compromises than many of us are really aware of as of yet. How about that for a bunch of words that really said nothing? lol.
Claude
Times are GMT -7.   It's 04:07 PM.
