Old 02-20-2014, 10:09 PM   #2881
Rixrider
Oddometer: 26
Great report from VN Noah!
If I hadn't done way too many trips to China/ VN over the last 28 years for work in the factory towns, I'd say that looked 'pretty interesting'!
As I begin some serious mods to my 2013 690, I'll be looking forward to your upcoming wrenching and riding.
Keep at it! Best report/ story going!
RS
Rixrider is offline   Reply With Quote
Old 02-21-2014, 05:13 AM   #2882
RoninMoto OP
Wanderer
RoninMoto's Avatar
Oddometer: 1,692
Bike work
I already posted this in the 690 wunderlust thread but I thought I would paste it in here also. You know, shameless self promotion.
If any of you have ever traveled by motorcycle in Asia, you know saying driver suck is an understatement.
I installed a Baja design Onx lightbar under my 990ADV headlight. It fits nicely. I had previously wired a 2 way toggle to my high beam wire. Now I can switch between the BD Onx or my 55w high beam. This also allows me to use the flasher and handlebar switch to turn the BD Onx on and off. I think this will be really nice way telling oncoming traffic to get the fook out of my lane.
A simple schematic
Mounting plate. I was worried that the aluminum I mounted the bracket to would break over time. On the sides you can see stainless brackets that take out any vibration by supporting the weight of the light.
Katriana is loving the attention.
690 Rally clutch cover. I was lucky enough to buy one from Pyndon.
There are 5 reasons it is awesome and why KTM should install it on all 690s.
1. Easy access to the clutch.
2. Easy access to the oil fill and it is on the back of the clutch cover so it stays cleaner.
3. Steal thread inserts for the oil filter cover.
4. It looks badass.
5. I can put the bigger rally clutch in.. you know.. for if I need that sort of thing.
I also Rewired my whole charging system. Mosfet FH020AA REG/Rec from Roadstercycle, brand new stator and new wire back to the batter. Also some new grounds.
The black wire from the RR is the ground back to the battery. The blue wires are and extra frame ground and then the grounding point on the Navigation tower bracket. Also, when you route the wires from the stator, there is a lot of room behind the Jug. I ran the wires in the same location as the Crossover fuel line for the front tanks.
Also, When I entered Cambodia, I dropped my skid plate because I broke the aluminum bracket. With access to a drill press, hacksaw, grinder and a vice.. I made these some nice brackets to fix her.
I couldn't find a spacer that was 10mm ID and 20mm OD but they had a shitload of washers that were correct size. So a 120mm long bolt, 5 washers on each side and I was back in business. The distance from the center line of the big bolt to center line of the small bolt is about 32mm... I think
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 02-21-2014, 07:15 AM   #2883
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,548
looks pretty bomber, any thoughts of the new skid plate mounts failing? How bad would the consequences be?
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 02-21-2014, 10:17 AM   #2884
Jbone11 11
Jbone11 11's Avatar
Oddometer: 742
Lovin' that clutch cover. As a Ducati guy first and a KTM guy second this is one of the things that kills me about the Austrian design. Say what you will about the italian steeds, they are super DIY friendly compared to any bike I've worked on. Japanese or Austrian. Case in point is that Clutch cover you put on there....the cover on the 748/916/996 series bikes (among others) is much the same. Sure its a dry clutch on the Ducati, but the simplicity of design is there. Great design is one Italy's greatest exports IMHO.
Anyways, great update, good job on the mods and good luck down the road ;)
2011 990 ADV
2000 996 SPS (SOLD)
2002 748E Bip
2003 Honda Hornet 600 (SOLD)
1969 BSA Royal Star - Let the Resurrection Begin!
Jbone11 11 is offline   Reply With Quote
Old 02-21-2014, 10:41 AM   #2885
bbenn75820
Oddometer: 1,082
+1
The new bracket looks 1/2 as thick as the broken one, will it hold?
Just thinking out loud
bbenn75820 is offline   Reply With Quote
Old 02-21-2014, 12:41 PM   #2886
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,582
Originally Posted by bbenn75820 View Post
+1
Looks like new is steel vs. old being cast aluminium. If so should be better.
Love the post Noah. Fixing stuff is all part of the adventure!!!
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 02-21-2014, 01:27 PM   #2887
The Reverend K
fair to middlin
The Reverend K's Avatar
Oddometer: 16
Completely envious! IN!
keep the rubber side down
The Reverend K is offline   Reply With Quote
Old 02-21-2014, 06:45 PM   #2888
RoninMoto OP
Wanderer
RoninMoto's Avatar
Oddometer: 1,692
This is true. Its 4 or 5mm thick steel instead of cast aluminum. I think it will last longer than I will.
Old 02-22-2014, 12:51 AM   #2889
MeinMotorrad
MeinMotorrad's Avatar
Oddometer: 1,514
Beware of electrolytic reaction between steel and alloy. The bolts, hangers and the sump guard will be affected. May take some time but it will happen.
'12 KTM 690 Enduro R
MeinMotorrad is offline   Reply With Quote
Old 02-22-2014, 03:44 AM   #2890
RoninMoto OP
Wanderer
RoninMoto's Avatar
Oddometer: 1,692
Vietnam Video Part 2. (Finally)
I finally got a connection that was good enough to upload the memorizing conclusion
Old 02-22-2014, 04:43 AM   #2891
tommymerle
advwanabee
tommymerle's Avatar
Oddometer: 367
Whew!
2000 Aprilia Pegaso, 1977 XT500
tommymerle is offline   Reply With Quote
Old 02-22-2014, 05:57 AM   #2892
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 840
WOW Sounds like a beer or 2 was in order that night!
sdd04 is offline   Reply With Quote
Old 02-22-2014, 06:08 AM   #2893
moto rrad
ADV n00b
moto rrad's Avatar
Oddometer: 101
Taco Taco
If you're in the mood for some mexican food while in Cambodia, go visit the fine establishment of Maybe Later in Sihanoukville. The taco commander Casey will take care of you
Suzi XF650 "Freewind"
moto rrad is offline   Reply With Quote
Old 02-22-2014, 06:31 AM   #2894
azbnd
azbnd's Avatar
Oddometer: 10
Thumb Excellent!!
Epic adventure and RR! Thanks for sharing....keep it coming!
azbnd is offline   Reply With Quote
Old 02-22-2014, 06:52 AM   #2895
yokesman
Oddometer: 518
When using steel against al,use al washers as a parasitic that way they take the chemical action verses the hard parts,use a zinc chromate primer on the bolts and washers when installing . Do like more clearance on parts that may take a hit.
yokesman is offline   Reply With Quote
Times are GMT -7.   It's 06:55 AM.
