Old 01-06-2013, 11:46 PM   #1171
WIBO
Will it buff out?
WIBO's Avatar
Oddometer: 3,166
Any pics Noah of the strip down etc?...
By the by I received your Xmas card...thanks for the kind words....did you get the last video I sent you ?(of you off road on a trail taken with my helmet cam?)If not I can send it again.
The Suit:What would you condsider to be your greatest weakness?
Me: Honesty.
The Suit: Honesty? I don't think honesty could be construed as a weakness.
Me: I don't give a fuck what you think.
WIBO is offline   Reply With Quote
Old 01-07-2013, 07:09 AM   #1172
RoninMoto OP
Wanderer
RoninMoto's Avatar
Oddometer: 815
By the by I received your Xmas card...thanks for the kind words....did you get the last video I sent you ?(of you off road on a trail taken with my helmet cam?)If not I acan send it again.
I got that video. Thanks
And here are a few photos. The bike has 50,000 km on it now.
My sweet workshop.. err... parking garage.
Removing the valve cover..
Old ones...
Here I have removed the Exhaust valve. I put a ziptie on the cam chain to keep it in the right spot when i am removing the cam to do the valve clearance. You might also notice the automatic decompression on the cam lobe. It has some wear and i suspect this is what made the roller loose its hardening. I will be replacing the cam and decomp in georgia to be sure this doesn't happen again.
New ones in and valve clearance done! ready to go get stuck in a snow storm...
This was taken about 1/2 hour ago. I was hoping the black sea would keep the snow away. I had snow and/or rain all day. If it keeps up over night I probably won't be going anywhere tomorrow.
Noah 08 KTM 690 ADV. 52,000 km. 25 countries. 4 continents and counting.
Open-Exporers----->A collection of travel blogs
Old 01-07-2013, 07:24 AM   #1173
MeinMotorrad
Oddometer: 159
Tools
You must carry a pretty comprehensive tool kit to be doing all this work. Torque wrench or just estimate?
I'd be interested to know what you are taking with you tool wise - I'm trying to decide what not to take on an extended tour this year - it all takes up room and it's heavy.
MeinMotorrad is offline   Reply With Quote
Old 01-07-2013, 07:24 AM   #1174
kwakbiker
kwakbiker's Avatar
Oddometer: 503
Strap the board to the front wheel and drive it thru
2006 Versys
1990 XT350
More fun being upright
kwakbiker is offline   Reply With Quote
Old 01-07-2013, 07:36 AM   #1175
RoninMoto OP
Wanderer
RoninMoto's Avatar
Oddometer: 815
If I only brought 1000 Kold Kutters...
Old 01-07-2013, 08:10 AM   #1176
WIBO
Will it buff out?
WIBO's Avatar
Oddometer: 3,166
OK Noah...
Good to see the pics.......
I'll send more video when I get more time.....
Keep at it!!!
Me: Honesty.
Old 01-07-2013, 08:13 AM   #1177
kwakbiker
kwakbiker's Avatar
Oddometer: 503
Would be rude not too
2006 Versys
1990 XT350
Old 01-07-2013, 08:51 AM   #1178
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 3,887
Looks like you could use some Tucano Urbano products..
Ever seen them?
'12 Kymco Downtown 300i ABS, '08 Yamaha FZ6n S2 ABS
SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125
My Flickr gallery
Cortez is offline   Reply With Quote
Old 01-07-2013, 09:32 AM   #1179
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,015
Send a message via Skype™ to Low594
Ever seen them?
I was thinking the same thing!
Inmate Corrado113 sells these
with these on and my grip heaters, I was fine with my summer weight gloves in 26*F weather, rain or shine, for my 2 hour commute before sunrise!
Here is the thread:
http://advrider.com/forums/showthread.php?t=487221
'99 KTM 640 Adventure R
East Bay Weekly Coffee
Support your local creep! CREEPS MC
Low594 is offline   Reply With Quote
Old 01-07-2013, 10:31 AM   #1180
RoninMoto OP
Wanderer
RoninMoto's Avatar
Oddometer: 815
Don't think I missed you... Needed to get a pic. I recently added some more stuff. I hope you can see the pic ok.
I'll talk about the ones that are different from the KTM ones.
-Computer and TuneECU W/cable to connect to KTM. I have to thank Beany for this one. I want to be able to troubleshoot everything.
-Calipers. A recent addition. Very nice when doing valve clearances if you can't read the shim. Also, this winter I have a feeling I will be checking the whole bike.
-Multimeter. I'm and electrical engineer. I felt lonely with out one. How do you track down an electrical problem with no tools? I also like checking voltage in the wall sockets where I stay.. to see how close it actually is to being "ok" power
-Craftsman 6 in 1 screw driver. The KTM screwdriver sucked. And the larger nut driver works on an 8 mm hex.
-Allen keys and Torx keys. I didn't like the t-handel/loos allen keys. you can loose them. (i lost them before my trip started)
-Bluepoint 1/4 inch drive socket set. 6-14 mm. Bluepoint is made by snapon and I got so used to working on the bike at home with it.. I decided to take it with. The 19mm socket I made with a spare 1/4 inch drive socket and a 19mm 1/2in drive. I use this for locking down the manual cam chain tensioner.
-Punches and hook. When I was at RallyRaid, John said I could have some tool steel. They make great punches. I heated the end of one up and made a hook. It works great for pulling the stainless fuel filters.
-Extendable magnet. Easiest way to remove and replace shims in your valves. If you are clumsy like me, you need all the help you can get not loosing stuff in the motor.
-Klein Tools Electrician scissors. I first used these at work. They are great for zipties, wire, cloth.. they can even cut plastic. If you had to cut a jacket or boot off someone, these would work.
-Forceps. Great for closing off fuel lines or holding something in place. Also when you cant reach with your fat fingers.
-Round file, Flat file, hack saw blades. You never know. be prepared. Maybe the spare chain you carry will fit on someone else's bike.. but you need to file and pound out the pin? Or you are dumb like me and you forgot to cut it to length before your chain broke in the Yukon.
I don't have a torque wrench. But I do have a decent feel lots of locktite.
Old 01-07-2013, 10:34 AM   #1181
RoninMoto OP
Wanderer
RoninMoto's Avatar
Oddometer: 815
Here is the thread:
I'm not sure that's going to help me over the next few days. I was thinking cardboard and ducktape would work. I'm also considering wearing the snowboard boots instead of the moto boots. They are just way warmer. I'm hoping the keeps melting over night. it looks like it stopped for the most part now.
Old 01-07-2013, 10:50 AM   #1182
MeinMotorrad
Oddometer: 159
Thanks for the pic. +1 on the KTM screwdriver mine just turns in the handle.
Winter gloves, bar muffs and heated grips on full blast worked well on a scooter I used to own, during the winter.
Old 01-07-2013, 10:54 AM   #1183
RoninMoto OP
Wanderer
RoninMoto's Avatar
Oddometer: 815
The heated grips and the Klim gloves work well for a while. But when they get soaked through its over. They are leather. I had my feet in wool socks in plastic bags today but once the boots got wet they got to cold. I need to find some SnowSeal or something to keep the water from soaking in.
The main thing that kept me going was the Gerbings heated jacket. When my core is toasty.. my feet and hands stay warmer.
Old 01-07-2013, 11:52 AM   #1184
MeinMotorrad
Oddometer: 159
Those Tucano Urbano muffs (similar to mine) are made of neoprene, so they don't let the water in. One thing I've found good to keep your core warm is a Knox met-sysback protector - really keeps the heat trapped - not so great in the summer. I
Old 01-07-2013, 01:57 PM   #1185
Durden
Freak!
Durden's Avatar
Oddometer: 454
Nice Kit, always amazes me how sh1tty the factory tool bags are now a days.
As for gloves, the best solution I found was crab fishing neoprene gloves in Oregon, they are like a wetsuit and designed to keep your hands warm (not dry). They soak through, but keep insulated when wet.
A cheaper alternative is two plastic bread bags, they seriously work.
So where to next?
Durden is offline   Reply With Quote
Times are GMT -7.   It's 05:56 PM.
