Old 04-15-2012, 02:08 PM   #1
rubRsidedown OP
rubRsidedown's Avatar
Oddometer: 2,377
Question 05 950 issue. Cant anyone help out?
I'm HOPING you guys can lend a hand here.
I have an issue going on with my 2005 KTM 950 ADVenture.
The problem is this, at 3000 rpms it stumbles and falls on it's face. It ends up running on one cyl if I hold it at 3000 rpms too long.
Above and below 3 grand it seems to run fine though.
Last week I performed an oil change on it and all went well (or so I thought. It's not my first time changing the oil in this bike either BTW).
I put about 70 miles on the bike after the oil change and now I'm wondering if it's something I did that caused this issue.
I rode the bike before the oil change for 150-200 miles and it went A-OK.
This afternoon I got gas (along with my Wife and her 650 GS) 93 octane and within 65 miles it started running weird. Her runs fine.
At first I thought, Ahhhh I left a fuel petcock off and it's running out of fuel. Pulled over on the side of the road to check, Nope, checked them both and they were open.
Anyone with some insight on this issue would be great.
One question, when the fuel pumps fail on these bikes do they go all at once or is this something they do?
Thanks in advance.
Jeff B In Maine
BLACK 05.5 KTM 950 Adventure, Mine
Electric Orange 06 BMW F650GS, Hers
"We don't quit playing because we grow old, we grow old because we quit playing."
rubRsidedown is offline   Reply With Quote
Old 04-15-2012, 02:10 PM   #2
rubRsidedown OP
Oddometer: 2,377
Update
I just removed the left side fuel tank to make sure I didn't somehow pinch a vent line. Nope, everthing looked fine.
Jeff B In Maine
Old 04-15-2012, 02:56 PM   #3
AdvGa
AdvGa's Avatar
Oddometer: 1,320
One thing you may want to look at is getting some OIL on your Voltage Regulator Connections.
AdvGa is offline   Reply With Quote
Old 04-15-2012, 03:53 PM   #4
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 415
Check the intake boots, may have an air leak. Take the airbox off, start the engine and see if both slides go up at the same time.
Damaged diaphragm can do alot of weird things.
690R & 990Adv
Old 04-15-2012, 04:00 PM   #5
rubRsidedown OP
Oddometer: 2,377
Voltage regulator and connnections are dry.
I will have to dig into the airbox tomorrow.
Any other suggestions?
I'm ALL ears.
Jeff B In Maine
Old 04-15-2012, 04:12 PM   #6
ridewestKTM
ridewestKTM's Avatar
Oddometer: 1,670
problems
the fuel pump can be intermittent. That might be the problem. I don't think it's the VR but those are a problem. Withount more discription, I would think it's the fuel pump. Other things are possible floats needing adjusted ... but address the FP because you will anyway. Dr Bean's or my kit- I have a few left. Or just buy new points.
If you got it missing put a tire pump on the tank vent(s) and pump some air in it will push fuel past the pump and if that works it's the fuel pump.
My 950KTM makes me feel like a little kid again......because it's so tall!
ridewestKTM is offline   Reply With Quote
Old 04-15-2012, 04:40 PM   #7
kingrj
kingrj's Avatar
Oddometer: 214
Send a message via Yahoo to kingrj
Thanks in advance.
My guess is a partially plugged slow jet in one or both carbs. If it went on one cylinder at 3000 and higher I would say bad spark coil but the fact that it gets ok when he needle jet goes higher up makes me thing fuel mixture. It could also be the diaphragm in one of the carbs that is leaking or a slide sticking in a carb doing this. It is all air, fuel and spark..one of those and it sounds like a general carb cleaning and inspection may solve your problem.
kingrj is offline   Reply With Quote
Old 04-15-2012, 04:43 PM   #8
CrashDBad
Big man, little bike
CrashDBad's Avatar
Oddometer: 2,036
Check that you opened both fuel petcocks.
CrashDBad is offline   Reply With Quote
Old 04-15-2012, 04:54 PM   #9
AdvGa
AdvGa's Avatar
Oddometer: 1,320
If you have a Fuel Filter you added, you may have a Clogged Fuel Filter that is restricting your Fuel Flow.
Old 04-15-2012, 07:12 PM   #10
sstewart
sstewart's Avatar
Oddometer: 822
Carbs
Inspect diaphragms,we had one that dealt us misery. Inspect completely.
sstewart is offline   Reply With Quote
Old 04-15-2012, 07:24 PM   #11
Deuce
Crazy Canuck
Deuce's Avatar
Oddometer: 2,392
I bet you a dollar's worth of donut holes it's the fuel pump. Mine did the same thing. Take the cover off the end of the pump and file the points with a finger nail file or something similar. Then order some new points or change them to a Mr.Bean type system.
Stay Calm, Be Brave, Wait for the Sign.
Deuce is offline   Reply With Quote
Old 04-16-2012, 04:33 AM   #12
rubRsidedown OP
Oddometer: 2,377
3000 rpms and yours fould fall on it's face as well but above that and below that it seemed fine?
Mr Beans is the better of all options out there?
I kind of like the Mikuni type because it's just like a snowmobile and
they are VERY simple, I like simple.
Jeff
Jeff B In Maine
Old 04-16-2012, 04:54 PM   #13
rubRsidedown OP
Oddometer: 2,377
Fuel pump pics.
Jeff B In Maine
Old 04-16-2012, 06:37 PM   #14
kingrj
kingrj's Avatar
Oddometer: 214
Dude...if it was fuel pump it wouldn't pull good at high RPM's..you got a carb problem. Take them off and clean the jets and check the diaphragms...Please!
Old 04-17-2012, 03:51 AM   #15
rubRsidedown OP
Oddometer: 2,377
Yup, under construction.
Will be doing that this week.
Jeff B In Maine
Times are GMT -7.   It's 11:13 PM.
