Old 04-21-2012, 01:51 PM   #31
Gasit
Methane Technician
Gasit's Avatar
Oddometer: 251
Gday Again Rubber-side
What i was told is the fuel pump works on pressure to the carby's it has to maintain a constant volume as well as a certain amount of fuel pressure that keeps the fuel flowing as the carby's need it to operate as they are designed to when you crack the throttle open and that little fuel pump works bloody hard it has to pump the fuel vertical and if you replace it at least you know its not the fuel pump
Gasit is offline   Reply With Quote
Old 04-22-2012, 03:29 AM   #32
BLUE(UK)
BLUE(UK)'s Avatar
Oddometer: 3,423
Further problems on rebuild......
http://advrider.com/forums/showthread.php?t=783978
WIll post up when I finally get it done!!
BLUE(UK) is offline   Reply With Quote
Old 04-30-2012, 03:39 PM   #33
rubRsidedown OP
rubRsidedown's Avatar
Oddometer: 2,726
Well I repaired the fuel pump and it still has the same issue.
MUST be carbs.
Diging into those next.
Do the tanks have to be removed, I would imagine so, to free things up....
Yeah, THAT was a STUPID question.
Jeff B In Maine
05.5 KTM 950 Adventure Black, Mine
06 BMW F650GS Electric Orange, Hers
"We don't quit playing because we grow old, we grow old because we quit playing."
rubRsidedown is offline   Reply With Quote
Old 04-30-2012, 03:54 PM   #34
Sumi
Sumi's Avatar
Oddometer: 1,812
MUST be carbs.
That's the easiest part of the fun that's avaiting you:)
Old 04-30-2012, 04:02 PM   #35
rubRsidedown OP
Oddometer: 2,726
I can only imagine.
Jeff B In Maine
Old 05-01-2012, 12:25 AM   #36
TcRulz
Oddometer: 289
Upgrade - you know you want to.
Maybe you should look on it as a positive upgrade and re-jet while your there. H2w (Ken) on this forum has the jets you need for your altitude (http://www.advmachines.com/product_p/jp1002a.htm). Might be worth thinkin about and ordering before you pull those suckers (sorry about the pun).
TcRulz is offline   Reply With Quote
Old 05-04-2012, 09:29 PM   #37
Bgunn
Mucha distancia
Bgunn's Avatar
Oddometer: 1,433
any closure yet?
Bgunn is offline   Reply With Quote
Old 05-05-2012, 03:41 AM   #38
rubRsidedown OP
Oddometer: 2,726
Originally Posted by Bgunn View Post
any closure yet?
No nothing yet, to be honest I haven't had the time to do much of anything to it.
Just got back from vacation last weekend and came down with the flu. Didn't feel much like freezing outside twisting wrenches while waiting to hit the toilet for the hundreth time.
I HOPE to do something with it this weekend or forst part of next week.
Jeff B In Maine
Old 05-05-2012, 07:00 AM   #39
kingrj
kingrj's Avatar
Oddometer: 440
MUST be carbs.
Yes Sir...it IS the carbs...Get a service manual before you start on them..
kingrj is offline   Reply With Quote
Old 05-05-2012, 04:52 PM   #40
rubRsidedown OP
Oddometer: 2,726
I have one, thanks.
Jeff B In Maine
Old 05-09-2012, 06:15 PM   #41
rubRsidedown OP
Oddometer: 2,726
What position SHOULD the jet needle clip be in for an elevation of 0-3000ft?
Service manual says 2nd position from the top.
Jeff B In Maine
Old 05-10-2012, 01:00 AM   #42
Dale950
Dale950's Avatar
Oddometer: 984
Another thing to check - water in the tank , happened to me when the drain hole's blocked under the fuel cap .
Dale950 is offline   Reply With Quote
Old 05-10-2012, 01:04 AM   #43
Sumi
Sumi's Avatar
Oddometer: 1,812
That is correct. You can also try 3rd from the top (middle), but I can't feel a big difference..
Old 05-10-2012, 07:01 AM   #44
EastSideSM
Isn't that dangerous?
Oddometer: 1,490
Originally Posted by ElChico View Post
My 950 is at 72,000 miles and I hardly know where the fule pump is... never touched it. It seems to me that there's a paranoia amongst some people.
In terms of the fault here - mine was missing at @ 2000 rpm steady - it was the rear carb - needed the jubillee clip tightening up a bit and a re-balance of the carbs.
The fault described though sounds like carb icing perhaps, I have had that quite often in the UK - and not always when it's very cold. If the engine goes onto one pot then dies out, and after 10 - 15 mins is OK again it's carb icing. In chilly/damp air I have found that you have to warm the engine up longer to get it hotter and to avoid a long spell of fast speeds and then very steady - 30 mph - you have to keep it varied.
You can buy anti-icing additives but they are expensive... modern fuels are part of the problem, they're shit!
Hope this helps
Ta
Col
Well, I'm not paranoid, I've gone through 2 pumps in 40,000 miles. But the OP problem sounds like a carb issue to me. When I had problems with the pump, it didn't stumble, it would just die.
EastSideSM: '06 950SM Black
EastSideSM is offline   Reply With Quote
Old 05-11-2012, 06:42 AM   #45
ridewestKTM
ridewestKTM's Avatar
Oddometer: 1,715
discussion
I have been discussing this with RSdown via PM. I worked on the pump putting in a kit and removing the points. The points were as bad as any Iive seen. With the kit the pump cycled great but flow/pressure seemed a little weak. The valving was good - didn't flow back or anything. That covers the two most common failure modes I have seen so I said it should be ok. I'm thinking now that the points may have gotten stuck and over heated the pump and either weakened the spring or reduced the coil's strength. I have suggesed some tests to eliminate the pump from the question such as pressurizing the tank or using gravity with a full tank.. - I think I'll just send him a working pump.
thoughts?
My 950KTM makes me feel like a little kid again......because it's so tall!
ridewestKTM is offline   Reply With Quote
Times are GMT -7.   It's 02:20 AM.
