Old 04-18-2012, 04:50 PM   #31
BikePilot
BikePilot's Avatar
Oddometer: 10,901
I'd do a 944, though I'd be sorta tempted to hold out for a later model if they can be found for a reasonable price up there. Even that 87 looks pretty nice, they hold up pretty well and handle exceptionally well for an 80s car.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, DR250SE, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 04-19-2012, 04:13 AM   #32
FPGT72
Oddometer: 3,953
Originally Posted by Dukeryder View Post
Real good write up on the 944
http://grassrootsmotorsports.com/art...e-944-profile/
Sasquatch is 100% right on that the cost of maintenance (if both have been regularly serviced with proof) between the E30 and 944 will be pretty close IF you maintain it yourself! Many shops will upcharge for a 944 even though it's got a lot of VW/Audi parts just because it has the P-car badge.
In SCCA ITS (10 years ago) the E30s used to run a lot higher in the pack the 944s, but that could have been due to the rule structure (min weights, can handicap some cars more than others).
$7K still seems like a lot for a 944, I've seen 968s for $10K that look like new cars. They're the most refined and regarded by many as one of the best handling cars ever made.
I'm still more partial to E30s but that's just me. BUT MKI Sciroccos and Rabbit GTIs with a 16V swapped in and a 3.94 or lower R&P and a Quaife LSD are even more fun
SCCA has some of the most F'ed classed cars and rules, don't go by that....and it is a very political group....very much an us vs. them group, club hates pro, everyone hates solo, prod drivers look down on IT drivers, GT drivers look down on prod...it just go so silly, I do miss running the car, but I sure don't miss the people....wish NASA was in my area.
I think the one thing you can take away from all of these comments...no matter what way you go is to get a car that is in the best shape you can and then learn to work on it yourself.
[FONT='Arial','sans-serif']Calling an illegal alien an 'undocumented immigrant'
is like calling a drug dealer an 'unlicensed pharmacist
[/FONT]
FPGT72 is offline   Reply With Quote
Old 04-19-2012, 05:18 AM   #33
Philander OP
Someday...
Oddometer: 316
Thanks for all the replies and the wealth of info provided by guys in the know.
No need to kick me in the nuts, as both cars are standard transmission...
However, the E30 has been sold. The 944 has a lot of bounce on the oil pressure needle, so according to my research it's either a sending unit short, a pressure control valve at $400, an oil pick-up tube that has broken off....or the bottom end of the engine is shot.
I think I'm going to have an indie Porsche shop have a look at it for me, as this is my first Porsche. If they say it's a good buy, I'll probably get it.
First job will be to remove the Harley sticker
Philander is offline   Reply With Quote
Old 04-19-2012, 06:02 AM   #34
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 25,538
Originally Posted by Sasquatch View Post
But the bottom line is that if I never want to work on a car, I would buy a bicycle..
Even bicycles require maintenance. Especially if you go off-roading on em!
Once you figure out how the engineers thought, fixing issues isn't as bad as it could be. For some reason, German cars are easier for me to figure out than American cars.
M
There. I've moved back to VA. Can you PLEASE change the weather?!
Gummee! is offline   Reply With Quote
Old 04-19-2012, 06:28 AM   #35
Sasquatch
Sasquatch's Avatar
Oddometer: 4,770
Mine had that at one time. It was the sending unit. If I remember right it was about a $75 unit, and a bit of a PITA to get a wrench on, but it fixed it perfectly. Very low chance of it being something major. Low end of the engine usually shows up as low oil pressure when hot (fully hot) and sitting at idle. Broken pickup tubes are rare. But it could also be one of the grounds under the dash or in the engine compartment.
Cleaning the grounds should be one of the first things on your agenda. Find all the ground lugs, pull the wires off if them, sand the connectors down and re install. German cars are picky on grounds (even the BMW )
Just remember. There is no such thing as a cheap Porsche. You pay the price up front for a well sorted and cared for car, or pay for it in repairs for one that has been neglected. Buy the newest and best one you can find in your budget.
Sasquatch
Sasquatch is offline   Reply With Quote
Old 04-19-2012, 08:31 AM   #36
FPGT72
Oddometer: 3,953
IIRC they had a problem with getting oil to one of the mains when they where run hard....could be another car....but I am real sure it was a porsche motor in something. If that is the case run away.
Good job on having a real porsche shop check over the car....no matter what it costs to have them do it that is money very well spent.
[/FONT]
Old 04-19-2012, 10:16 AM   #37
Sasquatch
Sasquatch's Avatar
Oddometer: 4,770
Number 2 rod bearing. Only really shows up on cars that are tracked hard. Rarely on street driven cars. But in any case, would not show up as the poster states. It would show up as low oil pressure at idle when hot. Followed soon by knock knock knock.....
Sasquatch
Old 04-19-2012, 12:00 PM   #38
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 9,503
I'd get the 944.
parts cost is going to be pretty comparable on both the BMW and the Porsche.
Aftermarket support is very good for both.
The Porsche is much better styled vehicle, IMO, and is the true sports car of the two.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Cobbie Award Winner
LuciferMutt is offline   Reply With Quote
Old 04-19-2012, 12:19 PM   #39
FPGT72
Oddometer: 3,953
Thanks for refreshing my memory
[/FONT]
Old 04-19-2012, 12:49 PM   #40
JasonStern
Winterize Bike? Wat?
Oddometer: 12
if you are young/single, go with the 944.
if you are older/have kids, go with the E30, or if you can find one, a 325iX.
either way, make sure to have a pre-purchase inspection done by a reputable shop familiar with each car. not only is it nice to know what you're getting into, but you can usually use the list of problems they find to negotiate a lower price.
Originally Posted by ddavidv View Post
Stock, yes, the 944 will handle better. It's not really any more powerful than a M20 equipped E30 though. Now add lowering springs, sway bars that aren't made of piano wire and some stiffer shocks to the E30 and you'll school the 944 pretty easily
yes. replacing all of the weak links in one car would make it better than an unmodified other car.
I love how many non 944 owners commenting on 944 reliability and handling. Priceless.
as a Porsche owner, I have to admit - factory parts aren't cheap. that said, BMW owners shouldn't be talking...
JasonStern is offline   Reply With Quote
Old 04-19-2012, 02:22 PM   #41
ddavidv
Thrifty not cheap
ddavidv's Avatar
Oddometer: 782
Originally Posted by LuciferMutt View Post
I'd get the 944.
This is simply not true, in the same way everyone thinks BMW parts are expensive (well, at least for 3 series cars). From Pelican Parts web site, I compared the following prices on similar vintage cars (325i vs 944S):
Brake rotor 41.50/72.25
Brake caliper 265.75/389.25
Radiator 186.25/311.75
Water pump 50.50/302.00
Timing belt kit 37.75/232.50
Door weatherstrip, left 151.50/89.50
Clutch kit 379.25/709.75
Fender, oem 282.00/1365.25
I chose the parts randomly; I did not go "looking for" parts that would prove my point, because I knew I didn't have to. These are all items that one would commonly replace on an older car or one that gets tracked. 7 out of 8 times the Porsche will cost (significantly) more to repair in parts cost alone. Figure in labor on the more difficult Porsche and the price goes even higher.
If the Porsche were 3-4 times better of a car I wouldn't argue, but frankly it's not. A 911 is, but a 944 is not. And it's not really fair to compare a 968 to an E30; that's more evolved and the E36 would be a fairer fight. I'll defend Porsches all day long if they are 911's, because they deliver a superior driving experience. The 944 is a comparable driving experience to the E30 but will cost you far more.
'04 Wee Strom
'89 KLR 650 (sold)
KLR Chronicles, list of my Ride Reports in PA/MD:
http://www.advrider.com/forums/showt...2#post18782262
ddavidv is offline   Reply With Quote
Old 04-19-2012, 03:08 PM   #42
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 14,308
Send a message via Yahoo to rocker59
944.
You said you wanted a toy. Get the sports car.
Fun car to drive.
They built/sold a shite load of them in the 1980s. They were everywhere in my hometown (Little Rock).
Always wanted one. Today, I'd probably hold out for a 968, if I could swing it.
The 924S was pretty cool. I liked it because it was different from the pretty common 944.
Nice ones are uncommon to see now, but would still be a blast to own/drive.
Rocker59 (aka guzzimike), Aux Arcs (NW Arkansas)
Moto Guzzi: LeMans 1000 CI, Sport 1100, V11 LeMans Nero Corsa
IBA #24873, MGNOC #21347
“Just keep playing, no matter how weird it gets.”
rocker59 is offline   Reply With Quote
Old 04-19-2012, 03:16 PM   #43
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 30,297
Originally Posted by sailah View Post
Both seem overpriced but maybe thats canada??
Esp the bmw.
I'd buy the porsche, way more fun, better resale perhaps. The 325, esp that vintage is a little long in the tooth
Well, the E30 325 is a great and SUPER reliable car, is probably as fast as the Porsche, and handles as well or better. It is WAY overpriced, but so is the 944. Neither have great resale value but that is true the 944 will be marginally better than the 325 if both are in perfect condition. HOWEVER, the 944 will be worlds harder to find parts for, WAY more expensive to repair, and not a ton more fun to drive.
"I claim to be frightened of horses but do so only to get out of attending parades. It's peculiar but ...it works. The Horses get it.
RESISTANCE IS NOT FUTILE. IT'S VOLTAGE DIVIDED BY CURRENT
Sniper X is offline   Reply With Quote
Old 04-19-2012, 03:18 PM   #44
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 30,297
I'd get the 944.
I hate to burst your bubble, but that 325 would spank the 944 on a track, and will vastly outlast it as well as being far less expensive to work on and keep up. However, the Porsche will get you more of the happy clam and be more fun to drive for a non sport driver.
Old 04-19-2012, 04:16 PM   #45
Fe Man
I am Iron Moran!
Fe Man's Avatar
Oddometer: 5,930
www.searchtempest.com
good luck!
Under my belt:
1885 325e, later with 3.5 from 735i, then turbo motor from 83 745i
1987 M3
1987 535is
1971 2002 ITB
1978 930 Turbo, then built a hotter turbo motor, then built a monster 3.5 ltr carb'd, high compression, twin plug fire breathing beast.
They called my son a "subversive" because he wrote a story about cutting all his teacher's heads off...
2006 Tiger
2008 KLR (hers)
Fe Man is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 05:55 AM.
