Old 04-18-2012, 10:09 AM   #1
Rob Dirt OP
More or less in line
Rob Dirt's Avatar
Oddometer: 2,255
Tiger 800 problems; for reference only please
This thread is for reference only. Please don't rant, or post how you have not had any problems. I'm happy yours is perfect. This thread is not for you. I want to make a thread for people to post what's wrong & what Triumph did to fix the problem.
I got one of the first 2011 Tiger 800XC ABS.
At about 2000 miles my XC would not start or idle w/out throttle. This happened after the new tune came out to solve stalling issues. My dealer could not figure out what was wrong because everytime I took it in, it would work perfect. After 5000 miles of having to turn the key on & off for 30 seconds until it would start & idle, they installed a new stepper motor. It's been perfect ever since.
Next, my gear indicator sensor would not recognize neutral when it was cold. After riding for 5 minutes, it works fine. The second day of that, I got a check engine light. It's been 2 weeks & I'm still waiting on a new sensor. They have a new part # so it must be a known problem.
The only other thing is my fault. I rode thru some thick sticky mud & the rear ABS ring got covered. This caused a check engine light for "speed sensor error". The ABS model uses the ABS as the speed sensor. I just had to clean the ABS ring & get the check engine light reset.
I love my Tiger & plan to keep it forever.
Update 6-8-12: I got a new Gear Indicator Sensor installed today. The dealer also did the recall for the shifter return spring. And the newest tune. My only complaint is that it took almost 8 weeks to get the new sensor. My Tiger had the check engine light on the whole 8 weeks.
Heart of Dixie
Rob Dirt screwed with this post 06-08-2012 at 03:15 PM Reason: Update
Rob Dirt is offline   Reply With Quote
Old 04-18-2012, 07:45 PM   #2
X-Ray
Over Radiated
X-Ray's Avatar
Oddometer: 204
X-Ray is offline   Reply With Quote
Old 04-20-2012, 05:10 PM   #3
Boxmonkey
Boxmonkey's Avatar
Oddometer: 33
The gear position sensor went out at 4800 miles, and was replaced with the new part # also. I have the newest tune installed, but did not have the stalling issue. I am at 7600 miles so far, and I am loving my Tiger 800.
Boxmonkey is offline   Reply With Quote
Old 04-20-2012, 08:16 PM   #4
E-town dirt dude
E-town dirt dude's Avatar
Oddometer: 179
I had the stalling problem after the first service. It took Triumph a couple of months to come out with a new program. After the remap was reinstalled it runs perfectly. I have 6000 km on the bike now.
The only other problem is trying to get rid of the smile lines on my face from the big shit eating grin that happens every time I crack the throttle
All it takes for evil to triumph is for good men to do nothing
E-town dirt dude is offline   Reply With Quote
Old 04-20-2012, 09:16 PM   #5
bug67
Hazard Avoidance
bug67's Avatar
Oddometer: 668
I received the very first Tiger 800 (XC or otherwise) in the state of Alaska. After about a week of riding, a severe chirp developed from the rear wheel area.
Turns out a spacer was improperly installed, over torqued or something, from the factory. I waited for about a week for Triumph HQ in Georgia to cannibalize one of the bikes they had (bike was so new, there were no spare parts in the U.S. much less Alaska) to send a replacement spacer. No problems since.
Never had the stalling issue...even before the tune.
Past: '04 Ducati Monster 620, '05 BMW R1200GS, '11 Triumph Tiger 800 XC
Present: '09 Triumph Street Triple R, '13
Triumph Trophy SE
Check it out: http://www.vegetablesandwich.com
"If you are going through hell, keep going." -Winston Churchill
bug67 is online now   Reply With Quote
Old 04-23-2012, 06:44 AM   #6
fbj913
fbj913's Avatar
Oddometer: 1,842
Cross Threading
One problem I seem to have over and over again is cross threading. I have now successfully cross threaded both main tank bolt threads and one of the four rear top plate bolt threads. I am NOT a person to force threads or force anything that does not work right. I think of all my years working on bikes, cars, and whatever I can get my hands on, this bike has by far given me hell on bolt threads. I don't know the cause. I'm thinking maybe the metal used on the bikes is the cause. Not sure if Triumph uses softer metal on thier bikes... I guess my point is BE CAREFUL!
Ride 365 LLC
Braaaap!
fbj913 is online now   Reply With Quote
Old 04-23-2012, 07:49 AM   #7
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 8,133
Send a message via ICQ to Yossarian™ Send a message via MSN to Yossarian™ Send a message via Yahoo to Yossarian™ Send a message via Skype™ to Yossarian™
I learned long ago never to put a lever (wrench) on the socket until I had the bolt or nut well seated and needed to actually apply torque to finish the fastening. Does it slow me down? Sure. Do I cross thread fasteners? Not any more.
Old 04-23-2012, 10:22 AM   #8
bug67
Hazard Avoidance
bug67's Avatar
Oddometer: 668
cross threading...
Yeah. I was putting the baffle back in my Arrow exhaust* last night. I had to remove the pipe from the bike to do so because I could get my torx driver in there good enough without pulling it. Anyhow, when I was going back, I somehow got the the nut crossed up on the main exhaust hanger bolt. Long story short, I broke the bolt and had to use the hanger bolt from the stock exhaust.
I could have sworn I had the threads lined up and snugged finger tight till the nylock part of the nut caught. That's when I started tightening. SNAP!
*Sounds great while actually accelerating but at steady highway speeds, it is a bit too drony for my tastes.
Triumph Trophy SE
Old 04-23-2012, 12:31 PM   #9
phillipsrog
Oddometer: 130
Engine won't turn over, warning lights
Good timing on this thread. Just went out to take quick ride at lunch and the bike won't turn over. No clicking, no nothing. I get a check engine light, check oil light, ABS flashing and alarm light on (there's oil in the sight gauge, and I don't have an alarm).
I tried disconnecting the battery and same thing happened. I rode to work this morning and everything sounded fine.
Sound familiar to anyone?
phillipsrog is offline   Reply With Quote
Old 04-23-2012, 12:37 PM   #10
fbj913
fbj913's Avatar
Oddometer: 1,842
I wouldnt say the perfect thread. Mainly because you dont know the fix... Try to post over here... http://www.advrider.com/forums/showthread.php?t=599070
is your switch in the on position?
Ride 365 LLC
Braaaap!
Old 04-23-2012, 01:10 PM   #11
phillipsrog
Oddometer: 130
Yep. I checked the basics. I'm guessing it's a computer problem, but that's all it is: just a guess.
Got it started, thought it might be the kickstand switch. Rode it home, tried to restart. Same problem. Lights come one, but hit the start switch and nothing happens.
phillipsrog screwed with this post 04-23-2012 at 04:30 PM
Old 04-23-2012, 05:04 PM   #12
phillipsrog
Oddometer: 130
Update III
Read the owners manual. Sounds like the engine immobilizer is the problem. "If the indicator light remains on it indicates that the immobilizer has a malfunction that requires investigation."
That describes my problem. Then it says see a dealer.
Old 05-04-2012, 07:21 AM   #13
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 2,555
swimmer is offline   Reply With Quote
Old 05-04-2012, 10:16 AM   #14
Rob Dirt OP
Rob Dirt's Avatar
Oddometer: 2,255
I've asked mods to nuke this whole thread. Too many people get offended when someone post about problems they have with a similar bike. I don't get it. Nobody is saying your Tiger is a piece of shit. Quite the opposite.
However, if a problem comes up it would be nice to know how it was fixed. I could quote at least 20 people having issues on various forums, but that wouldn't do anybody any good. I don't know how it was fixed.
Examples:
Front end bounce at 40mph
Pulls to the right when you let go of the bars
Immobilizer will not let the bike start
Paint finish on the engine is peeling
I could go on & on......
Heart of Dixie
Old 05-04-2012, 10:27 AM   #15
Yossarian™
Yossarian™'s Avatar
Oddometer: 8,133
Examples:
Had both of these issues on my XC.
After truing the front wheel, the bounce went away.
After more spoke adjustment to move the wheel in relation to the hub, the drift issue was corrected also.
It could be, for XC models, that the initial spoke torque from the factory is just a bit loose and needs to be looked over after the initial break-in. Once I corrected mine, I have had neither of these issues resurface.
Fixing them didn't take a trip to the dealer or any material expense on my part. I suspect the dealer would have been fine addressing them, but to be honest it was easier to work on it myself.
Times are GMT -7.   It's 09:55 AM.
