Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 12-06-2012, 04:12 AM   #76
Ian43ktm
Oddometer: 78
Originally Posted by andykeck View Post
Mine started ticking right about that same mileage. It does it all the time. At the 6k service last summer, the dealer service guy said it sounded like the other Tigers they had in. We'll see how things look/sound at the next service interval.
Check the bottom sprocket on the timing chain , behind the cover on the rhs. My friends street triple motor was noisy and I thought it was valve clearance. There is a bolt , 6 or 8mm allen key that was loose. Once tight the noise was gone. Similar to the primary nut problem for those that know the rfs KTM engines. The noise travels and sounds like top end.
Ian43ktm is offline   Reply With Quote
Old 12-06-2012, 07:40 AM   #77
Lion BR
I'd rather be riding
Lion BR's Avatar
Oddometer: 3,820
This noise is something really annoying in my opinion. Although I've heard the same story, "they all do it", it may be the thing that will push me over the edge to sell it. Mine is approaching 6K miles now.
Whenever we are riding, we are an ambassador to our sport
I'd rather be riding!
Lion BR is offline   Reply With Quote
Old 12-06-2012, 08:45 AM   #78
frytown
Oddometer: 73
I'd posted about my issue in the regular 800 forum but here's the link to the end result:
http://advrider.com/forums/showthrea...4#post18958464
For anyone who might have the engine rattle issue, this may be useful?
Since I got it dealt with I've had no issues and I'm at about 7500 mi.
frytown is offline   Reply With Quote
Old 12-06-2012, 12:13 PM   #79
burmbuster
burmbuster's Avatar
Oddometer: 1,429
Originally Posted by LotusKTM View Post
Great thread. Regarding the turn signal issues.Tourtech are a tad pricey.
Look into Baja Designs. They have ha proven track record and for my money and experience, that is the direction I'll go. $52 a pair.
www.bajadesigns.com
http://www.bajadesigns.com/products/...lacement-parts
They are in the Dual Sport kit area
Nice find. I was just getting ready to order the Touratrash ones. Thanks.
_______________
2013 KTM 690 Enduro R
burmbuster is offline   Reply With Quote
Old 12-06-2012, 12:58 PM   #80
RichardU
Let's Ride
Oddometer: 894
I have used these on a number of bikes successfully (but not the Tiger): http://www.bajadesigns.com/ProductDe...mNumber=604190
I do not recommend the LED turn signals. They look great in your garage, but on they road, people can not see them. They'll get it right eventually, but not yet that I have seen.
RichardU is offline   Reply With Quote
Old 12-07-2012, 06:47 PM   #81
andykeck
Oddometer: 104
Yeah, I mean to pull that cover off and take a look, but I need to order the gasket first so I can button it back up right away.
andykeck is offline   Reply With Quote
Old 12-07-2012, 07:11 PM   #82
Lion BR
Lion BR's Avatar
Oddometer: 3,820
Oh well... I would really appreciate a follow up. If it fixes the "tappet like ticking sound" it'll be great.
And shouldn't this be covered under warranty?
Old 12-07-2012, 10:01 PM   #83
andykeck
Oddometer: 104
It should be, but my dealer is not very convenient to me, and they already said they didn't think it was a problem.
Old 12-10-2012, 10:38 AM   #84
andykeck
Oddometer: 104
...and by "not convenient", I mean they're just far enough away that it's difficult to get to/from without a long bus ride the iffy proposition of getting a cab to come pick me up out there.
Old 12-10-2012, 02:03 PM   #85
burmbuster
burmbuster's Avatar
Oddometer: 1,429
New problem
Seems that my neutral gear switch is messing up. I can get in neutral shifting up and down but sometimes the switch will only pick up the neutral position shifting up from first. So if I am sitting at a red light I have to shift all the way to 1st gear and then shift up to neutral in order for switch to pick it up.
And no, if the light is not on you can't crank it without the clutch pulled in. Even if its in neutral.
_______________
Old 12-10-2012, 05:02 PM   #86
Rob Dirt OP
More or less in line
Rob Dirt's Avatar
Oddometer: 2,565
The gear position sensor has had 3 different part #s that I know of. When I had mine replaced it took 8 weeks, but I have good luck. Call your dealer & tell them yours is toast. It will eventually throw a check engine light.
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 12-10-2012, 07:43 PM   #87
fbj913
I ride
fbj913's Avatar
Oddometer: 2,354
pretty sure there was a recall on that...
fbj913 is offline   Reply With Quote
Old 12-11-2012, 09:28 AM   #88
burmbuster
burmbuster's Avatar
Oddometer: 1,429
Recall list
Isnt there a site that you can enter your VIN and check for recalls?
_______________
Old 12-11-2012, 09:45 AM   #89
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,638
There used to be, but last I checked it is no longer available.
The only thing related to the issue that I can think of was SB 439, which was not a recall but a service bulletin, and it dealt with the replacement of gearshift return springs on a limited VIN range of bikes.
Old 12-11-2012, 12:02 PM   #90
advtenn
advtenn's Avatar
Oddometer: 1,365
Originally Posted by backwoodsKLR View Post
2013 XC with around 1400m so far..
Only problem I have is front wheel hop from 40-50MPH. May try some new tires soon. Dealer says he can't feel it and has never heard of anyone else having this problem.
Also, dealer installed my heated grips incorrectly, lead came lose and blew a fuse. So they ordered a new set under warranty. Week and a half later, no sign of them...
Sounds like I need to sit down and do a bolt check like I have to do on my KLR from time to time...
I had the wheel hop on my first set of tires. (Battlewings) When I changed tires 5,000 miles later the wheel hop went away.
I noticed a small oil leak on the lower right side. I tightned the case bolts and it seems to have stopped.
I had stalling/would not idle, issues due to a dirty stepper motor after about 7,000 miles. I blew it off with compressed air and havent had any issues lately.
bikes guns and shine
"My body thinks my brains gone crazy" ..........Corky McMillian
advtenn is offline   Reply With Quote
Times are GMT -7.   It's 01:36 AM.
