Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 06-20-2014, 04:07 AM   #1441
KildareMan
KildareMan's Avatar
Oddometer: 674
Originally Posted by Snapper View Post
Thanks.... anyone else aware of a recall/TSB on this part? Anyone have a link or PDF? A quick search here and on the UK site didn't turn anything up :(.
Shop opened her and confirmed it's the pin... also tried for warranty assistance (although I'm out of it) and was denied on the near 30k mileage :(.
Triumph don't post up their Technical Bulletins any more. You used to be able to enter your vin and check for outstanding TB's. That's gone for 18 months or so.
KildareMan is offline   Reply With Quote
Old 06-20-2014, 11:42 AM   #1442
Snapper
Snapper's Avatar
Oddometer: 2,508
Yeah, I remember when that disappeared... just checking if someone might have picked up a copy from their service tech or something.
Lateral G Junkie
Fear Deer
Snapper is offline   Reply With Quote
Old 06-20-2014, 01:03 PM   #1443
Mikehusa
Mikehusa's Avatar
Oddometer: 271
My gear indicator on the display sometimes doesn't keep up with the shifts or displays the wrong gear for a mile or two. Does this intermittently and hasnt done it in a while. Just wondering if anyone else had/has this happen to them. Otherwise 23K trouble free miles on a 2012 XC. (Other than stepper swap)
Mikehusa is offline   Reply With Quote
Old 06-20-2014, 03:42 PM   #1444
Rob Dirt OP
More or less in line
Rob Dirt's Avatar
Oddometer: 2,567
You can clean it up & see if it helps. The original part number was changed. I doubt 2013 had the old part.
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 06-21-2014, 07:45 AM   #1445
boinoodle
Old and Cautious
boinoodle's Avatar
Oddometer: 1,248
Yet another starting issue
12.8V
Press start button, relay clicks but starter doesn't engage
Pop starts and runs normal, 500 RPM idle, power applies as normal with slow or hard roll on
Sealed with a curse as sharp as a knife. Doomed is your soul and damned is your life
Lord John Whorfin
boinoodle is offline   Reply With Quote
Old 06-21-2014, 10:59 AM   #1446
RedBean25
RedBean25's Avatar
Oddometer: 135
Originally Posted by boinoodle View Post
12.8V
Idle should be more like 1200-1300.
RedBean25 is offline   Reply With Quote
Old 06-22-2014, 09:11 AM   #1447
NABRXX
Oddometer: 46
Tiger wont start when hot....
As in, 20 miles or so hot...nothing extreme is my point. When I let the bike cool off it starts fine. I dropped it off at the westchester NY Triumph dealer to troubleshoot and repair. I called him 24 hrs after I dropped the bike off and demonstrated the problem. He says it is a starter motor issue and he is trying to replace it under warranty. I'll keep you guys posted on the results. he says he will be keeping the bike for at least a week. Any insights would be appreciated!!
NABRXX is offline   Reply With Quote
Old 06-23-2014, 07:43 AM   #1448
btao
RIP Lilolita
Oddometer: 1,011
12.8V
= Starter relay/solenoid
Here's the one I used to fix the wife's Virago 750 with the same problem:
http://www.lowes.com/pd_16125-442-OE...1148219&rpp=32
You can use or cut the flange off, then solder a wire to the rivet for your ground, or the flange if you use it.
Or you can buy the right one.
Also, sometimes it gets stuck and you can give it a mechanic's "tap tap" with an appropriate metallic blunt instrument. Take it off the bike first, and it may be a pretty good whack. Likely to occur again though, so have one on the way.
I'm sure it's related to your other issue from the bike dying from the starter fuse getting wet and eroding the tabs off, because those types of relays need enough current to burn off the deposits generated when the arc closed/open. When you have a bad/loose/fried connection like yours, you probably didn't put enough juice through it, and have buildup that led to the relay welding/sticking.
_________________________
Current: '13 Tiger 800 XC, '09 Subi WRX, '11 405hp Sti (wifey's) Past: '74 Honda CB 360, '81 Yamaha 650 Special II, '01 Bandit 1200S, '07 Bandit 1250S
btao is offline   Reply With Quote
Old 06-29-2014, 03:33 PM   #1449
NABRXX
Oddometer: 46
Update: BIKE WONT START WHEN HOT AFTER A RIDE.
Update: I spoke to the dealer and they said the starter motor was no good. They received approval from headquarters to replace it under warranty. Starter motor is on the way, bike has been in the shop for 9 days...I will continue the update and I hope that this is the only bullshit I have to deal with regarding this bike having problems. Any insights are appreciated...
Old 06-29-2014, 04:03 PM   #1450
bross
Where we riding to?
bross's Avatar
Oddometer: 4,549
What insights are you looking for? Your bike had a problem, dealer found the problem and Triumph is fixing it. Sounds like a pretty good outcome to me.
Get your bike back, ride it and enjoy.
Old 06-29-2014, 07:15 PM   #1451
Oddball
Starting over
Oddball's Avatar
Oddometer: 160
Just went through this myself. 2 months out of warranty. Dealer agreed with my assessment and I had it back in 8 days. Good luck.
Oddball is offline   Reply With Quote
Old 06-30-2014, 03:40 AM   #1452
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,775
To put it into perspective, Triumph uses thousands of these starter motors every year so the are bound to be one or two that are faulty. Hopefully that'll be the last problem you have.
2002 black Tiger955i, 72000 miles and counting.
2011 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Old 06-30-2014, 04:44 PM   #1453
NABRXX
Oddometer: 46
Yeah, I hear you...I guess I've had good luck with 99% of my bikes in my life and this ticks me off. I hope it's the only issue as I really enjoy the bike. Thanks all for your insights...:)
Old 07-02-2014, 11:53 AM   #1454
y0y02369
y0y02369's Avatar
Oddometer: 1,216
12k Service
So i'm approaching my 12k mile service and was asking roughly how much it'd be, i was told close to $1k... is that what you guys are paying too??
What's done for that price?!
Drive?! Why?! Cars have too many wheels... just makes me feel... awkwardly stable... I'll ride thank you!v
Not knowing where you are going in part of the adventure! :loll
Daisy the Tiger and Frenchie
y0y02369 is offline   Reply With Quote
Old 07-02-2014, 12:11 PM   #1455
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,667
No idea. I bought the 12K mile service kit and did the work myself.
Times are GMT -7.   It's 02:46 AM.
