Old 01-08-2013, 09:36 AM   #526
rensho
Oddometer: 93
Originally Posted by scorpion View Post
Which size dromedary bag for the back of my 390?
Leaning toward the 6L but the 4L may fit better
I'm also using a Mojavi Bag which I really like.
I've used a 6L by itself on the back of my 570 and it fits great. Cannot notice it is there, and no risk of moving or falling off.
rensho is offline   Reply With Quote
Old 01-08-2013, 10:03 AM   #527
Lost Rider OP
Broken Roadie
Lost Rider's Avatar
Oddometer: 2,787
A 4L fits inside the Mojave when about. full, I carry a 6L clipped to my backpack sometimes.
This was a Mobile posting using Tapatalk App
Lost Rider is offline   Reply With Quote
Old 01-08-2013, 10:46 AM   #528
UtahFox
UtahFox's Avatar
Oddometer: 423
I have a 6-liter one of these, and IMHO it blows. It's actually very nicely constructed and seems totally bombproof. BUT the valve is tiny, even putting a 1/2 liter of water into a stove is a PITA unless you hang it, then it's simply a PITA because it takes so long to fill anything. My preference is for Platypus bags, both the tanks and I also like them best in the backpack. Easy to fill, easy to use, easy to clean, also just as bombproof.
I had both of these down at a cabin this last week, it would be worse camping.
UtahFox is offline   Reply With Quote
Old 01-08-2013, 11:24 AM   #529
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 2,862
One solution for that is to replace the cap with a standard Nalgene bottle cap... .and I think he was asking about using it to haul extra fuel?? The Dromedary is being used in that capacity by a lot of folks... short term fuel storage.. the shape and tie down points make it very easy to strap to a rear fender until you need the fuel.
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is online now   Reply With Quote
Old 01-08-2013, 12:35 PM   #530
UtahFox
UtahFox's Avatar
Oddometer: 423
Ahh, right on. Should have read closer.
Old 01-08-2013, 01:17 PM   #531
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 2,862
Well he didnt really say he was going to use it for fuel.. you may be right.. I may be wrong
Old 01-08-2013, 01:51 PM   #532
scorpion
High Roller
scorpion's Avatar
Oddometer: 5,128
Ah yes, I want to haul fuel. With a 390 isn't that obvious! :lol
Trying to get my range into 150-180mile zone
07 KTM 990 11 Husaberg 390
The Happy Wanderer
scorpion is offline   Reply With Quote
Old 01-12-2013, 07:19 AM   #533
Rossb
Oddometer: 12
Ignition Switch Wiring
Originally Posted by Lost Rider View Post
***EDIT***
I was mistaken and originally posted a photo of the headlight plug - fixed.
Looks exactly the same ignition as mine, here's where the North America FE570S plugs in:
I traced it and the wires get lost going into the main harness.
Where is this plug hiding in the loom?
I don't see mine in the front
Rossb is offline   Reply With Quote
Old 01-12-2013, 10:31 AM   #534
rensho
Oddometer: 93
Funny. First time I used mine I hated how slowly the fuel came out. Second time, I started hating it again and then noticed the cap is a 3 way. The small part screws off, yielding a 1/2" pour opening which only takes ~30 seconds to drain the bag. I liked it again.
Old 01-12-2013, 04:20 PM   #535
SRG
SRG
SRG's Avatar
Oddometer: 893
Cyborg - I just got a couple of the tool tubes from ADVrider vendor gatogato. The same one you used. It looks like it will fit my 2010 FX450, but just barely. I can't tell from your photos exactly how you mounted the tube on your Berg. Can you please post up some more pix and the details of just how you did it? I assume you have confirmed that (a) the tube doesn't interfere w/ the tire, swingarm, or chainguard and (b) that your mounting system is sturdy enough (I was thinking of putting a +_ 1 liter fuel bottle in the tube).
Lazy Traveler
SRG is offline   Reply With Quote
Old 01-12-2013, 06:41 PM   #536
Rider1
Ridin' Dave
Rider1's Avatar
Oddometer: 114
I didn't see Cyborg mention this..... but his bike has a rear subframe fuel tank which completely opens up the left (opposite muffler) underside making plenty of room for the tool tube.
On my FE570S with a stock rear subframe there was no way the tool tube would fit without interfering with the tire.
I didn't find this out however until after I initially bought 2 tool tubes.
Maybe your '10 FX450 has a different rear subframe?
Dave
'11 Beta 450RR Sold
'13 CRF250L... Sold
'11 'Berg FE570S .. Sold
Rider1 is offline   Reply With Quote
Old 01-12-2013, 07:01 PM   #537
SRG
SRG
SRG's Avatar
Oddometer: 893
Oh, well that could be it. Shucks.
I don't have the subframe tank. I think my subframe is the same as any other 70* Berg.
I still think the tube might fit if it had a low profile bracket allowing the tube to be mounted in a position quite a bit farther back than Cyborg has his. If I get anywhere w/ it I'll post it up here.
Lazy Traveler
Old 01-12-2013, 09:06 PM   #538
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 4,398
Dave
Just catching up. Yes, as Rider1 says I have the 70degree subframe tank and never tried the tool tube with the standard plastic subframe, so I probably can't help you (SRG) there. It fit just fine and easily with subframe tank with plenty of clearance for everything.
cyborg is offline   Reply With Quote
Old 01-13-2013, 02:47 AM   #539
Mr_Chris
Get away, evil car!
Mr_Chris's Avatar
Oddometer: 239
For what it's worth, the FE 570 (2012 in Australia at least), does not come with the "secret compartment" on the left, so it looks like Cyborg's except of course without the tank under there.
The side number plate looks a bit stiff but not sure how well it would hold up with much weight, I suppose that's up to the fasteners.
Lusting for: 2013 Triumph Trophy SE
Current: 2012 Berg FE570, 2010 Street Triple R (wifey), 2011 Tiger 800 XC -- O YEA!
Sold: 1975 CT90, 2008 XVS650, 2007 Rocket III Classic, 2010 Rocket III Roadster
Mr_Chris is offline   Reply With Quote
Old 01-14-2013, 04:22 PM   #540
Brian011952
Oddometer: 86
Weather!
I haven't ridden the Hussy in a week, the high temp today was 20. I'm ready for sunshine and heat too. Will that solar storm they are predicting help? Hmmm...
Brian011952 is offline   Reply With Quote
Times are GMT -7.   It's 04:40 PM.
