04-20-2012, 04:56 AM
#1 |
Unregistered
Oddometer: 4,437
Zumo 450 dead?
My Zumo went crazy and I think it has deleted all user data. I can’t tell for sure, the software has gone nuts and the unit is not responding properly.
Garmin can fix these, right? And should I try to do that? I have been very happy with the Zumo 450, I am going to miss it. But it has only lasted about 2 ½ years. I ride a lot of very rough roads and I assume that is a factor in the Zumo’s malfunction. If I were to replace the 450, I’d want something very similar but hopefully more rugged.
I've got to be cool Relax Take a long long ride on my motor bike Untill I'm ready |
04-20-2012, 05:02 AM
#2 |
Nanu-Nanu Adventurer
Oddometer: 7,006
Yes you can send it back to Garmin and they will rebuild it or replace it for a flat fee.
You might try going to the Garmin page and try reloading the firmware first ?? Marc
04 R1150RT,06 KTM 450EXC, 84 R100RS LE, 89 XL600V, 2012 Stelvio, 72 Guzzi Eldorado http://s22.photobucket.com/albums/b327/lomaxcm/?sc=3 |
04-20-2012, 11:15 AM
#3 | |
Unregistered
Oddometer: 4,437
I suppose I should start looking at new units. Am I right in thinking the Zumo 220 is very close to what I now have? It does Tracks I believe
04-20-2012, 03:42 PM
#4 |
Oddometer: 7,006
When you get a new one send me your 450, I could use another one.
![]() Marc
04-20-2012, 05:56 PM
#5 |
Deaf on Wheels
Oddometer: 2,048
Happened to my Zumo 450...send it in to refurbish with a free(??) map update for $180.-, that was then! Still love my Zumo 450 but it couldn't accept drawn "Tracks" from Mapsource. So now the Zumo 450 sits side by side with a Montana 650 who uses newer BaseCamp in lieu of Mapsource...lotsa learning but fun. Get your Zumo fixed!
Labrador Ride 2008: Alaska Ride with Sidecar- 2009: Newfoundland 2010 TAT 2011-2012 |
04-21-2012, 05:19 AM
#6 | |
Unregistered
Oddometer: 4,437
Boy, I sure miss my Zumo 450
04-21-2012, 05:35 AM
#7 |
Oddometer: 7,006
I had a 450 fail on me once. It completely lost its mind and Garmin was not able to fix it. They sent me a new one.
![]() I run one on my KTM 450EXC and have for years without failure. I like the big screen and the dual controls. So far it is my favorite GPS of all times. I have a 550 also and only use the blue tooth for tunes when on the road. Best of luck and I hope the software update fixes it. BTW: I can draw a Route (not track) in Mapsource and download it to the 450 with no issues. ???? Marc
04-21-2012, 08:12 AM
#8 |
Unregistered
Oddometer: 4,437
Thanks but I am having trouble doing that. And I don’t think it’s software, I think I have an electrical short of some sort.
Yesterday I tried recalibrating my screen. When I touched a dot I got a message that my map was out of date and the unit froze up.
04-23-2012, 08:24 AM
#9 |
Unregistered
Oddometer: 4,437
I spoke with Garmin this morning. They can no longer fix the Zumo 450, it’s a discontinued unit and they don’t have parts for it.
They gave me a name of another Company that may be able to fix what I have. I’ll try but I may have to buy a new unit.I was thinking I had the 450 only 2 ½ years but I was wrong, it’s been 3 ½. Anyway, I have had the opportunity to use a Nuvi 550 and I was disappointed in it but I didn’t use it for very long. Maybe I just didn’t give it a chance. I kept missing my 450 The Zumo 220, if it does Tracks, might be the one for me to get but it sure appears to be a Nuvi to me. The Zumo 550? but I’d be buying a lot of capability I would not use. Any opinions?
04-23-2012, 09:54 AM
#10 |
Procrastinators
Oddometer: 5,772
Have you looked at the Montana line? No Bluetooth or media player, but a whole lot more instead. Check out the New Montana Thread to find out more.
The Montana screen is 4" diagonal, and can be used in portrait or landscape mode, as seen below. ![]() And if you like the Nuvi/Zumo type display, the Montana can do that in either orientation too. ![]() Here's another screen shot. ![]() Nothing better than this right now.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
04-23-2012, 10:50 AM
#11 | |
Unregistered
Oddometer: 4,437
04-23-2012, 02:46 PM
#12 |
Deaf on Wheels
Oddometer: 2,048
Emmbeedee...
How did you get this: auto; motorcycle or recreation..me likey likey having the map, speed; heading, elevation, etc on the right side on my Montana 650
04-23-2012, 03:02 PM
#13 |
Procrastinators
Oddometer: 5,772
That's the 4 Data Field Dashboard. You can have that in any profile you want. What's especially nice is that clicking the little arrow hides those data fields very quickly if necessary, as well.
04-23-2012, 03:15 PM
#14 |
DNS/DNF
Oddometer: 533
I've had my Zumo 550 since introduction- about 4 to 5 years, not sure but I bought an extra handlebar ram mount and swap between my Vstrom and KLX450R. No problem so far and the unit has taken a beating. I did have to replace the cradle after a hard getoff on my KLX450R up in the mountains. No problem as I found another one from an inmate here.
I am interested in the Montana and will only consider it if it does MUCH BETTER off road than my Zumo 550. When I am on the street, I linkup my Bluetooth phone and BT transmitter to pipe music and cell phone to my ER1. Seriously, what does a Montana do better than a Zumo in off road? Thanks. Jon
09 KLX450R (Plated) 06 DL1000K6 |
04-23-2012, 03:27 PM
#15 | |
Procrastinators
Oddometer: 5,772
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. Emmbeedee screwed with this post 04-23-2012 at 03:39 PM |
