Old 05-15-2012, 08:15 AM   #106
ebrabaek OP
Oddometer: 4,710
After the exit pipe was cured.... It was trimmed to fit lining up with the end cap, and core. Remember the color made in the beginning.......
The other half was bonded to the exit pipe... and the exit pipe was then bonded to the end cap...
I originally planned for the exit pipe to protrude through the end cap about 4mm..... but after seeing it this way.... I liked that clean look. It would have been tough to enlarge the hole in the end cap with the right dimensions....this way it is now curing with just a dab of epoxy...... After this it will be re-inforced through the inside.....
Erling
Old 05-15-2012, 09:02 AM   #107
rediRrakaD
Whoopdie do
rediRrakaD's Avatar
Oddometer: 741
Well worth the extra hours!!
S.
"Death in the pursuit of happiness is triumphant!"
rediRrakaD is offline   Reply With Quote
Old 05-15-2012, 09:08 AM   #108
ebrabaek OP
Oddometer: 4,710
S.
I think so to...Thanks...
Erling
Old 05-15-2012, 09:10 AM   #109
ebrabaek OP
Oddometer: 4,710
Then the exit pipe to end cap....and exit pipe to core flange is reinforced from the inside.....
In the oven again....... Time to start work on the strip to hang the muffler in.....
Erling
Old 05-15-2012, 01:25 PM   #110
ebrabaek OP
Oddometer: 4,710
Out came the giraffe neck for the dremel...... and after much trimming....and sanding..... It's done.... I must say... I really like the way it turned out.....
On the inside as well....and a thin "rub of epoxy in and out.....
Then on to the hanger...... First put the muffler in the "jig"....
Then put the "jig" ....in the "JIG".....
Then laid up 4 layers of CF tape..... and on the bolt on part..... 4 layers each side of a sheet of 5.7 oz twill (3K)......
Video uploading on youtube with the layup of the last tape.....
Erling
ebrabaek screwed with this post 05-15-2012 at 02:01 PM Reason: Added Youtube video...
Old 05-15-2012, 01:51 PM   #111
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 598
This thing is turning out freakin awesome!!!
(Like pretty much everything you make!!)
Ryan
2010 F800gs (Mine) 2011 F650gs (Wifes)
grndzr0 is offline   Reply With Quote
Old 05-15-2012, 02:02 PM   #112
ebrabaek OP
Oddometer: 4,710
Ryan
Thank you sir..... Can't wait to hear it......
Erling
Old 05-15-2012, 03:41 PM   #113
Kitedans
In love with my AT !!
Kitedans's Avatar
Oddometer: 39
I'm enjoying every single step of your work !!
Keep it going !!
BMW F800GS '11
Tuned Africa twin '92
Kitedans is offline   Reply With Quote
Old 05-15-2012, 03:54 PM   #114
ebrabaek OP
Oddometer: 4,710
Keep it going !!
Gracias amigo......
Erling
Old 05-15-2012, 03:56 PM   #115
zgfiredude
Oddometer: 818
If you guys keep patting him on the back and inflating his ego, he won't be able to fit in the garage to finish!!
Now, put down the espresso and get to work! There, I have spoken.
zgfiredude is offline   Reply With Quote
Old 05-15-2012, 04:24 PM   #116
ebrabaek OP
Oddometer: 4,710
Your just jealous that you don't have one...... No wait.... you don't have an 8GS either.... Bummer ehhhh....
Erling
Old 05-16-2012, 05:50 AM   #117
rattis
rattis's Avatar
Oddometer: 1,128
Thumb
hold da kaeft man det blir skideflodt
If it works half as well as it looks it'sgoing to be a fu..ing marvel
I wish I had bought a GSA a long time ago
and now I drink Orange Crush as well, double up now, a 990Adv and a 950 SER
rattis is offline   Reply With Quote
Old 05-16-2012, 06:50 AM   #118
ebrabaek OP
Oddometer: 4,710
Ja ikke... Det syntes jeg ogsaa. It has really turned out every bit as nice looking as I had pictured during the process... But it must be really nice to have a cad program and a cnc mill so you can do all this....even before the build start.....
Erling
Old 05-16-2012, 08:45 AM   #119
ebrabaek OP
Oddometer: 4,710
The jig held up great.....but as one of the beefs I had with the LV...is the too flimsy CF strip hanger. I wanted this one to be stronger...with less flex. The CF tape is awesome, but offers little torsional rigidity, when applied on top of each other. When I made the pipes from the tape... I cris crossed the tape yielding good torsional stability.... but with an open strip like the hanger.... It needed more... So one layer of 5.7 oz (3K) on the inside....two on the outside.....and this time using the HTE system. I used the 1618 system on the hanger, as I could not post heat cure the whole jig..... and the 1618 is great.... but the HTE is by far stronger. Curing right now....
Erling
Old 05-16-2012, 11:59 AM   #120
ebrabaek OP
Oddometer: 4,710
Out of the Jig....all looks rough...but good as the perimeter will be sanded away....
One bracket later....
I will be busy this afternoon....and at the most will get to packing..... but I would like to think.... It will run tomorrow.....
Erling
Times are GMT -7.   It's 06:02 AM.
