Old 05-16-2012, 06:10 PM   #121
ebrabaek OP
Oddometer: 4,709
End cap and mount hanger had a coat of clear lacquer......
I must say.... I really like the end cap. It really is....no matter how nice you make the can.... if you finish it with a sorry end cap...it's nothing..... I lucked out with this one.....
All the parts are now made......... And tomorrow I will pack it......final assembly....and run it for the first time....... Whoooooeeeeeee....
Erling
Old 05-16-2012, 08:17 PM   #122
ebrabaek OP
Oddometer: 4,709
Ok....so I couldn't help myself....... Just for kicks....he-he.....
It'l rip tomorrow......
Erling
Old 05-17-2012, 05:41 AM   #123
Hudson
Hudson's Avatar
Oddometer: 35
Fantastic.
Well done. You must be proud of that.
Safe Journey,
Hudson
Newport News, VA
"They both savoured the strange warm glow of being much more ignorant than ordinary people, who were only ignorant of ordinary things."
-Terry Pratchett
Hudson is offline   Reply With Quote
Old 05-17-2012, 06:21 AM   #124
ebrabaek OP
Oddometer: 4,709
Thanks..... Some things turn out better than others...... I really like the way this turned out..... So in short... Yes.
Erling
Old 05-17-2012, 08:14 AM   #125
rediRrakaD
Whoopdie do
rediRrakaD's Avatar
Oddometer: 741
Sheeesh... all that hard work and you still have that plate light extension on??
PLEASE remove so ALL can see the awesome work from every angle!
I know, my exhaust... it's sub par.
Yours, on the other hand, is a true piece of art!
S.
"Death in the pursuit of happiness is triumphant!"
rediRrakaD is offline   Reply With Quote
Old 05-17-2012, 09:01 AM   #126
SportFaller
Dirt dont hurt, MUCH
SportFaller's Avatar
Oddometer: 668
or chop the plate off entirely! http://www.advrider.com/forums/showthread.php?t=760549
"The chokers, and the chain saws, and the log trucks have been stilled, now spotted owls, and hippy gals, run freely through the woods!"
Bikeless in WY
http://www.dakotadualsportriders.com
SportFaller is offline   Reply With Quote
Old 05-17-2012, 10:23 AM   #127
ebrabaek OP
Oddometer: 4,709
S.
.... Actually imho... your early LV is better than the new LVone..... They (LV) produced a pipe of less quality (new LVone) as compared to what you have. I had both....and did not care of the performance of the new one. They are both an improvement over stock..... But the biggest beef I had....is the build of the LVone...end caps on the outside..... plastic end cap.... It seemed to me that they needed more profit.... as the new one takes less skill, and time to build. So I would hold on to the one you have.....
Erling
Old 05-17-2012, 10:23 AM   #128
ebrabaek OP
Oddometer: 4,709
Time to pack, and run the new muffler.......
Erling
Old 05-17-2012, 11:18 AM   #129
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 598
2010 F800gs (Mine) 2011 F650gs (Wifes)
grndzr0 is offline   Reply With Quote
Old 05-17-2012, 12:13 PM   #130
gbtw
Oddometer: 137
S.
Oh god CAN'T UNSEE YOU :(
now i will have to fix that :/
I hadn't looked at the plate at all yet, but now i see it in photo's
HALP!
gbtw is offline   Reply With Quote
Old 05-17-2012, 12:20 PM   #131
ebrabaek OP
Oddometer: 4,709
Whoooooeeeeeeeeeeeeee.......
Erling
Old 05-17-2012, 01:08 PM   #132
ebrabaek OP
Oddometer: 4,709
Simply awesome.....and mildly amusing...... it works great.....
Out came the packing..... I realize that there are a lot of different packing available. I have used this glass packing with great results. It does a fantastic job at attenuating sound...while lasting a long time before repack...
How to pack a muffler...... Well... you get 20 different people... they will offer 40 different ideas, and ways ...how to pack it, so this is merely my way....and perhaps as good, and bad as others. There will be a video uploaded in a few minutes, that explain this better. But the idea here is to lightly pack the glass around the core. Too tight...and it will last forever, but offers poor attenuation...too lightly...it'l blow out quick, but attenuate good.... So right in the middle.
Video of the packing.....
To the top...then end cap filled.....
Then the end cap was careful guided into position.....
The rim band was then carefully tapped into position....
Holes were drilled for the rivets....and here they are side by side....
Note the same overall length.....with a gain of about 1.5 inches of core.....
It is a substantially bigger pipe......with a gain of about 1 inch in both with and height..... But the loss of metals....paid off.....over one pound of weight savings.....whooooeeee I wasn't sure....but had a good feeling about this...
LVone
Viking pipe.....
Installed on the bike......
The video's are uploading as we speak..... But the perceived noise drop was more noticeable than the meter indicated.....as the LVone.....has very little low frequency rumble, but a harsh....to me.... snappy sound. The Viking pipe has a lower rumble...but the meter don't lie, in the overall measured levels.... Idle LVone was at 94 db....Viking 90db..... SAE 20 inches@3000 rpm 45deg approach...LVone 102db....Viking 100db. But the ticker here is the much more pleasant sound....with a lower rumble...rather than a snappy high pitch sound...... Be back with the video's shortly..... Kiddos are watching Netflix....grrrrr... takes away the bandwidth.....
Erling
ebrabaek screwed with this post 05-17-2012 at 01:39 PM Reason: Added You tube video.
Old 05-17-2012, 04:37 PM   #133
ebrabaek OP
Oddometer: 4,709
For control....LVone idle and revving.... 94 db....
Erling
Old 05-17-2012, 04:40 PM   #134
ebrabaek OP
Oddometer: 4,709
LVone SAE @3000 rpm...102db
Erling
Old 05-17-2012, 04:45 PM   #135
ebrabaek OP
Oddometer: 4,709
First start of new pipe......I know...I know...very geeky....but I had to share... Of course I would have burned the chip...if it was a fiasco......
Erling
Times are GMT -7.   It's 03:17 AM.
