Old 05-11-2012, 09:56 PM   #46
ADVMax
Sporting Foole
ADVMax's Avatar
Oddometer: 27,570
Originally Posted by Hawk View Post
Hate that it happened, happy you got away relatively clean and painless. Makes me want to tear apart my bike and at least check....
Satan's nine-fitty is back together and workin well according to Stewy.
Drif might get to ride this thing tomorrow afternoon.
Check yer freewheel rotor bolts.
just do it
There is absolutely NO EXCUSE for what I'm about to do!
The Second Amendment - it ain't about duck hunting.
You heatherns needs some churchin up - http://www.landoverbaptist.org/
ADVMax is online now   Reply With Quote
Old 05-11-2012, 09:59 PM   #47
ADVMax
Sporting Foole
ADVMax's Avatar
Oddometer: 27,570
verstehst du?
Old 05-25-2012, 01:56 PM   #48
avocadofarmer
Oddometer: 160
uuuh....I'm about to replace my starter torque plate...
What does the conventional forum wisdom say about this...to just check the torque values (and possibly break the locktite seal) or to pull the bolts, clean and retorque with 648?
avocadofarmer is offline   Reply With Quote
Old 05-25-2012, 03:22 PM   #49
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,152
remove bolts, clean both thread surfaces throughly, reapply 648 liberally to bolts, install and torque to spec.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2008 KTM 690 ADV- 2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 05-25-2012, 05:03 PM   #50
avocadofarmer
Oddometer: 160
Thanks for the info...is the problem that these bolts were not 648'd at the factory or that the locktite starts to lose it's effectiveness after a certain amount of time?
Old 05-25-2012, 06:13 PM   #51
avocadofarmer
Oddometer: 160
OOH...also, it seems difficult to find 648 locally, is there a permatex equivalent?
Old 05-25-2012, 07:24 PM   #52
sstewart OP
sstewart's Avatar
Oddometer: 822
648
Can get it easily on the web. This is some serious shit
sstewart is offline   Reply With Quote
Old 05-25-2012, 08:56 PM   #53
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,563
Send a message via MSN to v8toilet
Not having mine apart ever I was wondering if the gasket is one of those that must be replaced or if it will survive r&r. I realize having one I on hand is a good idea.
v8toilet is online now   Reply With Quote
Old 05-26-2012, 06:02 AM   #54
Lil' Irv
Lil' Irv's Avatar
Oddometer: 209
Safety Wire?
Can these bolts be safety wired? Haven't opened mine up yet and a quick search didn't find any pictures that would tell me. If there is room enough that the safety wire wouldn't interfere with anything I'd buy a set of bolts and have them drilled for wire and replace the existing bolts. With locktite 648 and safety wire there'd be no worries. Has anybody done this?
"Life is either a daring adventure, or nothing." -- Helen Keller
Stranger 315
'04 KTM 950 Adventure S
'04 BMW R1150RT
Lil' Irv is offline   Reply With Quote
Old 05-26-2012, 06:56 AM   #55
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,152
Usually the gasket will survive, but replacing is the best option to ensure no leaks.
I have not seen it done, however does not mean it cannot be done.... its a very tight fit, so the safety wire would have be very neat and tight to the flywheel, possibly bonded to the flywheel with adhesive of some-sort... otherwise the same thing would happen as if the bolts came out; contact with alternator windings=distruction
Old 05-26-2012, 07:02 AM   #56
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,152
Web source for 648 10ml bottle ~$17
http://www.amazon.com/Loctite-Retain.../dp/B000O01EU6
Old 05-26-2012, 07:14 AM   #57
avocadofarmer
Oddometer: 160
Thanks for the tips, H2W!
I did a search and found that Permatex sleeve retainer is a similar product and possibly easier to find locally.
Old 05-26-2012, 10:41 AM   #58
Yascher
Yascher's Avatar
Oddometer: 294
Hole Punch the bolts
These stator bolts is a cell known issue on V-twin aprilias and we use locktite together with hole punching the side of these bolts, to prevent any movement
Yascher is offline   Reply With Quote
Old 05-26-2012, 12:03 PM   #59
ADVMax
Sporting Foole
ADVMax's Avatar
Oddometer: 27,570
McMaster Carr's got it. I ordered a bottle for SStewart and I one day, had it the next.
Not sure why everyone is convinced it's so hard to get?
Old 05-31-2012, 09:22 PM   #60
avocadofarmer
Oddometer: 160
FWIW...I just did this tonight on my 2006. I took one bolt out and it was definitely 648'd. I decided to not bother the rest of the bolts and re-648 the one I took out and torque down to 15 nm.
Times are GMT -7.   It's 11:26 AM.
