04-21-2012, 04:52 PM
#1 |
Iron toocus
Oddometer: 927
Which scooter powerplant for a project?
I got hooked on scooters after getting my first one just shy of a year ago but I want to make something that isn't available. A scooter engined all purpose cycle with recumbent seating position. Think a tubular version of those hyper-miler scooters that get 150+ mpg.
The requirements for the engine: Cruise at 60 to 65mph Low maintenance(3,000 mile oil change intervals, valve adjustments twice as long) Can be carbed or FI. Has a 12" or bigger rear wheel that could handle 5" of travel, possibly more depending on the shock length. Engine can't have any adverse affects from being at more of an angle to the ground than normal(problems with oil pick up or transmission gears not being lubed by oil bath. Basically able to handle some light off road work. Thoughts? |
04-21-2012, 05:27 PM
#2 |
Oddometer: 409
Very Interesting Question
I've been thinking about the same thing. Probably the best choice would be the drivetrain out of a new BV350, or a new Downtown 300, because they're the most advanced engines out there today as far as specific power output, efficiency, etc. Downside to these two choices are the cost, and the fact that you'd have to sacrifice one of two awesome new scooters to get your donor drivetrain.
Next best choice might be a Burgman 400 or Majesty 400 drivetrain. These scooters are relatively cheap, and they're everywhere. These drivetrains are used to pulling around 700-plus pounds of man and machine, and their suspensions and brakes are also up to the task. Another reason favoring the Majesty 400 is that I happen to have one in my garage.
HandKPhil |
04-23-2012, 07:39 AM
#3 |
Perpetual ponderer
Oddometer: 1,662
If I was starting from scratch, and only needed cruise speeds below 70mph, I would factor in the strong aero advantage offered by building from scratch, and combined with exceptional light weight - if at all possible - would be looking at something around 125cc. The Yamaha BW motor is pretty efficient, and has an enormous aftermarket support, just in case you need to go bigger than you expect later, or need to tune-in the CVT stuff to suit the new ride.
These things get great economy, and will happily do close to those speeds almost standard, so by the time you've got the lightweight and aero advantage it will do it real easy. To give an idea of aero effects, the Moto Guzzi 350cc IOM racers with their cool "dustbin" fairings had a top speed over 150MPH in the mid-50's. When the fairing design was banned, they could barely manage hi-120'sMPH........
Every ride's an adventure if you can't ride for crap http://www.dragtimes.com/Ducati-Mons...lip-10329.html |
04-23-2012, 08:15 AM
#4 |
Oddometer: 328
Something like this!?: http://www.evomoto.de/index-Dateien/page0078.htm
04-23-2012, 08:17 AM
#5 |
Oddometer: 480
I agre with the 400cc burgman or the Yamaha , I would grab some thing like this where you have all the mechanial and electrical parts . Then you could sell off the stuff you don't need , pretty cheap
![]() http://detroit.craigslist.org/okl/mcy/2965792453.html |
04-23-2012, 08:51 AM
#6 | |
Oddometer: 409
I'm thinking about embarking on a three-wheeled Micro Car project, and I like the fact that the Majesty already has a beefy, die-cast central "spine" to build around. Try Googling "Naked Yamaha Majesty" to see some pictures. In regards to the O.P.'s needs I know that the highest point on the aluminum frame (near the seat position) is pretty low on a Majesty - perfect for a "feel forward" project.
HandKPhil |
04-23-2012, 12:47 PM
#7 | |
Iron toocus
Oddometer: 927
This idea is tube frame, minimal bodywork, and able to play in the dirt. Bodywork will be minimal and still not even sure if passenger accommodations will be provided but they could double as storage space. |
04-23-2012, 06:55 PM
#8 |
Oddometer: 95
I vote chinese for something like this, parts are cheap and you can find full bikes cheap too.
On the other hand, there was a guy a few years ago on the helix forum that put a 500cc rotax sled engine in a stripped down helix.....BAD ASS. |
04-23-2012, 07:39 PM
#9 | |
Iron toocus
Oddometer: 927
Are you talking GY6? |
04-24-2012, 04:46 PM
#10 |
Oddometer: 2,835
Sounds cool! Please post up when you start building it!
I can't really know about the oil lubercations and angles on these engines. I do agree on the aerodynamics though. If youse got real good aero, then you can gear the engine much taller [machine finial drive gears that's taller], and get much higher cruise speeds with low RPMs. Just don't overdo it on a smaller engine. As for maintainence. Most engines can do well over 2-3K with a good synthetic oil, even if recommended at less. Valve adjustments? I never did one for years on my Elite. Runs fine but I's gonna do it now. As for offroad. I take my old 86 Elite 150 off road all the time. And I don't exactly baby it! No flying 10 feet up in the air off jumps MX style, but I have some fun in the mud! Eventually I'm fixin to put some sort of skid plate under it though to protect the coolant hoses and such. But its not necessary unless you do it a lot.
85 Honda Shadow 700, 86 Honda Elite 150 deluxe, 2001 Honda Elite 80, 07 CRF 100, 07 CRF 50, 07 DRZ 250, 78 CB 400 Automatic [Project Bike] |
04-24-2012, 06:04 PM
#11 |
Oddometer: 95
yes I was thinking gy6. The Linhai 250s are also pretty reliable powerplants. I knowseveral people that trust gy6 150s or even Honda 250 clone engines out through Kentucky on gocarts without worry. Our local Hammerhead dealer even sent a 250 up pikes peak last summer, so the engines can handle a beating off road and the reliability issues of being chinese can be overcome by the performance rebuild work.
04-24-2012, 08:34 PM
#12 | ||
Outside the Pod-bay
Oddometer: 1,431
![]() ![]() Honda aerodynamic scooter conversion results in 214 mpg Quote:
![]() One of the early test studies.
'77 BMW R100RS with Ural chair '08 Suzuki AN650A Burgman (and trailer) |
04-24-2012, 08:44 PM
#13 | |
Oddometer: 480
04-24-2012, 11:45 PM
#14 | ||
Outside the Pod-bay
Oddometer: 1,431
I recall being happy with the 139mpg (Imperial) that was possible with a ordinary Honda C65 stepthrough back in the sixties. The 65cc motor was the FIRST OHC powerplant that Honda put into a Supercub. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . I seem to recollect that the auto maker Daihatsu selecting 993cc in the Three-cylinder configuration for reasons of efficiency way back in their post-WWII history - of particular in the Charade. It was something along the lines of 330cc being an optimum volume for each cylinder's peak efficiency. Coming soon: Three-cylinder engines Matt Campbell March 12, 2011 Straight-three engine From Wikipedia From that idea, I derive a single cylinder of 300cc - 350cc as being a good compromise for optimum fuel efficiency with top road speeds in no way being hampered. That 125cc of Jacobs (of course) remains great at lower top speeds. Interesting, that my Burgman Exec employs two cylinders of 319cc each -- not so great for fuel economy, but it powers off from the line something wicked!
04-25-2012, 08:25 PM
#15 |
Iron toocus
Oddometer: 927
It's really tough researching what would work best for this application.
Honda Helix(parts availability and can be had cheap) Kymco engines(125 to 200cc)-again, cheap and reliable GY6-cheap and able to be reliable, plenty of aftermarket. Yamaha Vino 125-Can find bikes cheap and parts still available. If the engine has a mount on the bottom it will be more difficult to have ground clearance. A horizontal engine will allow a lower profile frame design. Not sure about air versus water cooled. Obviously the air cooled will be simpler with the lack of plumbing. |
