Old 04-24-2012, 11:37 PM   #16
Hochtouren OP
Improve until broken
Hochtouren's Avatar
Oddometer: 150
Originally Posted by spafxer View Post
Don't forget to move your mirror from the master cylinder onto the perch bracket.
A few $ spent now will save in the long run
Right you are - have a bracket front coming from KTM Twins.
'12 990 ADV: The Orange Barchetta
______________________________
It's not about logic. The great thing about being a man is that it doesn't have to make sense.
Hochtouren is offline   Reply With Quote
Old 04-25-2012, 02:45 AM   #17
fluff34567
fluff34567's Avatar
Oddometer: 1,054
or order folding mirrors
fluff34567 is offline   Reply With Quote
Old 04-25-2012, 06:46 AM   #18
Beema Killa
Beema Killa
Beema Killa's Avatar
Oddometer: 806
+1 AND new bracket!
Beema Killa is offline   Reply With Quote
Old 04-25-2012, 06:51 AM   #19
Hochtouren OP
Hochtouren's Avatar
Oddometer: 150
Expect the bracket from KTM Twins any day, my folding mirrors are stuck in with my Touratech order that is being hauled from Germany by oxcart/canoe. Hopefully arrives before the bike is miled out and traded in....
Old 04-25-2012, 02:22 PM   #20
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,785
Did you flip the cables over so they are on the bottom?
Works like a charm.
I had installed without flipping and was a bit worried about how the cable stretched but when I open the air box there was no movement at the FIs. Just flipped them and there there is plenty of slack
Moto Trek'n to New York via the Trans Labrador Hwy, South America
Moto-Treks
moto-treks is offline   Reply With Quote
Old 04-25-2012, 02:46 PM   #21
Hochtouren OP
Hochtouren's Avatar
Oddometer: 150
Only issue is a bit of binding where the cable boot contacts the starter/killswitch assembly, but other than that, works great. I can see now that the additional step of switching the cable routing to the other (right) side of the steering head would make plenty of room for even the 2" risers.
Old 04-25-2012, 07:28 PM   #22
Hochtouren OP
Hochtouren's Avatar
Oddometer: 150
Would like to know how the stabilizer works out. Cheers!
Old 04-28-2012, 11:49 PM   #23
Hondo
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,460
I just installed a set of 2" Rox Risers on my 2011 Adventure -
I rotated the throttle assy 180 degrees -
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is offline   Reply With Quote
Old 04-28-2012, 11:53 PM   #24
Hochtouren OP
Hochtouren's Avatar
Oddometer: 150
All you need now is the blingy bar clamp from CJ to ice the cake.
Old 04-29-2012, 12:54 AM   #25
Masa
Masa's Avatar
Oddometer: 297
Originally Posted by Hondo View Post
The brake line is a bit on the tight side, same as mine with 2" rallyrisers.. I could re-route line to get more slack, but so far haven't bothered to do it.
Masa is offline   Reply With Quote
Old 04-29-2012, 07:14 AM   #26
Hondo
Hondo's Avatar
Oddometer: 9,460
My brake line seems fine.
The throttle cables are under a bit of bending pressure though, but not enough for me to worry about.
Old 04-29-2012, 07:46 AM   #27
Hochtouren OP
Hochtouren's Avatar
Oddometer: 150
One thing that helped a bit was to snap off the small plastic guide that the cables run in just to the left of the steering head - provides a bit more slack for the throttle cables.
Old 04-29-2012, 07:59 AM   #28
Hondo
Hondo's Avatar
Oddometer: 9,460
On my 990 the bending tension is right under the On/Off/Starter switch assy -
Old 04-29-2012, 09:54 AM   #29
Hochtouren OP
Hochtouren's Avatar
Oddometer: 150
Same here - boot is a little too thick.
Old 05-01-2012, 05:34 AM   #30
fluff34567
fluff34567's Avatar
Oddometer: 1,054
Originally Posted by Hochtouren View Post
Flipped the cables to cut some much needed slack...
Then set these awesome Rox up in the position I wanted them... huge improvement in ergos.
any chance you or anyone else could get a photo side on of where the bar goes into the riser and your front brake line?
looks like there is a large gap between the bar and the riser...
my risers arrived but have some issues - label on the front says 2" rise with a 1.75 clamp and 1 1/8 bar dia.
label on rear says 1.75" rise and 1 1/8 clamp and bar
a quick test fit and the clamp of the riser is a perfect for the bars BUT the radius in the riser is no where near so only 2 points of contact onto the bar = crap.
Looks like i really have a 1 3/4 rise with a 1 1/8 stem and a 7/8 radius with a 1 1/8 top clamp
would be interested to see what others also have.
thanks for help
fluff34567 screwed with this post 05-01-2012 at 06:12 AM
Times are GMT -7.   It's 04:24 AM.
