Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 04-23-2012, 09:43 AM   #16
HardWorkingDog OP
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,770
Originally Posted by DRTBYK View Post
...Easy enough to keep using v2.1.6 until v4.0.1 comes along. I don't know if the MapInstall Developer reads this forum. If you want to hurry an update along you might post on the Garmin Forum for Mac MapInstall your observations.
That's what I'm doing. Too bad the Garmin Mac Software thread is dormant. GarminMac's last post was 2+ years ago...
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 04-23-2012, 09:54 AM   #17
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,996
Are you looking here?
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 04-23-2012, 10:07 AM   #18
HardWorkingDog OP
Harvey Mushman
Oddometer: 1,770
Cheers,
No, sorry, I meant the Garmin Mac Software thread on advrider, that was started by someone working for Garmin with the screen name GarminMac.
The official Garmin forum you linked seems useless—lots of newb questions that sit unanswered for weeks...
I did send an email to support describing this problem. We'll see...
"Coffee first..."
Old 04-23-2012, 11:49 AM   #19
abhibeckert
abhibeckert's Avatar
Oddometer: 1,724
Don't be to amazed, Garmin and Apple are still trying to get coordinated on application updates.
Trying to get coordinated?
Apple pushes out around a thousand new/updated apps every day, and don't give special treatment to anyone (there is an "urgent" flag for critical bug fixes but they take it away if you use it often).
Approval takes less than a day or two unless it's rejected (no reason for this to be rejected, no porn or anything), and you can set a public release date once it's approved.
It's all computerized, they don't need to coordinate anything.
abhibeckert is offline   Reply With Quote
Old 04-25-2012, 04:18 AM   #20
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,847
This may be old news to some, but Garmin released MapInstall (for Windows!) version 4.0.0 officially on Monday.
http://www8.garmin.com/support/downl...ls.jsp?id=3291
Emmbeedee screwed with this post 04-25-2012 at 04:44 AM
Emmbeedee is online now   Reply With Quote
Old 04-25-2012, 06:35 AM   #21
HardWorkingDog OP
Harvey Mushman
Oddometer: 1,770
I received an email reply from Garmin International today.
Yes, I am sorry but the newer version of MapInstall is going to be a bit of a challenge with the legacy units, such as the GPSMAP60CSx.
Mainly because the only image file the device can read is gmapsupp.img whereas the newer units can read named mapping. Whenever one sends mapping to a legacy unit it will automatically replace what is on the SD card, so the application is not going to prompt that there is a file there.
This sounds like we will be required to reinstall every single dadgum map segment if we want use 4.0.0 on our LEGACY UNITS...
Hard to figure that's really a desired behavior, but I'm not willing to test it out; got better things to do.
(Speaking of which, I'll be headed to Utah today, probably not much internet access, so won't be able to shepherd this thread )
"Coffee first..."
Old 07-25-2012, 12:28 AM   #22
dacrazyrn
ED RN Adventurer
Oddometer: 495
MI did not erase and rewrite my existing maps on the card. Since I wasn't doing anything to the existing maps MI preserved them on the SDcard.
Been loading and reloading stupid maps the last 2 days. Been playing with the typ file to have my topos uniform…anyway. The last time I pulled some of the img files off the card and Montana, because every time that I would change A map, MapInstall (Mac) is erasing ALL of the maps and reloading them again. ALL OF THEM. TAKING HOURS ON END. Tried different things like unchecking ones I want left on…NOPE, erases it and loads others. Leaving it checked…NOPE, erases it and reloads it. Going into the partial install…NOPE, erase and reload. (I was watching my card in the background and POOF…gone!) Not to mention that it is just willy nilly throwing whatever map on whichever area they want….I want to control that. BLECH!!!!
Tracy E / Photos4Aidan.com / dacrazyrn.dpcprints.com / Can you SPOT me?
“When you do things RIGHT, people won’t be sure you’ve done anything at all.” God in Godfellas-Futurama
Life is Risk Management
'09 BMW F800GS-Fate Honeyed GSabelle
dacrazyrn is offline   Reply With Quote
Old 07-25-2012, 09:27 AM   #23
HardWorkingDog OP
Harvey Mushman
Oddometer: 1,770
I do see that Garmin has released 4.0.1
http://www8.garmin.com/support/downl...ls.jsp?id=3825
Are you using that? I thought the erase-and-download-every-time was only supposed to happen to the "legacy units" but you're using a Montana, right?
Too bad Garmin isn't better at this software stuff. They've got the right idea, but don't seem to have the right vision.
Will the older version of Mapinstall work on a Montana? I've got 2.1.6 archived and still use it on my 60CSx for this very reason...
"Coffee first..."
Old 07-25-2012, 10:19 AM   #24
DRTBYK
DRTBYK's Avatar
Oddometer: 5,996
Yes, I'm using v4.0.1, which I do suggest you try. I don't have the same results that you seem to be having. I have no problem loading just the map data that I want and MapInstall does not remove any of my previous map files when doing so.
I also only use the "Customize...Advanced/Partial Install" feature.
Cheers,
Cheers,
Dan
All Things GPS
Old 07-25-2012, 10:33 AM   #25
HardWorkingDog OP
Harvey Mushman
Oddometer: 1,770
...I have no problem loading just the map data that I want and MapInstall does not remove any of my previous map files when doing so...I also only use the "Customize...Advanced/Partial Install" feature.
Thanks, I'll have to try that. Won't be for a couple weeks or so that I'll be able to have gps play time though...
"Coffee first..."
Old 01-13-2015, 05:16 PM   #26
HardWorkingDog OP
Harvey Mushman
Oddometer: 1,770
Time to revisit this 2.5 year-old thread Hello everyone!
Conclusion: DIY. Roll your own compiled maps, load them onto an SD card inserted into your computer, or an attached ipod, then rename them, and copy them onto the microSD that you will insert into your handheld. This is for the "modern" units. For the legacy 60/76's, compile your maps into a single gmapsupp.img file, and copy it using the finder onto your microsd. Do NOT let MapInstall 4.0 interface with your GPS internal memory or directly with a SD card inserted in your unit until the software has sufficiently matured...
So what is this "compile your maps into a single gmapsupp.img file"? Sounds like a good idea, just not sure what the process is...
edit: I know that's what MapInstall does, but it sounds like you're referring to some other process?
"Coffee first..."
HardWorkingDog screwed with this post 01-14-2015 at 07:46 AM
Old 01-13-2015, 05:30 PM   #27
HardWorkingDog OP
Harvey Mushman
Oddometer: 1,770
So I had to delve into the MapInstall issue again, spurred by the 2015 update of E32 mapas.
I decided to try the latest version 4.1.1 of MapInstall. It took 20+ hours to load approx. 515 map segments onto a 4G sd card in my 60CSx. ugggggh. But, it worked. I had to manually select all the segments I wanted (to keep all my previously installed map segments) based on screen shots from MapInstall 2.1.6. Wasn't as bad as I thought, just had to match up shapes like a jigsaw puzzle.
Once that was done I tried an experiment--I selected one new additional map segment, hit the "Send Maps" button, and after all the whirring of creating the new image, yep, it was going to take 20+ hours, again, to simply add a 15 MB map segment. No. Way.
Went back to MapInstall 2.1.6, did the same experiment, it took about 2 hours. Better, at least that's what I have experienced from Day 1 with this unit. But I decided to give Garmin a call.
Long story short--I found a very knowledgeable support tech, he told me the internal card reader on the 60 series is very...rudimentary...and suggested I try using MapInstall 4.1.1 and put the SD card into the card reader built into my laptop.
I did, and was shocked. The same operation--adding a new segment, saving the new image file to the sd card--took about 12 minutes using MapInstall 2.1.6 and about 5 minutes using MapInstall 4.1.1.
Hard to figure, but I'm happy to be able to add maps now in a reasonable time frame.
"Coffee first..."
Times are GMT -7.   It's 04:21 PM.
