Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 04-02-2013, 03:29 PM   #2806
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,349
Originally Posted by pebble35 View Post
There is a twin fan setup on the 1190 - and rather than simply being an 'on/off' switch for the fans, they run at variable speeds depending upon coolant temperature. Supposed to provide much more stable temperature control but the proof will only really be seen when (if ?) we hit summer temperatures
That would explain the constant temp readings reported by Umitc
Jaime
KTM 1190 Adv R
Jaimoto is offline   Reply With Quote
Old 04-02-2013, 06:40 PM   #2807
veesquared
Oddometer: 126
Question Tennesee, it gets hot here.
It gets up to 100 + deg. F for days here in the southeast. I had a BMW K bike that made so much heat it was unbearable. The cooling fan blew the heat onto my right leg .Could one of you gentlemen tell me where the two fans vent the air too ? I have a deposit on the Adventure 1190 and am more curious than anything as I intend on buying the bike anyway. TIA
KTM 1190 KTM 690 E KTM 200 Exc
veesquared is offline   Reply With Quote
Old 04-02-2013, 11:10 PM   #2808
umitc
umitc's Avatar
Oddometer: 353
On the right side of the radiator, if I am not mistaken
umitc is offline   Reply With Quote
Old 04-02-2013, 11:23 PM   #2809
umitc
umitc's Avatar
Oddometer: 353
And pebble what makes oil temperature decrease? I wonder, what is the exact source of the heat, can it be just the exhaust pipe, as I remember one of the reviews on the web, after Tenerife ride has mentioned.
And would it help if I wrap the exhaust pipe, usnig an exhaust wrap.
Old 04-03-2013, 03:16 AM   #2810
Georgios
Georgios's Avatar
Oddometer: 180
Originally Posted by umitc View Post
.. I wonder, what is the exact source of the heat, ...
Do you know, if the fan is running when you feel the heat?
Georgios is offline   Reply With Quote
Old 04-03-2013, 03:30 AM   #2811
umitc
umitc's Avatar
Oddometer: 353
I think I haven't heard a fan so far, like it was in 990. By the way, fans are at the rights side, if I am not wrong, but the left side of the bike becomes hotter; I can feel it where my knee squeeze the tank. :
Old 04-03-2013, 04:30 AM   #2812
Georgios
Georgios's Avatar
Oddometer: 180
... By the way, fans are at the rights side, if I am not wrong, ...
On a picture, I can see two fans on the right side of the radiator. I would place a light paper sheet in front of the radiator. If the fans work, the paper shouldn´t fall down.
Or you can see them operate when you look through the gap (between the orange and the black part) on the right side of the tank. At least some hot air should come out.
Old 04-03-2013, 04:45 AM   #2813
explodingmouse
Oddometer: 231
Joe Pilgers report from Africa on a 1190r states that he was pleased that the bike didnt overheat and he was extremely happy with the dual fans compared to his 990r.
explodingmouse is offline   Reply With Quote
Old 04-03-2013, 05:02 AM   #2814
umitc
umitc's Avatar
Oddometer: 353
Yes he is right; no overheating. Anyway, I will wrap it up tomorrow and wait for the Akra arrives in the dealer's stocks. I hope that it can turn to be more bearable.
Old 04-03-2013, 06:27 AM   #2815
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,349
Here is the first (or one the first) test vs the GSW.
It's in Spanish, but you can use google translate to read it or at least to figure things out
http://motos.coches.net/noticias/com...?tipoNoticia=2
The tester mentions the heat coming from the bike, and that could be a problem in the summer...
Jaime
KTM 1190 Adv R
Old 04-03-2013, 06:46 AM   #2816
umitc
umitc's Avatar
Oddometer: 353
Surely there is a problem; I am maybe just a little bit more careful against it, then other people. During summer it gets between 30 and 40 degrees here and it will be even more irresistable.
Old 04-03-2013, 07:42 AM   #2817
mcmann
Motorcycle Maniac
mcmann's Avatar
Oddometer: 2,099
Looks like a windmill slalom course:
"Life is 10% of what happens to you and 90% of how you react to it."
mcmann is online now   Reply With Quote
Old 04-04-2013, 07:38 AM   #2818
Lion BR
I'd rather be riding
Lion BR's Avatar
Oddometer: 4,280
Not exactly an answer to the question you were asking, but here are my 2 cents of generic approach to an answer: I have continuously had cars, since the 1990's, that have separate water and oil temperature gauges. For these cars, water and oil temperature not always run in tandem. Most common example: oil temps go up when higher RPMs are used, as in freeway riding at higher speeds, oil temps go down at idle speeds or stop and go traffic. Water/coolant goes down at higher speeds of travel, goes up when seating in traffic or at idle speeds. Now, an oil cooler/radiator changes that some but because of oil's higher viscosity when compared to water, oil cooler/radiators are not as efficient as water radiators. That is, oil remains a function of engine speed, will cool down when RPMs go down. Also, oil temps also change at slower rates than water/coolant temps change.
Whenever we are riding, we are an ambassador to our sport
I'd rather be riding!
Lion BR is offline   Reply With Quote
Old 04-04-2013, 07:49 AM   #2819
umitc
umitc's Avatar
Oddometer: 353
Thanks for your detailed explanation. Today I have spent a lot of time wrapping the exhaust using thermotec copper wraps. Seems like we have overcome a good portion of the heat. I have done almost all the bumper but, in my opinion, the biggest cause to this problem is the small pipe, in the middle of the bike. I can give you more feedback later. By the way fans work well, no problem.
Old 04-04-2013, 07:55 AM   #2820
veesquared
Oddometer: 126
Thanks for your reply.
I found a pic on page 2502 of this thread and see the stacked fans on the right. Cant wait to ride one but that is months away here in the USA.
Times are GMT -7.   It's 03:19 AM.
