Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 06-04-2013, 04:18 PM   #3391
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,695
Here is one source:
http://www.heatshieldproducts.com/pr...lava-mat/95/35
and another (same source, different product):
http://www.heatshieldproducts.com/pr...ield-mat/76/21
You should be able to make a "blanket" that will fit under your seat.
Mike -
"For those who fight for it life has a flavor the protected never know."
USMC 65-68 RVN 66-67
6USMC6 is online now   Reply With Quote
Old 06-04-2013, 10:07 PM   #3392
umitc
umitc's Avatar
Oddometer: 353
Originally Posted by 6USMC6 View Post
Here is one source:
Hi USMC, I have ordered a shield from DEI through ebay, it was a self adhesive white thick fiber covered with a hard aluminum foil. I have stuck this foil, the seat felt even warmer. Parking the bike at home, after a short traffic ride, I have taken out the seat; I can tell you that the foil was as hot as to let you cook ham and eggs on. :-))))). I have torn it out and put a plastic heat shield from KTM but not much improvement. I will love thecbike on winter for sure; in tge meantime, I am riding my 800R in the city.
umitc is offline   Reply With Quote
Old 06-05-2013, 12:53 AM   #3393
Bails
Bails's Avatar
Oddometer: 402
Had a Buell and this was an issue also. Only time I really noticed was when I didn't have leathers on , or if it was a really hot day. If I remember the way to deal with it on the Buell was to duct some extra air and this did the trick.
If it has to Be then it's up to Me!
Bikes Multi Strada 1200 BMW GSA
Bails is offline   Reply With Quote
Old 06-05-2013, 01:47 AM   #3394
umitc
umitc's Avatar
Oddometer: 353
Yes, during summer, leather is out of question and it's just the beginning. There is not much space, I am tired of trying. Because whatever I did, it has just worsened the problem. I will ride like this as long as I can. Thanks that I have a backup
Old 06-05-2013, 02:48 AM   #3395
aus636
aus636's Avatar
Oddometer: 52
heat under the seat
unfortunately the only solution is to ride the bike at speed for. better. air flow
Do as much as you can when you can
aus636 is offline   Reply With Quote
Old 06-05-2013, 03:07 AM   #3396
bigboyxl
bigboyxl's Avatar
Oddometer: 330
i confirm
KTM LC4 640 Adventure 2006 KTM 530 EXC 2011
KTM LC8 1190 Adventure
www.alburmoto.com
Nomada panniers, Holan crashbars, Remus silencers etc. Worldwide shipping. Better deals for ADVriders
bigboyxl is offline   Reply With Quote
Old 06-05-2013, 03:10 AM   #3397
az63u
az63u's Avatar
Oddometer: 140
The speedo on the right with a single man , 2 man , a luggage. Does it only appear only on the adventure and not the R model?
Cause I notice that some models do show and some doesn't.
My R model book also doesn't indicates it.
Can anyone explain???
az63u is offline   Reply With Quote
Old 06-05-2013, 03:10 AM   #3398
umitc
umitc's Avatar
Oddometer: 353
Yesssss, definitely
Old 06-05-2013, 03:13 AM   #3399
bigboyxl
bigboyxl's Avatar
Oddometer: 330
only bikes with EDS (electronic damping system) has this. and only standard model (meaning non-R) can has this option
R model has manually adjustable suspension, not electronically
www.alburmoto.com
Old 06-05-2013, 03:17 AM   #3400
Viajaendl
Oddometer: 18
Yup,
The R version hasn't electronic suspension adjustment and the T version (normal) got it
Viajaendl is offline   Reply With Quote
Old 06-05-2013, 03:21 AM   #3401
az63u
az63u's Avatar
Oddometer: 140
Originally Posted by Viajaendl View Post
Yup,
Thanks a lot, just as I expected it........
enjoi the ride
Old 06-05-2013, 07:12 AM   #3402
igorpetrovich
igorpetrovich's Avatar
Oddometer: 181
in Italy we are finnaly getting some warm weater and I started to feel the problem of the heat, on the left leg only.
I put a small plastic barrier and the situation inproved a lot.
Ktm 1190 adv R------ Ktm 350 exc-f
igorpetrovich screwed with this post 06-05-2013 at 11:49 PM
igorpetrovich is offline   Reply With Quote
Old 06-05-2013, 09:31 PM   #3403
umitc
umitc's Avatar
Oddometer: 353
let me try something like this in the weekend. Thanks for the tip Igorpetrovich
Old 06-06-2013, 03:37 AM   #3404
nikoktm
nikoktm's Avatar
Oddometer: 283
I"m looking for the fog lamps from Power parts. Here in Australia they cost almost $800.00. Do Any of you guys know if those ones are different than the Touratech ones? And if so, which ones are better?
nikoktm is offline   Reply With Quote
Old 06-06-2013, 04:26 AM   #3405
RoundOz
Plenty of seasoning
Oddometer: 1,014
Light choices
I am assuming these are halogens. If it was me I would install aftermarket LEDs at a fraction of that cost, better performance and less amps. They are usually a broad beam but that is how the Powerparts ones are described anyway. Touratech does make a hid which should be all he light you will ever need but for the 990 version here in the States they are nearly $600 each side!
2009 KTM Adventure
RoundOz is online now   Reply With Quote
Times are GMT -7.   It's 12:39 PM.
